Question about Kenmore 24032\24036 Top Load Washer
Kenmore 90 series does not stop filling
I removed the control panel, and the pressure hose is still attached. Do I have to remove the back of the machine to make sure it's still attached to the tub or is there an easier way?
  • 5,911 Answers
You need to remove the washer exterior casing to access the wash tub where the air hose is attached to the air dome. Before you do that however, if the air hose had come off the air dome, the washer would leak as it tries to fill. This isn't a small leak either. More like a gush of water. Furthermore, you can check the air hose by adding some water to the wash tub, shutting off the washer and disconnect the air hose from the pressure switch. If you blow through the hose and can get air bubbles in the wash tub, the hose is not leaking. If you can't blow air through the hose, you may want to inspect the air hose to ensure it is not cracked or split somewhere. Just follow these steps:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
To reinstall the washer casing, follow these steps to ensure you get the case correctly placed and secure on the frame:
1. Re-install washer case. With the lid of the washer open, grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
Make sure you check the electrical connections on the pressure switch to make sure they are not corroded and are making good contact. If all these preliminary measures do not work, replace the pressure switch.
Let me know if you need any further assistance. I hope this helps you.
Posted on Sep 04, 2009
Kenmore 70 series wont stop filling with water to start the wash cycle
Lid off, right side circular pressure switch with black hose attached. Remove end of hose, blow down to make sure not blocked and blow into switch where hose attaches. Should click twice. If doesn't click, faulty pressure switch (replace)
May 19, 2012 | Washing Machines
THE WATER IS NOT STOPPING, JUST KEEPS PUTTING WATER INTO THE WASHER KENMORE 90 SERIES
There are two possible causes of the water not stopping. First is the water inlet valves stuck in the open position and second is the pressure switch not tripping when the correct water level is reached. Turn off or unplug the machine while it is filling and if the water doesn't stop, the water inlet valve/s is/are indeed stuck in the open position. Replacing the water inlet valve assembly should solve the problem.
But if the water stops, the problem is the pressure switch stuck in the empty position. Disconnect power then raise the console up and hinge it at the rear of the machine to access the pressure switch. It is the part with the small clear hose attached to it. Detach the hose and blow air down into it including the pressure switch itself. Replace the pressure switch if the problem persists.
Click on the link below for the detailed procedure in raising the console and removing the cabinet to access and replace the water inlet valve assembly.
Removing the Cabinet on a Whirlpool or Kenmore Top-Load Washing Machine
Dec 31, 2010 | Kenmore 15864/15862 Top Load Washer
Kenmore series 90 washer keeps filling with water and won't stop during to move on to next cycle
If overfills onto the floor , then the waterlevel switch hose came off the switch behind the control panel . You have to remove the 2 side screws and tilt panel to see the hose and switch . If the water keeps filling , but doesn't go on the floor , then you have a syphon problem at your drain . As it fills , water is being sucked out by your drain due to no air able to get in around the drainhose and drainpipe . Pull drain hose out of drain and only insert about 4-5 inches into drain . If hose is tightly in drain , a parts house or home depot should have a syphon break in stock .
Jul 22, 2009 | Kenmore 22422 Top Load Washer
Kenmore 90 series won't stop filling with water
A common cause to the constant fill problem is the air dome hose coming loose from the pressure switch. The following link explains:
http://www.fixya.com/support/r762094-washer_overflows
It is common for the hose to come loose and fall off the pressure switch from vibration and from becoming stretched. Without this hose attached, the pressure switch cannot detect the change in pressure from the wash tub as the washer fills. The result is a washer that continues to fill to the point of overflowing. If the hose IS attached, check the entire length of the hose for leaks. Also, double check the electrical connections to the pressure switch to ensure good contact. All these steps will assist you in determining if you have a bad pressure switch, or a problem that requires no parts. Please read through the rest of the link and let me know if you still require assistance. I hope this helps you.
May 27, 2009 | Washing Machines
Kenmore serie 80.does not stop filling water in and does not star
Yeah I've seen that happen a many of times. Take the back of the control panel off and where your load size selector is you'll find a little hose that's suppoed to be attached to the side of it. just reattach it and you'll be back up and running.
Almost all washing machines use a pressure tube that tells the washer when to stop filling with water. If the tube comes off for some reason the washer will never stop filling and that's an instant flood if you don't notice it quick enough. Also a hole or puncture of any kind can be causing ti to never stop filling as well.
Hope this helps
Jason
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
Water keeps flowing non-stop with my old Kenmore washer
Check the pressure switch and the pressure switch hose.
Remove the end caps on the console and remove the 2 screws that hold it down. Pull slightly from the bottom of the console and flip it up. On the left side you should see the pressure switch (water level switch) with a few wires and a small hose connected to it. The hose should be connected between the pressure switch and the tub. In most cases the pressure switch hose sometimes falls off over time due to vibration.
Replace the hose if it is damaged. If there are no visible holes or cracks in the hose, try trimming 1/4" off each end of the hose (pressure switch side and tub side) and reconnect them making sure to push hose ends securely onto connections. This is done because the hose sometimes stretches at the connection points and you will lose air pressure inside the switch, therefore the water will never shut off.
Alternatively you can use small clamps on each end.
If this doesn't work, check the function of the pressure switch by attaching a small hose to it and blowing lightly into the pressure switch while the machine is filling. You should hear a click and the inlet water valve should turn off. If it doesn't turn off you may need to replace the pressure switch or if the machine fills even when it's in the off position replace the inlet water valve.
Mar 03, 2009 | Kenmore 22422 Top Load Washer
Kenmore 90 series washing machine
Check your pressure switch.
First of all, unplug your washer. You will need to remove the console in order to get to the pressure switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. And, still there are some of the older models that have screws holding the console in place from the back. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place.
The pressure switch will be located behind the load level selector knob. Make sure the air hose is still attached. Often, this hose comes loose and falls off. This will prevent the lid switch from sensing the pressure from the wash tub as the water fills. The result: washer fills continuously until it overflows. Looks like a major problem, when its not. Reattach the hose. To keep the hose form sliding off again, you can take a small zip-tie and place it snugly around the hose where it connects to the pressure switch. This will create enough resistance to prevent the hose from falling off in the future. CAUTION: DO NOT over-tighten the zip tie as you can crack or damage the pressure switch. Just enough to make it snug.
If the air hose is still attached, check the electrical connections to ensure the connector plug is making contact and/or not corroded. If everything checks out, replace the pressure switch. If need further assistance, please post back and let me know.
May 26, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series Model 110.20862990 Type 111
no the timer doesn't control the water fill the pressure switch does you have three possibility's either the pressure switch is malfunctioning or a water valve is hanging open or the pressure switch pressure hose is leaking or off the tub the pressure switch is connected to the knob that lets you select the water level in the tub if you back out the two screws on the front or back of the end caps depending on the model you can pull the control panel forward and tilt it back to access the pressure switch its gold in color and has a clear latex hose attached to it also take the hose loose and blow through it to make sure its clear with the washer empty of course lol if you need more info just reply to me be glad to help water can also leak out from the pressure switch hose if a mouse has chewed through it or its come loose from the tub
Mar 18, 2008 | Kenmore 24902 Top Load Washer
Washer won't stop filling with water.
slick, first see if the hose came off the pressure switch. Just grab the end caps on each end of the control panel and pull them off, they snap on. Remove the two consol screws, pull foward and flip the consol up. See if the hose came off. If it did, just put it back on and use a zip tie to secure it. See attached photo. Catriver...post back.
Mar 18, 2007 | Kenmore 22642 Top Load Washer
Kenmore Series 80 won't stop filling.
Kenmore washers
Fill switch
pull off fill knob
remove plastic trims from front face ends of control panel exposing screws
remove phillips head screws from bottom
slide control panel forward & up ~1inch then flip over backwards on top hinges
to remove fill switch
depress lock tab right side where switch body touches back of control plate
rotate counter clockwishe 45-90 deg
withdraw fill switch
remove plastic tube from switch body
Blow any water out, should be empty when washer is empty messes up pressure sensing
refit plastic tube
adjustment screw is 1/8" hex head bolt next to knob shaft
clockwise raise water level
counter clockwise lower water level
can be operated in this open position to check operation, may have to move switch between fill positions to restart fill operation
Nov 27, 2006 | Kenmore 15864/15862 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
195 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
