Question about Frigidaire FRS26R4A Side by Side Refrigerator
Water leaking onto floor when defrosting automatically
I have a frigidaire refrigerator/freezer FRS26Z?H
water leaking onto floor when defrosting automatically...why?
  • Frigidaire Master
  • 4,655 Answers
There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are cased by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
SEA BREEZE TIP's
Posted on Sep 04, 2009
Frigidaire side by side refrigerator is leaking water
I assume you are talking about water leaking from the freezer onto the floor. It is most likely that the defrost drain is blocked in the freezer causing the water to drain through the air vents. You will most likely have to remove the rear panel in the freezer and pour hot water in the drain trough until the drain clears up and the water drains down the drain tube.
Aug 15, 2014 | Frigidaire Refrigerators
Frigidaire refrigerator/freezer
bit confuse with your problem.. are you having a defrost issue or leaking issue? If defrost issue... Check your compressor it is working? compressor - The thing that make noise behind the refrigerator...
Sep 05, 2007 | Refrigerators
Frigidaire refrigerator leaking
Good Afternoon Friend,
I understand that there is a frost build-up on the back wall of the freezer portion of your Frigidaire refrigerator. I also see that there is water leaking onto your floor from the front of your appliance. What you are describing is a possible frozen evaporator, and the freezer needs airflow to work properly. You need to completely defrost the freezer. If your appliance starts behaving normally after defrosting then you need to monitor it closely, as it will sometimes start frosting up again. If it does fail again then it's possible you have a defrost problem. Possibly the defrost heater, but can also possibly be the defrost timer or defrost sensor. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. If further troubleshooting is needed, please leave me your model number. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Frigidaire Refrigerators
Frigidaire Fridge Freezer forms huge iceblock inside fridge back wall. It freezes up whatever is stored in fridge i.e. vegtables, cheese. Water leaks onto the floor from under the vegetable containers. ...
the defrost drain pan is plugged up,you need to defrost it and run a wire down the drain tray hole so it can drain to the bottom as it defrosts otherwise it defrosts and runs everywhere else and re freezes
Jun 05, 2011 | Frigidaire GLRT86TES Top Freezer...
Ice is forming in the bottom of my side by side fridgedaire freezer and once its 1/4 inch thick starts to melt and leak from the freezer onto the floor. I then take out the ice built up and the process...
The drain is either frozen or plugged...when the freezer coil defrosts the water has no place to get away...
Find and fix the drain and you will be okay again...
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Nov 16, 2010 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire FRS26ZNH frig is freezing water in the bottom of the freezer and is leaking water onto the floor. i have looked for a stopped up drain plug or hole with no success. please help. john
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
heatman101
Aug 30, 2010 | Frigidaire Refrigerators
Defroster drain leaks into the main compartment
The drain hole is plugged. Probably with ice now. Needs to be fully defrosted with a heat gun or hairdryer, be sure drain is free by pouring hot water into it and seeing it get to the pan below the machine. If this persists you need to troubleshoot the automatic defrost circuit. Could be bad defrost timer.
Sep 01, 2009 | Frigidaire FRS26H5AS Side by Side...
Leaks onto floor
your defrost drain is stopedup if its a sxs its in the back bottom of freezer side if its a top mount its behind the back over in the freezer remove and use hot water and blowdryer you will see a little drain tube under the evap coil
Jul 05, 2009 | Frigidaire Gallery Series GLRT218WDZ 30"...
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
577 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
