Question about Everstar Portable Heater/Fan
I don't know where to put the water. Its been draining water but I don't know how to refill it.
    Problem Solver:
  • 5 Answers
It makes water on it's own , thats the condensation from the Air conditioning process itself.
Better not to use the small water condensation drawer, rather use a bucket with the drain hose supplyed with the system. it holds alot more water and you shouldn't ever get the P-1 error code because of having the drawer full of water or the drawer switch missaligned.
If you do use the water drawer be careful and gentle when putting it back in after emptying it. It has a switch in it that makes contacts for the AC unit to work in AC mode and not just fan Mode.
The fan will always turn on unless it goes out, but the AC when it is on will sound diffrent when working it should sound a bit like a air compresser at the gas station because that is basicly what it is.
Posted on Sep 25, 2009
My car overheated, I let it cool down and was about to open the radiator I put water it and then I put what I thought was radiator fluid. it turned out it was oil. it smoked (white) really badly. I had...
Go buy a small bottle of dishwashing liquid. Drain your water/oil out of the car. Refill with straight water and the bottle of soap. Start the engine and let it warm up to operating temperature so the soapy water has a chance to circulate. Drive around the block if you want to, or just let the engine run warm for a few minutes. Stop the engine and drain the soapy water out. Refill with water only, warm up the engine. Drain again and fill with 50/50 premix. Hope for the best.
Mar 15, 2015 | Honda Cars & Trucks
Where is te tap of the radiator of my toyota celica 2002
You mean you need to drain the old water and refill w/new water..?
-Drain plug is in the Btm of the radiator.
-Filler cap is on top of radiator. Just push down the cap and turn Left to
open. (Careful do not open when it's hot!)
Mai
Mar 29, 2013 | 2002 Toyota Celica
My dishwasher is not spraying out water. The floater fell off and I don't know how or where to put it back.
there are filters in your water lines and sometimes the drain check to see if plugged
Mar 10, 2013 | Dishwashers
Where is the Drain valve?
Usually on the bottom, looks like a hose spigot , put yard hose on it and open it up!
Jul 20, 2012 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Whenever I put the car into reverse it hesitates for about 2 seconds, is there a problem?
If your fluid is getting old in the TRANSMISSION, add one and a half cans of SEA-FOAM TRANSMISSION treatment to it and follow instructions on the can.THEN drain and refill fluid.Not necessary to drain and refill if your fluid in TRAN.is fairly new. don-ohio
Oct 02, 2011 | 1997 Ford Explorer AWD
190cc 675 sears push LM. Irene put it under water. Drained carb and crank. removed and cleaned filter. New gas. Won't start. Got a little pop with starter spray. No pop at all?
Did you drain fuel tank before refilling with fresh fuel? Drained carburator bowl good, drained crankcase and refilled with fresh oil good,removed air cleaner and dried out good. One question for you , did you remove spark plug and drain any water that may have gotten into your cylinder through an open valve? There could be water sloshing around in the cylinder, gas and water will not fire, and water on spark plug wont allow plug to spark. If you need any more help please get back to me , I believe this is the first under water problem I've encountered. GOOD LUCK.
Sep 07, 2011 | Briggs & Stratton 190cc 875 Series OHV...
Is there not a radiator cap on a 1999 silverado? want to flush sysyem but do you refill through resavoir?
If you don't see a cap, you don't have one. If you are flushing in hopes of correcting an overheating problem, be aware that if the radiator is partially obstructed, the flush chems sold today are too mild to actually do much. The better chems were all banned by the epa.
If you are just doing routine maintenance, easiest method of draining is to remove the lower hose at the radiator, let the system drain, put the hose back on, fill with water and any chems you want to use, run it as per instructions, drain again, fill with more water and repeat with water at least twice before draining and filling with new antifreeze.(do all flushing with heater on full heat) Keep the cap off while doing this so you don't build up pressure and be careful draining hot water. Even though they are mild for the job, chems can still irritate your skin so be careful. When filling for the final time, make sure the system is full and the thermostat has opened before closing it up. Always check everything over for leaks.Any other questions? Just ask!!
May 30, 2011 | 1999 Chevrolet Silverado 1500
I have a 1995 Jeep cherokee country..I need to know how to drain water out of the radiator so I can put in antifreeze.
on the bottem of the Radiator there is a drain plug (screw) it will drain the whole radiator so you will need to refill it again. it is best to drain the whole thing because if yoo don't the water could crack your radiator.
Dec 07, 2010 | 1995 Jeep Cherokee
Proper method on coolant system flush
Best way is to buy a flush kit. It is an adaptor that you put in your heater hose and can hook up a garden hose to. You cut the hose and put this device permanently in the line. Remove the thermostat, don't put the new gasket in there yet just put the outlet pipe back on and bolt it down. Run the car when cold with your hose running for about 10 minutes with the radiator drain valve open on the bottom of your radiator and the cap loose, water should come out of the drain valve and the radiator cap. This will flush your engine adequately, why waste money on distilled water, save that for topping off your battery. Turn off your engine continue to allow water from your hose to flow as long as you are seeing any thing other than clear water flow until it flows clear. Turn off the hose, put the cap on the flush port you installed. the port stays under your hood and allows you to flush your engine as needed. Let the water drain through the drain valve. Put in a new thermostat, with a gasket this time. Refill with water and antifreeze as directed in your manual. You should be good to go.
May 21, 2009 | 1997 GMC Jimmy
I accidentally got water in the oil part of the engine
Definitely DO NOT start the car...drain the oil pan, replace the plug, and refill with the proper amount of oil. Start the car and run until the engine temp is at the normal range for at least 15 minutes. Then drain the oil, change the filter, and refill with fresh oil.
Jan 22, 2009 | 2005 Pontiac Grand Prix
Everstar Portable Heater/Fan Logo
108 people viewed this question
Top Everstar Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you an Everstar Pool and Spa Expert? Answer questions, earn points and help others
