Question about Dell 922 All-In-One InkJet Printer
Printer says left ink cartridge incorrect.
I double checked to make sure that is right. it a brand new cartidge. what do i do to fix the problem?
Hey it is your cartridge that is bad try and change it to another one that using another cartridge of the same type try this first if it persist go and give it to the specialist.
Posted on Sep 04, 2009
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
Left ink cartridge incorrect. It is the right ink
A trick which may work is cleaning the contacts on both the cartridge and the printer.
Make sure you've switched it off first, I'd try gently buffing with a soft dry cloth first.
HP reccommend using distilled water and cotton buds, but not alcohol based cleaning fluids.
Allow the water to evaporate before replacing cartridge and switching on.
May 11, 2010 | Dell 946 All-In-One InkJet Printer
Won't accept color cartridge
Is this a manufacturer cartridge or a knockoff? Knockoff cartridges can for sure cause that message. If it is a new one, it is possible it may be the wrong one. Check your manual. If this is also not the problem, then your printer has an internal problem and needs repair. Hope this helps. Cheers.
Oct 06, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X4530 Incorrect Cartridges.
By any chance did you get these cartridges refilled? If so then you may be out of luck as I read that Lexmark chip their cartridges/printers to reject refilled cartridges. I have the same problem at the moment just with the right (colur) cartridge. The cartridge is an original refillable Lexmark (i.e. grey box) I got the cartridge refilled twice and it worked fine, but the third time no joy. Research indicate that Lexmark program their printers to reject cartridges refilled 3 times!!
Jul 07, 2009 | Lexmark X4530 InkJet Printer
Ink cartridge stuck on left side in cradle and will not release
Take the cradle out of the printer, using a flat blade screwdriver prise up on the left corner of the toner cartridge and pull toner cartridge from the right hand side.
the problem is cause when the toner cartridge in install incorrectly, inserting at an angle to the leftside first and so the toner trap door does not rotate.
The correct way, is to place the cartidge on the cradle and press from the centre down on the toner body.
May 27, 2009 | Kyocera FS-2000D Laser Printer
I have put in new cyan ink cartridge but printer does not recog
are you sure you got the right ink cartidge put in? Also check if you took that piece of plastic that coverred your ink cartridge contact
Mar 20, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Left Cartidge incorrect
Hi, remvoe the black ink cartridge , dip the cartridge in luke warm water for 30 secs , clean the cartridge and unplug the power adapter from the printer , wait for a minute and then reconnect it back , put back the cartridge and then look for the error msg , if it stil displays the same error then its an issue with the cartridge and needs to be replaced..
Do lemme know if it helps..
Thanks
Jul 08, 2008 | Dell 922 All-In-One InkJet Printer
Dell 924 printer problem with black cartridge
Dell printers donnot seem to work on refilled cartridges. Do buy new cartridges to fix the issue
Apr 08, 2008 | Dell 924 All-in-One InkJet Printer
Solve this
I could be mistaken but I am pretty sure the right cartridge should be the black one. I would double check it. Also make sure you are using Dell brand cartridges.
Aug 03, 2007 | Dell 924 All-in-One InkJet Printer
Dell 922 All-In-One InkJet Printer Logo
154 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
