Question about O2 Xda Zinc Cellular Phone
I can't log on to windows... - O2 Xda Zinc Cellular Phone
Boot log 1525
venkatachalam,
How to Enable Boot Logging in Windows By Dan Gookin from Troubleshooting Your PC For Dummies, 3rd Edition
Two event log files that come in handy for troubleshooting your PC are the boot log files. These files are created when you specify boot logging as a start-up option. The files are named either ntbtlog.txt or bootlog.txt, depending on how old your PC is. These files, found in the Windows folder, list the success or failure of various pieces of Windows as it's loaded into memory from the PC's mass storage system.
You can enable or disable boot logging by using the MSCONFIG utility. Follow these steps in Windows 7 and Windows Vista:
  1. Press Win+R to summon the Run dialog box.
  2. Type msconfig and press Enter.
  3. In Windows Vista, type the administrator's password or click the Continue button.
  4. Click the Boot tab.
  5. Place a check mark by the item Boot Log.
  6. Click OK.
  7. Click the Restart button to restart now. Otherwise, click Exit without Restart.
    The logging doesn't take effect until you restart Windows, and you have no reason to do so immediately unless you really want to see the boot log.
In Windows XP, you can enable boot logging by pressing the F8 key when Windows first starts and choose the item Enable Boot Logging.
The boot log is overwritten every time you start Windows. And, the log is produced only when you turn on the boot logging option.
What can you do with the boot log? You can check for the failed installation of certain pieces of Windows or device drivers. The drivers or files are obviously flagged in the log. Because you know the filename, you can then either disable it from loading or look for an update.
  • Activating the boot log in Windows 7 or Windows Vista means that you configured your PC for a custom start-up. If that bothers you, disable the boot log after you cull whatever useful information you need from the boot log file; repeat the steps used to enable boot logging, but in Step 5, remove the check mark.
  • Traditionally, computer logs are all text files. They may have the filename extension log, or they may use txt instead.
  • You can search for log files by using the Windows Search command. Simply look for files named *log* anywhere on the hard drive, including system, hidden, and non-indexed locations.
  • Most log files are in plain text, but the text may be organized by using the XML, or Extensible Markup Language. XML is merely a way to organize information, and although XML files are readable as text, to get the most from the information, you should use an XML reader, such as the Event Viewer program.
  • If you find the file boot.ini on your Windows XP computer, you can enable boot logging by modifying the file. Open it in Notepad and look for the line that contains this text:
    Windows="Windows XP (That's only a portion of the line; in the file, it's longer). Add the text /bootlog to the end of the line. Save the file. When you restart Windows, boot logging takes place automatically.
Thank You,Dell-Jesse LDell Social Media and Communities
Aug 19, 2013 | Dell Inspiron M5030 Laptop
Tip
How to disable Notification Area Balloon Tips in Windows Vista: Click...
  • Click Start, Run and type Regedit.exe
  • Navigate to the following subkey:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced
  • Create a new REG_DWORD (32 bit) value, and then name it EnableBalloonTips
  • Double-click EnableBalloonTips, and then give it a value of 0
  • Close Regedit.exe
  • Log off Windows, and then log back on.
This method applies to Windows XP as well
Using Group Policy Editor Settings:
  • Click Start and type GPEDIT.MSC
  • Accept the User Account Control prompt
  • Navigate to the following branch:
User Configuration \ Administrative Templates \ Start Menu and Taskbar
  • Double-click Turn off all balloon notifications and set it to Enabled
  • Close Group Policy Editor
Here is the corresponding registry value for the above setting:
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer]
"TaskbarNoNotification"=dword:00000001
on May 25, 2008 | Microsoft Windows Vista Home Premium with...
How to log onto windows 8
Power on your machine, let it log onto your Windows User, when you bought or upgraded your Windows to Windows 8, you were asked to create a Windows User Account, default would of been a Windows 8 Microsoft Log in like your Microsoft Log in, asd123@hotmail.com or @live.com or @live.ie and so one.
Try log on using your Microsoft Password.
If you clicked Local Account, then this account does not need a password, you can bypass the step.
I hope I answered your question.
Aug 11, 2013 | Computers & Internet
INSPIRON 1545 WON'T LOG IN MESSGE READS 'THE GROUP POLICY CLIENT SERVICE FAILED THE LOG ON ACCESS IS DENIED' RUNNING WINDOWS 7 HOME PREMIUM
Are you able to get to the desktop in safe mode?
Repeatedly press F8 on startup and choose to boot to safe mode in the options window.
Mar 28, 2012 | Dell Inspiron 1545
Ardamax keylogger
Ardamax Keylogger is a keystroke recorder that captures user's activity and saves it to an encrypted log file. The log file can be viewed with the powerful Log Viewer. Use this tool to find out what is happening on your computer while you are away, maintain a backup of your typed data automatically or use it to monitor your kids. Also you can use it as a monitoring device for detecting unauthorised access. Logs can be automatically sent to your e-mail address, access to the keylogger is password protected. Besides, Ardamax Keylogger logs information about the Internet addresses the user has visited.
Keylogger Features:
* Email log delivery - keylogger can send you recorded logs through e-mail delivery at set times - perfect for remote monitoring!
* FTP delivery - Ardamax Keylogger can upload recorded logs through FTP delivery.
* Network delivery - sends recorded logs through via LAN.
* Clipboard logging - capture all text copied to the Windows Clipboard.
* Invisible mode makes it absolutely invisible to anyone. Ardamax Keylogger is not visible in the task bar, system tray, Windows 2000/XP/2003/Vista/Windows 7 Task Manager, process viewers (Process Explorer, WinTasks etc.), Start Menu and Windows Startup list.
* Visual surveillance - periodically makes screenshots and stores the compressed images to log.
* Chat monitoring - Ardamax Keylogger is designed to record and monitor both sides of a conversation in following chats:
o AIM
o Windows Live Messenger 2011
o ICQ 7
o Skype 4
o Yahoo Messenger 10
o Google Talk
o Miranda
o QiP 2010
* Security - allows you to protect program settings, Hidden Mode and Log file.
* Application monitoring - keylogger will record the application that was in use that received the keystroke!
* Time/Date tracking - it allows you to pinpoint the exact time a window received a keystroke!
* Powerful Log Viewer - you can view and save the log as a HTML page or plain text with keylogger Log Viewer.
* Small size - Ardamax Keylogger is several times smaller than other programs with the same features. It has no additional modules and libraries, so its size is smaller and the performance is higher.
* Ardamax Keylogger fully supports Unicode characters which makes it possible to record keystrokes that include characters from Japanese, Chinese, Arabic and many other character sets.
* It records every keystroke. Captures passwords and all other invisible text.
Mar 22, 2011 | Computers & Internet
Imtryinig to log off so someone else can log in
Hi there...
If you use Microsoft Windows based computer, logging off is very easy..
1. Go to Start menu (Its a button saying ' Start ' on it. And it locates Most commonly at lower left of screen) and click it.
On Clicking, it will pop open showing contents of start menu
You may have start menu look like one of these.. (Assuming that you uses Windows OS)
2. Follow either A / B / C option corresponding to your start menu appearance. If Your Start Menu Looks like Option_A, then follow its instructions. So do others
Option _ A
Click On button ' Log Off '
Then Choose " Log Off " button to Log off from system
Option _ B
Click On Small arrow next to Lock Symbol . It will show a menu containing many options including " Log Off".
Then Choose "Log Off" to Log off from system
Option _ C
Click on "Shut Down ...". This will open new window showing many options. On Drop menu (Looks like a text area and it will have a down pointed arrow or triangle) choose "Log Off".
Click on Ok Button will Log you off the system
Mar 12, 2011 | Computers & Internet
Lost my administrator password, how do i remove it? i now have only bio scan access.
are you using windows XP if you are log into safe mode tap f8 upon powering the system till you get windows advance menu select safemode, in safemode log in try logging in as admiistrator leave password field blank if it logs in go to control panel and click user accounts change or manage user accounts select you log in with the lost password change the password or better remove the password then restart system log in using the user name u normaly use if it log directly that is good then ccreat a new password under that account profile ^_^ this should work but for vist and win7 it might be imoissuble to log into an administrator account you must at least know the password if you created one if not then reinstalling vista and win7 is the final option ^_^
Jun 05, 2010 | Alienware PC Systems Alienware M17...
My Mini 1035NR, cant get passed the windows log on
format the Hard drive and re-install windows on it.
*MAKE SURE YOU HAVE YOUR WINDOWS PRODUCT KEY!!!*
Feb 21, 2010 | HP Mini 1035NR Notebook
When i log in to windows xp it logs me out right away
You are not logging into administration and therefore it is logging out. Boot into safe mood and create administration rights account.
Dec 06, 2009 | Microsoft Windows XP Professional With...
Failing to log on Asus Laptop L7200 with windows xp professional
can you explain if its the initial logon to enter the bios and set up; or the windows log on to boot into your desktop
Jul 03, 2007 | ASUS COMPUTER (S6FM-1P028C) 11.1INCH 1366...
O2 Xda Zinc Cellular Phone Logo
Top O2 Cell Phones Experts
Computer Repairing
Computer Repairing
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Are you an O2 Cell Phone Expert? Answer questions, earn points and help others
