Question about Sony Ericsson W350i Cell Phone
Flip broke the flap broken off to and the tiny piece of metal cam out but i put in the wrong way ad its stuck now wat should i do
2005 Lincoln LS V6 Ash Tray stays open, wont close
Pop out the ashtray. Remove the ashtray assembly (the housing). if you flip the ashtray over and look at the bottom you can see a small spot where a piece of plastic has broken off (this should be obvious). In the ashtray housing there is the latch mechanism with the broken "nipple" probably stuck inside of the mechanism. Get the plastic piece out and discard it. Reinstall the housing only.
Now, get a TINY ( I mean really small, like 4mm long and maybe 1/4-1/2mm diameter) screw handy. Drill a slightly smaller hole right through the ashtray where the piece of plastic was before it broke off. screw in the screw from the TOP of the ashtray so it only pokes out of the bottom 1.5 MMor so. Put the ashtray in. If it still doesn't "catch" screw the screw in a little further so it sticks out the bottom a little more. If it binds you've ******* the screw in too far so back it off. You get the drift.
This takes about 30 minutes. It's hard to explain but once you look at the bottom of the ashtray you'll understand the concept. Hope this helps somebody out there.
May 07, 2016 | Lincoln Cars & Trucks
Printer ribbon is stuck
hi my thermal ink ribbon is stuck to the unfinished photo and has stopped working the on button has gone red
Nov 22, 2013 | Casio PCR-272 Black Cabinet Design Cash...
My Lexmark X2480 printer starts to feed the paper, it goes crooked and then an error message appears that there is a paper jam. How can I get to the rollers to clean them please? Thanking you in advance...
Normally this occurs when there is a tiny piece of paper stuck between the front roller and the feed metal piece. This can be cleared by putting something like a piece of card in (after lifting the flap at the front) and sliding it sideways until you can find the paper. Long nose pliers or tweesers can then be used to remove it.
Alternatively, put the card in and manually feed it though - as sometimes it can pick up and clear the paper jam.
Hope this helps.
Jul 26, 2011 | Lexmark 2480 Matrix Printer
I have a ESP 3250 and it keeps giving me a error message saying that it has a paper jam. Problem is that there is no paper jam.
Very common issue and always the same fix: There will be something in there, whether it is toner/ink over a sensor, a paperclip/staple, a plastic flap which is flapped the wrong way, or a tiny scrap of paper.
The trick with this one is patience, methodically strip it down as far as you can, checking as you go for stuck material, and once you have gone as far as you can put it back together nice and slowly, looking for broken connections and loose bits, then try it again.
If there is nothing in there then the printer has something broken and needs looking at by a technician, in this case you should turn to your warrenty.
Oct 31, 2010 | Kodak Office Equipment & Supplies
My lens is cracked on my flip cam, how do i fix it?
They aren't too hard to open up and take apart. There's a glass piece the covers the actual lens and I'm guessing that is what broke. Once the flip is in pieces you can remove the glass piece and it will operate fine without it. If you want to replace it, you can either get a broken flip and use it for parts, but there's a pretty sticky, tough ring of tape holding that glass piece in place. You could also try a very clear piece of plexiglass and cut it to size. Haven't tried that one myself, but it may work.
Apr 15, 2010 | Pure Digital Flip Video Ultra Camcorder
Hp laserjet 2420 paper jam 13.20.00
Hi, check throughout the printer for small pieces of paper stuck, broken sensors etc, clean the rollers in the paper tray 2, check for wear. clean the registration rollers (under a metal flap under the print cartridge) do not clean the transfer roller (the spongey roller sitting under the drum!)
Feb 09, 2010 | HP LaserJet 2420 Printer
Turns over but won't fire
well the plastic piece are from the timing chain guides are either broken or ripped off,and the metal rattling was probably the timing chain,,i think the timing chain jmped or broke and broke the guides,if thats the car you most likely bent the valves in the head,,,i would remove the cam cover and the timing chain cover and see what you got,you may need a engine
Oct 19, 2009 | 1992 Saturn SL1
Cover card open when it's shut
This problem is caused by the little piece of plastic that you flip down to hold the XD card in place. It has a nipple sticking out of it that is prone to breaking off. Unfortunately, this nipple (about 1/16" x 1/8" x 1/8") holds down a little button which tells the camera that the the plastic piece has been flipped down. Once the nipple breaks off, you need to find some other way to hold the button down.
I simply took a small plastic peg from an old boardgame -- a cribbage-board peg might work -- and whittled it down to fit the opening. Remove the XD card and you'll see the small 1/16" x 1/8" rectangular opening. There's a tiny, squarish black button inside. Use a toothpick or tiny screwdriver to carefully press the button in while the camera is on, and you'll see the error message disappear.
Once you get the idea, use a tiny Phillips screwdriver to remove the plastic piece that you flip down. There are two screws to remove, two little metal retaining brackets and a tiny metal rod. Be careful not to lose any of these pieces! Then gradually whittle your piece of plastic so it fits the rectangular opening snugly, and consistently turns off the error message. Then cut it to about 1/8" in length, insert it into the opening, and reassemble the rod, brackets and screws to hold it in place.
Now the little button will always be pushed in and the camera will be functional once again. Since the XD card has its own spring-loaded "locking mechanism" (you push to insert and push to remove), the piece of plastic you flip down isn't really needed in the first place. You can save it, anyway, just for the memories....
Apr 05, 2008 | Olympus Stylus Verve S / ?-181 mini S...
My needle broke and a piece of metal fell out of machine
Totally happened to me last week. I discovered that the metal piece that fell off and holds the needle has a small screw that holds it in place. It needs an Allen wrench (tiny one) to tighten it back into place. I just lucked into figuring it out.
Sep 11, 2007 | Brother XR-65t Mechanical Sewing Machine
Sony Ericsson W350i Cell Phone Logo
160 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
