Question about HP Color LaserJet 2600n Printer
My printer is printing yellow only
I have tried from cleaning, restoring and my printer is printing yellow only. What should i do?
    Problem Solver:
  • 9 Answers
Hi, i think the other ink is finished in your printer cartage. i also have the same problem and then i buy a ink refil kit and then fill the cartage with blue and mergenta colour and then it working fine. I suggest while filling the cartage please don't remove the slip, just fill it using injection.
Posted on Sep 04, 2009
5 Suggested Answers
jassimkv1
  • 165 Answers
SOURCE: Printer won't print yellow and blue.
Please Buy original hp printing catridge from an authirised dealer of hp.
Posted on Oct 26, 2009
SOURCE: Not Printing Cannot do Automatic Print Alignment
We should buy Epsons !
Posted on Dec 09, 2007
SOURCE: My Brother MFC 210 C printer will not print in yellow.
i cannot print the documents that i want ,,the printer cannot recieved the documents but it can copy.
Posted on Jun 25, 2009
sgoswami
  • 114 Answers
SOURCE: HP 6000 Won't print with yellow cartridge
Try this :
Take out the power cable from the back of the printer keep on tapping the power button for 30 secs ; then plug it back.
Take out the catridges clean them with a Lint free cloth (copper contacts); also clean the catridge slot of the printer; put in back the catridges ;
Unplug the power cable from the back of the printer; press and hol down the (#) and the (6) button simultaneously with one hand and with the other hand put in back the power cable; and then release the (#) and (6) button;
It will perform a reset on the printer
IF still then it doesn't work then the catridge slot's copper contacts has gone bad and need to replace
Regards
Soumajit
Posted on Mar 12, 2010
Why does yellow not print on oki c5200?
The fountain under the yellow cartridge could be dried and clogged (assuming the cartridge is not dried up from too infrequent use and is not empty. If you stuff all around the fountain with rags and then gently force water into the fountain using a syringe you might be able to clear the ink passageway and restore yellow in the machine. Servicing the other fountains might be in order, too, since one clog is likely to be followed by others. Remember to use the printer more often to prevent such cloggingg. Also, you could try the built-in printer head clean function before trying the manual cleaning; but, generally, when it gets to the point of zero ink delivery, it's already to late to clear the ink clog with fresh ink, which is what the self clean feature does to try to dissolve the clog and restore ink flow to the fountain.
Aug 19, 2014 | OKI C5200n Laser Printer
Yellow ink will not print
You may have blocked yellow print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the printthen a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase anew printer.
The Print head will contain all the nozzels for all the different colors so you cannot just replace a single color print head nozzels.
May 22, 2012 | Canon Office Equipment & Supplies
Hi . My G85 fails to print yellow. Other colours ok. Tried 3 colour cartridges. All same. Suggestions please.
Hi!
Clean the cartridge and carriage electrical contacts with a cotton swab moistened with water. If this fails to restore the yellow, replace the color cartridge. If you believe the cartridge is good test it in any Deskjet 900 series printer.
Thanks
Apr 21, 2010 | HP OfficeJet G85 All-In-One InkJet Printer
I have a Brother mfc-240c - will not print yellow
The print head is clogged.If not unclogging with cleaning process may you try to clean manualy.You need to dissasembly the hole printer to remove the print head.Put it in hot water.If you don't have a technical skills, don't try anything.
If not help just buy new printer, because the new print head will cost you as much more.
Nov 06, 2009 | Brother MFC 240C All-In-One InkJet Printer
I recently installed new black ink cartridge. Since doing so, the colors on anything printed are incorrect. For instance, anything red prints as pink. Anything deep yellow prints as a gold. MY...
Hi maryryherd - yes the C64 is in the list - don't know why you couldn't see it.
The inkjet colour system can be quite confusing. The colours in the cartridges are cyan, magenta and yellow, plus black. Other colours require a mixture of these basic ones. For example, to produce "red" requires a mixture of magenta and yellow. Your problem sounds like you are getting insufficient yellow, and maybe insufficient black.
Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Are all the 3 colour bands plus black printed OK. If not, try up to three cleaning cycles. If ink is now flowing pretty well, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print. If these actions produce no positive results, report back with a new comment.
Apr 18, 2009 | Epson Stylus C86 InkJet Printer
C84 Wont print red
The printer colour cartridges are magenta, cyan and yellow. The printer prints "red" by mixing magenta and yellow ink. So, if you only get yellow when you print red, it means you aren't getting any magenta ink on the paper.
Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of magenta ink on the paper. Try up to three cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print.
If you have already done lots of head cleans with no result, are you sure you have a good magenta ink cartridge? To eliminate the possibility of a faulty cartridge, buy a new set of compatibles on E-Bay - they're very cheap. You can always re-use the old one later if it turns out it is OK.
If none of the above works, then you may have blocked magenta print head nozzles. You can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid
comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any magenta ink on the nozzle check, then there is hope! Repeat the process until you get a full magenta nozzle check. If nothing, repeat the process once more.
If still nothing, post a new comment detailing what you have done and the results.
Apr 05, 2009 | Epson Stylus C84 InkJet Printer
PIXMA ip3000 printer is printing yellow instead of red
Clean the ink cartridge contacts with a moist tissue or glass/LCD cleaner clothe. Do the same on the printer cartridge holders. Do this gently and carefully avoiding further damages to your printer and it's cartridges.
Declog print heads using denatured alcohol for an hour or two or head cleaning agents available at any ink refilling stations. You can use a suction device included in the refill kit.
Try using another cartridge of the same type by borrowing from a friend, relative or member of the family and see if the problem still occurs.
Try removing the printer driver, restart computer then reinstall driver so that the default settings will be restored. If it still exist, you can google for iptool software and try resetting it's EPROM.
If the problem still exists, you need to go to the nearest service center.
Dec 19, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Lexmark X1100 printer will not print black
I came up with a work around for printing black.
I changed the black cartridge with the color cartridge.
Then when I have a letter to print, I change change (or write) the letter text to yellow, red or blue.
Then I can print out a letter.
By printing the text as yellow, red or blue the cartridge will try to print with only 1 color, but will print out black.
If you do not use one of these primary printing colors the out put will be unusable.
I can not of course print out pictures.
Oct 04, 2008 | Office Equipment & Supplies
Will not print at all
You can try restoring the printer to factory settings..and try agian it has worked most of the times for me..Let the catridge be in the printer when you do this..
Oct 27, 2007 | HP DeskJet 960c InkJet Printer
HP Color LaserJet 2600n Printer Logo
2,006 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
