Question about LG 17" L172WT Monitor
What causes a herringbone pattern on L172Wt television and composite input, but not PC input?
  • papa_crisp Sep 04, 2009
    Neither Composite nor S-Video go through the IF section, but both have the patterning on them. HDTV input and PC analogue and digital inputs do not suffer from it.
  • 788 Answers
Your PC input is a secondary interfase, it does not go thru the IF and tuning sections.
It is possiable the if section has taken a surge and will need to be serviced.
Posted on Sep 04, 2009
Herringbone pattern at turn on clears as it warms up.
Does your TV show red, green and blue colors separated?
If the answer is yes, the problem is in the convergence circuit.
There are 2 integrated circuits (STK392-XXX) that need to be replaced by a qualified TV technician. The repair will cost around $150 or more.
Aug 13, 2014 | Toshiba 46H84 46" Rear Projection...
How do i connect my wii to my new samsung ue46d6530?
Input &
Output
HDMI 1.4 (3D Auto Setting/Return Channel):4
USB:3
Component In (Y/Pb/Pr):1
Composite In (AV):1(Common Use for Component Y)
Digital Audio Out (Optical):1
PC In (D-sub):1
CI Slot:1
SCART:1
RF In (Terrestrial / Cable input):1
RF In (Satellite input):1
Headphone:1
PC Audio In (Mini Jack):1
DVI Audio In (Mini Jack):1 (Common Use for PC Audio in)
Audio Out (Mini Jack):-
Ethernet (LAN):1
Initially I thought the problem was going to be no composite input on this television. However according to the specs there is one composite (yellow, white, red) input and that is where you connect the wii. Is the problem that you've already connected something to the one input and you're looking for another spot to connect the wii? There is a wii component cable http://www.amazon.com/Official-Wii-Component-Video-Cable-Nintendo/dp/B000JJRV90
Jun 13, 2011 | Samsung Televison & Video
What causes a herringbone pattern on L172WtProblem with the LG 17",ok on pc.problem entered 10 months ago.is there a fix now
Do you have another electrical device too close to your tv?
those patterns are caused by AC power leakage. You can move other devices i.e.sat box etc. further away from your tv to fix this.
Jul 14, 2010 | LG 17" L172WT Monitor
TH-37PE30 - DVD picture now lousy (herringbone?)
Do you have an S Video cable connection on the DVD player? I'd try that If you have one or component (red green blue) cable or even the composite (yellow) connection. The SCART connection on the input PCB of the tv could be damaged. The cost of this board may be pricey so if you can use the other type of connections with the DVD player I'd recommend that or get a DVD player that has one of those. Your model does not have HDMI so those are your only other options. Hope this helped
Feb 08, 2010 | Panasonic TH-37PE30 37 in. Plasma...
Problem with AV Input and TV signal distorted but i know signals are fine from source
change devices to other ports, if you are sure some ports are not working properly then you will need to replace the mainboard.
May 16, 2009 | LG L172WT 17 in. HD-Ready LCD Television
Picture quality in cable mode only, watching dvd picture is
Herringbone pattern?
House stray AC 60hz signal is getting into the cable b/c the shield is not properly grounded. Call the cableguy
Mar 26, 2009 | Samsung 50 in. Plasma TV
I INSTALLED MY ATI RAEDEON 128PCI VIDEO CARD AND IT HAS S VIDEO OUT AND COMES WITH THE SVIDEO TO RCA CABLE BUT I CANT GET THE IMAGE TO DISPLAY ON TV
The S-video to Composit adaptor tells me that you wish to connect to the Composit input of the TV
Connect the TV , set the TV to ( Composit input ) Composit 1 , or Composit 2 , NOT A CHANNEL
restart the computer , this will help the video card and software to detect that the TV is now on and connected.
When you come back to windows you should be prompted to perform the television setup wizard
if not
go to your display properties
Advanced tab
and manualy configure the video card for television output.
Selah.
Sep 15, 2008 | Computers & Internet
Herringbone pattern
Herringbone (and other patterns) can be caused my many faults, the obvious one the tech was looking for was a tuner/interference fault.
Another common cause is a faulty power supply.
Difficult to say without having the TV on the bench.
I'm a bit suspect about the $400 - $500 repair cost though.
Perhaps try another tech?
I doubt it's a DIY repair though.
Let's know how you get on.
Jan 20, 2008 | Sony KP-61V85 61" Rear Projection...
LG 17" L172WT Monitor Logo
120 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
