Wont work on heat - Heating & Cooling
  • 534 Answers
Three thing could be wrong. First the easiest. Check thermostat for fresh batteries. inspect to see if the thermostat setting inside the thermostat, a switch, is set for the correct medium you are using i.e. electric, or gas. If those are correct then the second thig to check for is to see if the heating element is in good shape (this is only for electric heaters) disconnect on side of the electrical on the element and check for continuity using an electric meter set to ohms If you get a signal then your heating element is good. That leaves you with a hi-limit switch This switch is a safety device installed to prevent the heater from getting too hot and cause a fire. These switches look like a silver button and are mounted towards the heating elements. Hard to test one so if all others are working or check good then I would have the hi-limit switches replaced.
If this is a gas operated furnace then there could be a couple thisng. First the thermocouple could be bad. This is the small shaft you see sticking into the pilot light. Easy to replace following instructions. Secondly, Gas valve could be bad. No way to test without special tools and equipment. Gas pressure supply to the valve again hard to test without special tools. Good luck hope this helped
Dave
Posted on Sep 04, 2009
The heating wont work unless the heating is on, is this a reprogramming, a repair or replacement job please
Re-read your post. Does it make sense to you? "The heating wont work unless the heating is on" !! If this is about Cars & Trucks, submit a new question, proofread it, and include the year, make and model of your vehicle.
Jan 31, 2017 | Cars & Trucks
Heat pump compressor wont come on in heat mode, works fine in cool mode, we get heat occaisionally for about 2 min, then the compressor shuts off. it is a fridgedaire window unit.
Try setting the thermostat at a normal heat setting. By raising the temperature too high the unit thinks that the heat pump won't be effective and go into strip heat mode.
Nov 17, 2013 | Frigidaire Energy Star Room Air...
Tumble dryer wont dry clothes reset button doesnt work
Check the Circuit Breaker. It is a double Breaker Switch. one side is for the heat one for the motor. If that is good then it's possibly the Heating Element or one of the two heat sensors.
Jan 17, 2013 | Dryers
Heater not heating well car
chk your coolant level. If it is low your heat wont work very well if really low it wont work at all. You could still have enough to not over heat and still be low.
Oct 29, 2012 | 2000 Volkswagen Beetle
2000 Silhouette: HEATER WONT GIVE OFF HEAT THEIR IS HEAT BUT WONT S...
Check the water level. If the water is low it will not allow water into the heater core to produce heat. If there is water keep an eye on your temperature gauge It should reach at least 140 to 170 degrees. If it is staying colder than that you have a stuck thermostat which is allowing the water to flow to much and not let the engine warm up. The only other solution is if the fan is not working properly replace the fan relay for you blower.
May 17, 2010 | 2000 Oldsmobile Silhouette
1998 S10 heat wont work sometimes
When you say the heat doesn't work are you meaning the fan doesn't blow out hot air or just doesn't blow out any air? if it blows cold air sometimes when you have the heat on then it could be poor circulation through your radiator or a weak water pump. make sure your radiator is clean on the inside, not too corroded or nasty inside. You can buy a radiator flush thing from wal-mart or any auto parts store. See if it helps.
Mar 01, 2009 | 1998 Chevrolet S-10 Pickup
Kenmore heavy duty clothes dryer will not heat
REMOVE THE BACK AND CHECK THE HEATER FUSE AND THE HEATING ELEMENT-MIKE
Feb 25, 2009 | Kenmore Dryers
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
