Question about Samsung HCM4216W 42" Rear Projection Television
SAMSUNG HCM4216W has a verical line
I have a samsung hcm4216w I have taken in twice to get the convergence fixed. The last time the power wouldn't turn on so I took it in to get fixed now there is a vertical line that runs about 1/2 of the screen. The repair guy said it was the red picture tube and wants another $400 to fix. any suggestions
  • rorymolnar Dec 28, 2007
    Thanks Cycus any idea of what that would cost to fix?
  • tandacarlson Jan 16, 2008
    I have the exact same tv. Just replaced the convergence board now i have a pink vertical line in the middle of my picture.
    Sergeant:
    Champion:
  • 346 Answers
The vertical line has nothing to do with the picture tube,Some component in the horizontal circuit is causing that problem,most likely an electrolytic capacitor
Posted on Dec 27, 2007
  • cyriacus joseph Dec 29, 2007
    total cost could be somewhere around $250
Samsung hcm4216W turned off by itself loops.
Instead of typing model number of your TV (that located on right hand side and on the back of TV) you published here part number of your TV's remote control. LOL.
Anyway... If it is LCD/plasma panel that you talking about - than power supply have bad electrolytic capacitors that have to be replaced. You can recognize 'em by bulged/swollen tops (instead of flat tops of good capacitors).
This repair required soldering skills.
Mar 09, 2010 | Samsung HCM4216W 42" Rear Projection...
Samsung HCM4216W 42 in. Rear Projection Television Not turning on. After opening the back, found out that two resistors (RR402S and RR471S) are very badly burnt. Could that be the problem? I took the...
Sounds like your convergence circuits shorted and took out the resistors. This is fairly common.
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 19, 2010 | Samsung HCM4216W 42" Rear Projection...
Red and Blue convergence issues cause triple-image
This sounds like your convergence chip is bad. If you are good at soldering you can order the replacement kit from www.tvrepairkits.com and do it yourself.
Apr 17, 2009 | Samsung HCM4216W 42" Rear Projection...
Red blinking light
It's most likely convergence -- the small board up and to the right inside the back of the TV, which has two large amp Ic's attached to it..
Unplug the +/- 20v line on the fron left corner of that board (red in color) and then try and power on the set... If the set comes on the board needs to be repaired and it's an easy unplug and two screws that mount it inside.
Bill
Premium Technologies
PO Box 442
LOng Beach, WA. 98631
360-641-4993
premtech@willapabay.org
Apr 18, 2008 | Samsung HCM4216W 42" Rear Projection...
Samsung hcm4216w
The most common problem for those symptoms are convergence amps. That unit takes two stk392-040 Sanyo Ics and will most likely require that several low ohm resistors (3.9 ohm-2w) be tested and possibly replaced.. There is one last thing also, a pico fuse at Fd102 (3.5a) that sometimes opens and would need to be replaced..
The convergence board in these is easily removed, so an in-house service call could be done...
Hope this helps
Jan 09, 2008 | Samsung HCM4216W 42" Rear Projection...
HCM4216W
most convergence problems if they can't be adjusted come from chips called stks.. if they go out they have to be replaced. DId you get any result.s does the colors adjust at all?
Dec 06, 2007 | Samsung HCM4216W 42" Rear Projection...
HCM4216W Convergence Problem
the convergence problem you had before, re- occured
Sep 25, 2007 | Samsung HCM4216W 42" Rear Projection...
Blue and Yellow doubles
Well, fortunately the television that you purchased has an auto-convergence feature. What is happenning is that your color lamps are misaligned, did it get moved at all recently? Anyway, in your menu you should see a "Convergence" menu, and inside that menu, a section called "Perfect Focus". Run Perfect Focus in this sequence: Green --> Red --> Blue After that your picture should look great, if not try tinkering with the manual adjustments on the "Convergence" menu. Here are some URLs that you might find helpful: (just copy+paste into your browser) Your Television On Samsung's Webstire: http://www.samsung.com/Products/TV/ArchivedTelevisions_2002/HCM4216WXXAA.asp Your Television's User Manual (Download And Open With Adobe PDF Reader) (The "Convergence" Menu Is Section 3.3) http://www.usersmanualguide.com/samsung/tv__projection/hcm4216w
Apr 29, 2007 | Samsung HCM4216W 42" Rear Projection...
Samsung HCM4216W Power Problem
Vern,
Hope this helps!
Bill
Mar 05, 2007 | Samsung HCM4216W 42" Rear Projection...
Samsung HCM4216W 42" Rear Projection Television Logo
60 people viewed this question
Jerry Greenberg
Jerry Greenberg
