Question about Nikon Coolpix SQ Digital Camera
System error I see quite a few postings for the same problem but no solutions, does this mean we toss the camera? Please try to assist Regards Corrie
  • 2 more comments
  • Anonymous Dec 13, 2007
  • Anonymous May 27, 2008
  • mchg Jul 09, 2008
    same camera - same issue
    had no luck with Maxwells - they said it was a fault in lens
    will cost over $300 through them, to fix
    very unhappy
  • Anonymous Oct 25, 2008
    Me too "Error system" how to reset it! Nobody have a solution!!!??
    Problem Solver:
  • 5 Answers
My camera has been sitting in a drawer since 2005, found it tonight and decided to try take it apart to see if the lens was stuck ( apparently this is a problem with nikon coolpix), but before i did ( couldn't find screwdriver) decided to try gentle brute force. i turned it on and off 6 or 7 times while banging on the body beside the lens (to the left if looking at the screen) and it seems to have worked. Systems Error message has gone and i've taken 20 or so pics. i was actually looking here for a solution earlier today, so here you go guys
Posted on Dec 04, 2008
Have same camera and same help out there???
Posted on Jul 09, 2008
Hi I bought a Dyson vacuum a few months ago, of course I did not register it, and it has completely crapped out.
Check where you purchased it and ask. They do not always need the registration. You need your receipt naturally. There is usually a warranty on them. Quite often they want you to register them so they can sell you other items at a later date.
Dec 26, 2016 | Cameras
I have a radio shack auvio 40-297 sub woofer that I purchased two years ago and it has NEVER worked, I'm about to toss it away but thought I would question you first (turns on but VERY little sound)
This case (existing but very littleaudio level) is quite strange and has nothing to do with the subwoofer. Maybe the audio signal that comes out from the amplifier has a very low level. What is the amplifier you use and which output do you use? Also make sure that the "subwoofer level" setting at the back of the sub is turned fully clockwise.
At this link you can see 2 suggested solution from RadioShack. Which one do you use?
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
direct FixYa link:
Sep 17, 2011 | Audio Players & Recorders
What does F9 mean? the oven says Door when i try set the bake temp and after a few min it starts beeping and show F9?
Hello there:
The f9 error code means that you are having door lock mechanism failure or a erc (electronic range control ) problem and needs to be replaced
1st inspect the door latch and ensure that it works properly and is not loose in any way and if this does indeed work properly than you will have to replace the erc ok
Hope this helps
Feel free to rate this solution for me and if needed post me a comment any time for further assistance
Best regards Michael
Sep 22, 2010 | Amana ARGS7650SS Gas Kitchen Range
Charged the battery,and the cammera still wont turn on
Hello, Quite possibly the battery is a few years old and has lost the capacity to power the unit on,these type batteries become weak over time and the unit requires quite a bit of power to boot the camera,only solution is try a new battery that has been charged for at least 4 hours.Hope this solves your problem,the battery is very cheap on E-Bay,Battery is KLIC-5001.
Best Regards,Russell
May 16, 2010 | Kodak EasyShare DX6490 Digital Camera
Error E18 . What does this mean. Canon camera
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Aug 30, 2009 | Canon PowerShot S2 IS Digital Camera
My camera is write protected
Dear Hannahboggs9,
I am not quite sure of what is the make of your Memory card however most of the memory cards have a small switch on side that could be toggled to make it write protected. I am sending you a link with picture to make it more clear.
See the yellow slide lock on left edge of the above card...
Now if there is no lock on your card or if the above mentioned is not the problem then you might want to try formatting the card using your computer with "FAT" OR "FAT16" file system selected from the drop down (DO NOT SELECT FAT32).
If that too doesn't work then you might want to try with a different memory card.
This issue doesn't seem to be with camera.
In case any further assistance is required please write back and I would be glad to assist.
Jun 25, 2009 | Nikon COOLPIX S51 Digital Camera
When start the printer it shows E - 9,
Error code E 9 means that the connected digital camera/video camera does not support Camera Direct Printing. Have you connected any digital camera or video camera, then please check its compatibility with the printer. If it is not the case, then please reset the printer after unplugging it for 5 minutes and then re-plug it. Also, detach the cartridges and replace them again and see the results.
If the problem still persists, please do post a comment and I will reply back immediately.
So far as your other question is concerned, this is the unique service on which you can interact directly with the various Experts and it has not any call centre number. However, the experts belong to different countries including India and you can contact them only on this site.
Please do rate this solution as FixYa and revert for further assistance.
Jun 20, 2009 | Canon Office Equipment & Supplies
Says out of yellow ink but replaced wth hp cartridge
You might want to try the solution posted in this link. It appears to have worked for quite a few folks. Read through to the end before you try it...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 11, 2009 | HP Photosmart C6280 Printer
Dark Pictures
Hello Cowgirl, It sounds like the camera settings have been changed in the menu.Check to see if all control items are set to "AUTO"
This should take care of problem.The camera did not go bad not being used.
Best Regards, Russell
Dec 19, 2008 | Kodak EasyShare DX6490 Digital Camera
Put new batteries in doesn't work
I keep getting the same problem myself with particular brands of batteries, if even they are brand new.
Try using Duracell or another brand of batteries and this hopefully, should resolve the issue.
Hope that helps...Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
May 01, 2008 | Olympus FE-210 Digital Camera
Nikon Coolpix SQ Digital Camera Logo
170 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
