Question about Canon Office Equipment & Supplies
Printer ip is not getting reply
I have canon iR2016 All in One Network Printer i Gave it a ip .but i m not gattig Reply
    President:
  • 1,126 Answers
Do you have printer enable kit installed? These copiers come with network interface board installed, but need the print kit to enable printing functionality.
Posted on Sep 07, 2009
Why isn't anything appearing in the control panel display of my HP Laserjet p2055dn?
try giving ping command to the ip of the printer
if you get a reply from the printer in the command prompt then the printer is properly connected to the network. for a precaution try to switch off the printer and if then too you get a reply there is conflict with the same ip.
if you get a proper reply from the ip try installing the driver once again
May 03, 2016 | HP LaserJet P2055d Printer
We use a Canon 8180c in the office and it worked fine for a while on a network. (except that it changes the port everytime the power goes out) Now we can't even pick it up on the network. The lights at...
The simplest solution would be to set the printer up to use a static IP Address. It sounds like it's currently setup to get a dynamic address via DHCP - which would explain it getting a new address every time the power goes out.
If you set the printer up with a static address you can then setup each computer to use that IP port. That should maintain a direct connection that you won't lose after a power outage.
If you need additional help just reply to this solution.
May 03, 2011 | Canon imageCLASS MF8180C All-In-One Laser...
RESET PASSWORD FOR CANON IR2016 COPIER. I LOST THE PASSWORD.
My Canon C-IR2016 is demanding a Administrative ID & Password.
I did entered the Admin PWD and latter removed it. but can't really
tell what happen that after I restarted the copier, it still requested for
the Admin ID & Password. unfortunately the the details i used before
is not functioning any more. PLEASE I need Help !! thanks
Oct 06, 2010 | Canon iR 2016i Black and White Copier
I lost my software disk for my wireless printer. I download drivers on line and still can not work wireless. It works fine when its hard wired. But when i unplug it, it goes offline. I have tried alot of...
For that first make sure your wireless network adapter driver is working fine.Try to uninstall and then reinstall . Then check the ping of your wireless printer ip address you can check it in "run " for that press windows key + R key then you can see run type in run "ping 192.168.1.1" without where 192.168.1.1 assumes ad your printer ip. Then press enter then if you get "reply from..." then printer is in network but if you get "request time out or destination host unreachable then it is not in network then check your printer ip address and your computer ip address. Also reinstall printer driver from below link. Click here Let me know if you need further assistance. Thanks for using FixYa.
Aug 27, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Can't find printer on network after establishing ip address on printer I've followed the procedure of getting IP address, Gateway etc, but when I try to install a driver on the computer, it can't find the...
are you still on the network, ping the printer ip address or eg Ping 192.168.10.4 -a -t, if you get a reply and you have an administrative access to configure the printer then you are done, but ensure you are on the same domain, same subnet mask and within the IP range for this network,
Regards,
Mar 13, 2010 | Office Equipment & Supplies
I changed internet providers and now my wirless printer doesn't work
STEP1: Print "Network Configuration Page"
  • Make sure paper is loaded.
  • Push the Setup Button on the all-In-one.
  • Use the Down Arrow key to highlight the Network menu.Push Ok
  • Push Ok again to select View Network Settings .
  • Push Ok again to select Print Network Configuration page .
  • A network configuration page will print.
STEP 2: Check the Printer Connectivity
  • From the printed Network configuration page, note down the printer IP address, (example : 192.168.1.6).
  • Click start, and then click "RUN".
  • In the RUN box, type "CMD" press OK.
  • In the command screen, type "Ping IP address" (Example: Ping 192.168.1.6). Hit Enter.
  • You must get output similar to below.
Pinging 192.168.1.6 with 32 bytes of data:
Reply from 192.168.1.6: bytes=32 time=1ms TTL=64
Reply from 192.168.1.6: bytes=32 time<1ms TTL=64
Ping statistics for 192.168.1.6:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 1ms, Average = 0ms
STEP 3: Configure Port.
  • Click on start >> Control Panel >> Printers and Faxes.
  • Right click on printer icon, select "Properties".
  • Click the PORTS tab on the top.
  • Select your product under the Printer column, and then click Configure Port . The Configure Standard TCP/IP Port Monitor dialog box opens.
  • Look in the Printer Name or IP Address box. This value should match either the MAC or IP Address on your network configuration page. If the values match delete the printer and install it again.
  • If the values does not match,Click inside the Printer Name or IP Address box, and then type the appropriate value (IP address / MAC address) as listed in network config page.
  • Click OK , and then try printing again.
Regards
Riztech
Mar 08, 2010 | HP Photosmart C6180 All-In-One InkJet...
How can i established network connection with ir2800 and desktop
First of all you must have a local network hub.Connect your network hub with your computer and the Ir 2800,your IR have to be equip with a network card.(If only have to connect one computer and your computer is not connected to a LAN network,you can use a cross-over cable connected directly from the computer to the IR machine.Give your computer a ip address by right clicing on the local LAN select properties and select internet protocol ver 4,and select a ip address.If your computer is already connected to a network,dont change the ip address go to command prompt tipe in ipconfig/all.This dos command will show you what the ip address is of your computer.
Example the ip address is 192.168.1.10,Select a ip address for your IR by changing the last class to any number.But you must make sure this ip is not in use,lets say you select 25.In the command prompt tipe :ping 192.168.1.25.If you get a reply,dont use the number.Select a number untill you dont get a reply and a time out response.
Now use this IP address and program it on the IR2800 under additional funcktion system setings,network settings,TCP IP settings.
Switch the machine off for a minute and switch it back on.
Now load the printer drivers of the IR and add the port you selected.
Restart the computer,
And print to your computer.
If you have any trouble along the way,just send me a note
Dec 10, 2009 | Canon (6981A002AA) for imagerunner 2200,...
The printer is not being detected on the network. The printer network settings are all OK and a test print can be done from the printer. The network cable is OK.
Reset its ip adreses.
go to printer menu then find tcp ip settings set ip addreses ,subnet mask and default gateway then check ping.If you get reply then it is in network.
the ping coomand is type as "ping 192.168.1.1 -t"
for example.then if you get reply then it is in netwrok.type this coomand in command prompt.
Jul 13, 2009 | Konica Minolta magicolor 4650DN Laser...
Setting Ip address on canon c3220 imagerunner.
Is the Canon connected with a cable that's connected to an active port. You can try to Fixed IP hold down 1 & 7 When you power up the machine, make the necessary network configurations and see if pings back with a reply.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 06, 2009 | Canon imageRUNNER C3220 Printer
No Network Driver Load When I install Win XP Pro...
please check the IP Address i.e,
go to
Control Panel
Network Connections
Local Area Connection (Right Click On it)
Properties
Internet Protocol(TCP/IP) Properties
See whether the
IP Address,Subnet Mask,Gateway,DNS Server Address
is entered properly or not
if it is entered properly go to Command Prompt type the following
Ping ip address and ping gateway address and DNS address
if both are getting reply then connectivity is there no reply means
either the cable not plugged or else cable not poper i.e, RJ 45 Cable (Network cable)
if still not solved try to get the solution from the vendor or else friends or any computer technician nearby to u r home because until some one has to come over there and understand the problem then only we can solve the problem .
Sorry i thought it was a driver problem so therefore i gave the link for drivers
Aug 19, 2008 | Dell Latitude D510 Notebook
old marine
old marine
