Question about Sony Ericsson XPERIA X1 Smartphone
My sony experia x1 won't turn on. the device hang, so i remove the bettery, but when i tried to turn it on, it wont. batteries are good. just got it with in a month.
My fone wont turn on after i took out the battery becos of sand in the case? PLEASE SUM1 TELL ME HOW TO FIX IT :( xx
Posted on Aug 05, 2010
  • 22 Answers
Clear the sand with gentle cloth
Posted on Mar 27, 2011
Sony experia mt27i hangs
download firmware&drivers fastboot& flashboot
download flashtool for xperia
In program choose unlock bootloader
last flash your firmware
(fastboot vol up+power blue ligth)
(flashboot vol down+power green ligth)
Jan 17, 2013 | Sony Mobile Phone XPERIA Sola MT27i White
Tip
Sony Ericsson Experia X1: How to Reset
We can't deny the fact that our cellphones mess up sometimes. That's the truth about the machines, we cannot let them take any medicine so that they'll be fine. However, there some ways on how to make them work again. One of these ways is what we call as reset.
Your phone will come back to its factory settings once you reset it. This is the last thing that you want to do anyway with your phone because this tweak will erase all the files and software that you added in your phone. In other words, it will clean up the whole phone. It is really advisable that you back up your important files like pictures, videos, messages, etc that you have saved in your phone. You can back up your files by using a memory card or any other external devices.
There are two ways on how you can reset your Sony Ericsson Experia X1 phone to its factory settings.
1. Soft Reset
Start>Settings>System>Clear Storage then enter the number 1234 and press Yes.
2. Hard Reset
While the phone is off -hold down the front left and right buttons on the X1 and insert your stylus into the soft reset hole all at the same time.
(Back of the phone)
(Stylus pen on the soft hole)
(Location of the Hole)
After following the procedure, a blue screen will appear which will ask you to press R to reset and delete all your existing files. Just press R. Then, you will then follow the on screen instructions like stylus calibrating. It's like having your Sony Ericsson Experia X1 the first time.
on Jan 27, 2011 | Cell Phones
My experia no carging
Dear:
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Dec 15, 2012 | Sony Ericsson XPERIA X8 Cell Phone
I have the Sony S2 Sports ZS X1 and it will not turn on.
Before confirm transformer fault, load batteries and see whether it works. After loading batteries, pull out its AC cord from its AC socket at it back side. With AC cord connected at the back of the set, battery supply won't connected to the set. There is a cut - off switch at the AC socket. Only after removing the AC cord, the set will work on battery.
Try this. If it works with battery, make sure that transformer or internal mains fuse has blown out.
May 29, 2012 | Sony S2 Sports ZS-X1 Radio/CD Boombox
HOW CAN I DOWNLOAD ANDROID ON MY EXPERIA X1
Here are the instructions
http://www.addictivetips.com/mobile/install-android-2-2-froyo-cm6-rom-on-sony-ericsson-xperia-x1/
Apr 29, 2011 | Sony Ericsson XPERIA X1 Smartphone
I m sending sms from my sony ericsson xperia X1 but it can't be sent because the pop-up windows appears & shows message sending failed? Is this a softwares problem ?
sounds more like a sms settings problem, try checking the service center number is correct for your sms. or you could contact your network provider and get them to send you the settings for it. hope this helps
Mar 29, 2011 | Sony Ericsson XPERIA X1 Smartphone
My sonyericsson Experia X10 not charging
first of all connect your adaptor to the phone,remove the battery and check the battery terminal voltage. If voltage is absent check adaptor voltage at the pin.If no voltage change the adaptor.However if the voltage is presrnt,test voltage of the battery.If below marked level replace battery.if not ,clean battery contact and place into the slot.If after full charge the battery wont last then replace battery.
Sep 28, 2010 | Sony Ericsson XPERIA X1 Smartphone
My experia x1 dont want to come on its new no more than a month
There could be lot reasons for this. Send your phone for repair at Dr. Cell Phone. They repair almost all cell phones.
Dec 11, 2009 | Sony Ericsson XPERIA X1 Smartphone
Please I want to change the Language opreating system of my sony experia X1 from Spanish to English . Thanks
Hello.
You need to flash another ROM into your phone.
You can also install a modded ROM that will add more features to your phone.
If you're not confident flashing your phone (YOU CAN actually BRICK it), you're better taking it to a repair shop.
http://forum.xda-developers.com/showthread.php?t=397515 <-- A good modded flash.
Greetings.
Jul 31, 2009 | Sony Ericsson XPERIA X1 Smartphone
Sony Ericsson XPERIA X1 Smartphone Logo
1,828 people viewed this question
Top Sony Ericsson Computers & Internet Experts
sandrasteven
David Payne
David Payne
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
