Question about Singer Sewing Machines
The needle is hitting the throat plate. I have a singer 2517, how can I solve this problem? HELP!!!
  • 5,603 Answers
The needle POSSIBLY isn't seated properly or is bent. Most of the needles have a flat side that must be registered in the corresponding grove where it attaches. This can be a bit tricky to get it seated just right AND fully up into place.
Posted on Sep 04, 2009
My needle is hitting the plate when I try to make a buttonhole
Sue: According to http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CCAQFjAA&url=http%3A%2F%2Fwww.consew.com%2FFiles%2F112347%2FInstructionManuals%2FCN2230R.pdf&ei=ZGtVVaa7OYKRyQTGo4GoBA&usg=AFQjCNG-1xhxBFtfhJZJn7y5QZ_0E1r48w&bvm=bv.93564037,d.aWw : "The Throat Plate is not held firmly in place. Its screws are not tightened securely. The Throat Plate shifts around and is being hit by the Needle. Solution: Locate the Throat Plate correctly and tighten firmly the throat plate screws."
May 14, 2015 | Sewing Machines
Singer CG500 Needle hits the needle plate. Needle was replaced. Verified needle in correctly. Tried hand wheel - still hits. Machine has yet to be used!!
Unless you need all the bells and whistles to sew get you a pre-1930 treadle or handcrank. I have 2 electric Singers, 1947 model 66 and 1948 201-2 both with attachments. Also I have 1903 Singer handcrank made in Scotland. The plastic new one just don't have the ability to hang in there .... All my pre 1930 Singers sew... I love them!
Apr 17, 2014 | Singer CG500 Mechanical Sewing Machine
Please help my throat plate[needle plate] is banging loudly..the faster I sew the louder it knocks[throat plate against its base]..it's as if its too loose but see nowhere to tighten or screw it in...
I would like to help you but I do not know what model your machine is. Please answer this and I will try to help you. Knocking is usually lint built up under the throat plate and has to be removed to get it cleaned out.
Apr 18, 2011 | Singer Sewing Machines
I have a singer 14sh654 serger. Having trouble with the left needle thread tension disc, it seems to be stuck. Even when it is at 0 and presser foot up there is still too much tension on the thread. ...
Try cleaning the tension discs with a thicker piece of the thread knotted 3 or 4 times and running it back & forth through the discs because there could be lint stuck in there. You should do this at least once a month, alot of threads leave lint behind. Also, check your diffential, put it to neutral. If, that does not help, take it in for service before something breaks off.
Mar 17, 2011 | Singer 14SH654
I have a Singer 2517. The needle hits the plate, just misses the hole to connect with bobbin thread. Is there a fix?
Is your needle inserted all the way? Sometimes it is the simple things that are the problem. Do you have your manual? There is a site online singerco.com that will let you download it for free.
Jul 23, 2010 | Singer 2517 Mechanical Sewing Machine
The needle hits the throat plate
if a new needle still wont align with the needle plate, your needle bar is out of whack
Mar 18, 2009 | Brother CS6000i Computerized Sewing...
How do I adjust the timing on my SINGER CG590C
If you have a zig-zag machine check to see if the needle is set to the correct position. If you are trying to zig-zag, be sure you have the wide holed throat plate on.
Jan 27, 2009 | Sewing Machines
Singer 6038 needle issues
That sounds like the needle is not in straight or is bent.
Oct 13, 2008 | Singer 6038 Mechanical Sewing Machine
Sewing Machines Logo
102 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
