Question about Bosch 24 in. SHU43 Built-in Dishwasher
BOSCH SHU43C06UC/17 DISHWASHER DOES NOT RUN WATER AT ALL DURING CYCLES
  • 10 Answers
SOURCE: Dishwasher repair
The most common reason why your machine has stopped filling is not the valve, but more likey you have had a leak and the base of the machine is full of water.
If you take the lid off followed by the left side panel ( held on with 2 torx 20 screws ) the lid has two clips at the back and pushes back from the front.
at the bottom of the metering tank towards the front you will see a Red lever going up to a mircoswitch and down to a float. push the lever down to see if the microswitch reacts. if so the base is full of water. empty out and test. try this first, if no luck get back to me.
Posted on Mar 23, 2008
here2helpBSH
  • 27 Answers
SOURCE: Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Posted on Mar 19, 2009
jan mczeal
  • 632 Answers
SOURCE: water not draining
If the water doesn't drain from your dishwasher, check these:
  1. Drain line/air gap--A clog in this part is the usual reason that a dishwasher doesn't drain. Remove the drain line to clear any debris from the hose or hose connection at the household drain line connection. Reattach the hose before starting the dishwasher again.
  2. Pump--You can reach the pump from inside the dishwasher. Remove the lower rack, spray arm and support. Look for an impeller, a device that spins around and forces water through the spray arm. This is the wash impeller and beneath it is the drain impeller that pushes the water into the drain port. Replace it if found defective or worn out.
  3. Drain valve/solenoid---The drain valve may have a solenoid with lever that sticks or frozen and prevents the dishwasher from draining. Free up the solenoid and lubricate the lever.
  4. Belt---A certain brand of dishwasher uses a belt to drive the pump. Replace it if broken or worn out.
  5. Motor---Check it if turning or working.Turn the rotor manually to see if stuck and free it up. Replace if defective, it is not serviceable.
Posted on Sep 04, 2009
BIKER T
  • 909 Answers
SOURCE: Bosch Dishwasher with very little water pressure or power
It all stems back to your incomming water supply. Either the sieve is dirt or the valve is blocked with sedementation. Some valves are servicable and some are not,if your valve has screws then its revicable. (low water pressure restricts movement on arms.)
Posted on Sep 18, 2009
arikrom
  • 528 Answers
SOURCE: bosch shu43c06uc-17. Our dishwasher turns off mid
  1. open the bottom panel 2-4 screw
  2. take a flashlight and turn the machine on
  3. see where it come from
  4. if you need take the unit out a bit from the counter
  5. check it all around to find the sorce of the leak
  6. good luck its EZ :)
Posted on Jan 01, 2010
My Bosch SHU436UC/17 goes thru its cycle OK, but dishes aren't very clean. During the wash, the water isn't very warm, but at the end of the cycle, the dishes are very hot. Any ideas?
Is the water supply hooked up to the hot water are you rinsing the dishes before you insert them in the dishwasher did your dishwasher low on
Nov 28, 2015 | Bosch Dishwashers
MY BOSCH DISHWASHER MODEL #SHU43C06UC/17 WILL NOT START. NONE OF THE LIGHTS TURN ON AS IF THERE IS NO POWER GETTING TO IT. I HAVE CHECKED THE POWER CORD AND THE BREAKER BOX AND EVERYTHING IS O.K., BUT I...
Hi gwmkjm,
I'm Harvey the Master Plumber.
Your question is: YOUR BOSCH DISHWASHER MODEL #SHU43C06UC/17 WILL NOT START. NONE OF THE LIGHTS TURN ON AS IF THERE IS NO POWER GETTING TO IT. YOU HAVE CHECKED THE POWER CORD AND THE BREAKER BOX AND EVERYTHING IS O.K., BUT YOU STILL CAN NOT GET IT TO TURN ON. AT ONE TIME THE LED LIGHT LIT UP FOR A BRIEF SECOND, BUT NEVER AGAIN. ANY OTHER SUGGESTION?
Yes. 9 times out of 10 it's a loose or broken wire in the d/w junction box under the d/w behind the kick plate on the right. Make sure to turn off the electric before you expose the wirenuts. Remove them and install new.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 28, 2008 | Bosch Dishwashers
How do I fix the heater in my Bosch shu5306uc / u12?
SHU5306UC-12 BOSCH DISHWASHER Manual - Sears ...
www.searspartsdirect.com > Kitchen Appliance Parts > Bosch Parts
Download Manual for Model SHU5306UC-12 BOSCH DISHWASHER.Sears PartsDirect has parts, manuals & part diagrams for all types of repair projects.
Aug 01, 2015 | Bosch Dishwashers
Does my Bosch SHU43C06UC/17 dishwasher have a hot water element in it? Our kitchen tap water does not get very hot, and before I hook up the dishwasher I want to make sure it will have water hot enough to...
Hi.
Your dishwasher should never be connected to a hot water tap.
Every dishwasher has its own Heating element. If you connect it to a hot water tap you may eventually damage the inlet valve which has sensitive plastic components in it and may even void your warranty if your installation manual suggests Cold water connection only.
Regards Sam
Oct 06, 2013 | Bosch 24 in. SHU30 Built-in Dishwasher
Bosch SGI4345AU/17 shows 2H on the display, it does not seem to matter which program is selected, the unit runs continually. It does not heat the water or finish any cycle. The washing tablet covers the...
The Control unit on your Bosch has a burnt out heat circuit. Just about every dishwasher has a number of "thermal holds" during the wash and rinse cycles in which the controller waits for the water to be heated to a specific temperature. Most dishwashers check for a temperature rise over a certain amount of time and will shut down if this increase is not seen, however, Bosch does not employ this secondary check and the unit will run for as long as you allow.
The Control Unit on your dishwasher will need to be replaced. Being as Bosch is extremely properitary on their parts sells, it is best to actually talk to a parts supplier directly in order to ensure you are getting the correct controller. It is very important that the replacement controller is for your model #, including the /17 designation at the end. A xxxxxxUC/12 controller will not work on your model.
The Control Unit is found in one of 2 places; 1) behind the Control Panel, or 2) at the lower right hand side of the unit towards the rear. Both are relatively easy to replace.
Apr 16, 2011 | Bosch Dishwashers
My Bosch Dishwasher model #SHU43C06UC/17 in 5 years old and has been working great and all of a sudden last week it stopped working. When you try to start a new load it will start the timer, but the...
Welcome to FixYa.
I would first run a diagnostic to see what error is presented and in turn will direct which way to focus the repair.
Try this and then let me know what you find aa a result...
This diagnostic posted below should guide you, let me know if it isn't clear or you don't understand something.
Sep 23, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch shu43c06uc-17. Our dishwasher turns off mid cycle, and now leaks from the bottom.
Nov 28, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Water not draining
Sep 04, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
BOSCH DISHWASHER SHU43C06UC/17 NO WATER UPPER ARM
Ours is a SHU3300UC/06 model, basic model which we bought in 1999 so have had 9 years of trouble free service.
Recently we noticed that there was soap left in the soap dispenser after the machine had finished all the cycles. On further inspection we noticed that the upper level glasses, cups and bowels are not consistently clean and it appears that the upper washing arm is not working properly. At the back of the upper washer arm, there is a rectangular piece that slides over the two water outlet tubes projecting out of the back of the washer which supply H20 to the upper arm. On removing the upper arm and the rectangular connector, I noticed there is an inner place that I think is supposed to work like a washer that fits tightly over the 2 water outlet tubes in the protruding from the back of the washer. I noted that the upper opening in the washer/seal is broken so a proper seal is not established. This would cause insufficient water pressure getting to the upper arm and reduce its effectiveness. Now I'm trying to find the replacement part. It appears to be something than can easily be replaced.
Dec 06, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Leaks, doesnt drain properly and cloudy film on glasses
u have water under dw .and overfill switch turninng on only  drain pump all time.second from bosch water  water never leaks on floor.
Sep 25, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
208 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
