Question about Kenmore Dryers
Thermal fuse repeatedly blows
I installed a new thermal fuse and it stopped working after 2 uses. when tested current does not pass through fuse any longer. I assumed part defective and replaced. The same thing happened on first dry attempt. I dont think it is the part but an unknown problem in my dryer. can you help me figure the problem out. Maybe I should replace the high heat fuse as well? the current one does have good test results for current/continuity. thank you
  • 304 Answers
The thermal fuse or high limit thermostat failure generally points to a reduction of air flow due to SOME blockage either inside the dryer or in the vent pipe leading out of the house. If you find either of these parts bad be sure to check the vents after replacing parts to ensure the same parts won't fail again.
It sounds like you have blockage in SOME area of the venting system, either interior to the dryer or in the vent pipe leading out of the house. The thermal fuse is a safety feature to warn of low air flow. Remove vent from wall and run dryer placing hand over end of hose to determine strength of flow difference after attempting to do the same thing at the exhaust outside the house. Good Luck.
Posted on Sep 04, 2009
Testimonial: "I thought I tried everything, I never would have believed lint was my problem. Thank You sooooooo much for pinpionting my problem for me."
Thermal fuse failure
If the relay sticks, that will cause overheating and the thermal fuse to blow.
Feb 27, 2017 | Whirlpool Dryers
Does not come on
follows this steps and fix it. God bless you
Line Fuse
Every microwave oven has a line fuse. This fuse is designed to blow if too much current is drawn through the microwave circuitry. The fuse can be replaced, but the underlying issue should still be investigated and resolved. Otherwise the new fuse will blow also.
Main Control Board
If the microwave is not working the main control board may be defective. This is not common. When a microwave stops working the problem is usually the line fuse or within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Thermal Fuse
If the microwave is not working the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector
If the microwave is not working the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Feb 07, 2013 | Microwave Ovens
What is the internal resistance of WB27x10194
follow this steps and fix it. God bless you
Line Fuse
Main Control Board
Thermal Fuse
Thermoprotector
If the microwave is not working the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.2_7_2013_10_19_58_pm.gif
Feb 07, 2013 | GE SpaceMaker Microwave Ovens
Whirlpool over the counter microwave stopped working
SEE THE steps and fix it. and diagrams attached.use the DVOM.God bless you
Line Fuse
Main Control Board
Thermal Fuse
Thermoprotector
If the microwave is not working the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown2_6_2013_8_43_03_pm.gif2_6_2013_8_43_37_pm.jpg
Feb 06, 2013 | Microwave Ovens
Microwave stopped working. No power
please follow this steps and fix it. God bless you
Line Fuse
Main Control Board
Thermal Fuse
Thermoprotector
If the microwave is not working the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.1_24_2013_4_57_51_pm.gif
Jan 24, 2013 | Panasonic NN-S541 Microwave Oven
Goodmans st101ss microwave no power
Line Fuse
Main Control Board
Thermal Fuse
Thermoprotector
If the microwave is not working the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.1_24_2013_5_05_57_pm.gif1_24_2013_5_07_19_pm.gif
Jan 24, 2013 | Tappan TMT157E1 Microwave Oven
Dryer had built up lint,blew fuse,now will blow fuse after cleaning and replacing vent hose
if its heated electrically, not by gas,then it sounds like the heating element has shorted to the case and this would blow the breaker
Jul 28, 2010 | Amana NDE2335AY Electric Dryer
Coffe unit has stopped working. Any help will do.
There are thermal fuses on the bottom. You must remove the bottom cover to see them under the heating tray. If the heating does not work the water will not heat and rise (no drip - nada). I posted some pics on my ebay store.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=150370700440&ssPageName=STRK:MESE:IT
TYPICAL FAILURE OF THIS MACHINE = THERMAL FUSE MALFUNCTION.
WHERE ARE THE THERMAL FUSES: There are 2 thermal fuses under the coffe tray and 1 fuse under the espresso boiler. (YOU WILL HAVE TO REMOVE THE BOTTOM COVER OF THE MACHINE). What this fuse does is regulate the temperature of the heating element so that everything doesn't melt (yep, I tried to bypass the fuse and found out the hard way..testing...testing..). Anyway, replacement for these thermal fuses are sold at RADIO SHACK for about $2.00. (Yep, only $2.00) If you open the bottom cover of the coffee maker and you will see the 2 fuses, they look like resistors. they are covered in a plastic tube to prevent damage. Clip them off I used a small wrench(radio shack) to pry open the small clamps that hold them, replaced them, then reclamped the new fuse back on.
REPLACEMENT FUSES: The thermal fuses have the watts/Amps and temperature stamped on them. There is 1 part that I use and has been working well for over a year ( over a year, yes this machine can last a long time!!).
The part # is Labeled - Raido Shack 270-1321 Thermal Fuse 438°F (226°C) 250VAC 10A (For heating devices like coffee makers and hair dryers). The temperature may vary + - a few degrees° on the label, from what I have seen.
HOW TO TEST THERMAL FUSES: These fuses are not only used for temp control but they also close the curcuit. If the fuse blows then it is open and will not heat. I use my ohmeter (put 1 prong at each end of the fuse) and if it reads open it means that the thermal fuse is bad, it has blown, there is no current running through it. I believe a light meter can check for continuity also and are much cheaper. Test by putting the test leads at each end of the fuse (1 prong at each end).If the light turns on then you are good, getting continuity. If you cannot get no light then it is bad. You can test your light fuse with a simple wire, touch each end and the light should go on, cut the wire in the middle and no light!!easy.
fyi. If your coffee does not get hot enough the fuse may need to be replaced also.
HOW TO READ THE OHMETER.
Know that a reading of OL means "over limit." That means the resistance is off the charts, and you have a break in the circuit. If you got an OL reading for the plug wires, you'd know there was a broken wire that needs replacing. In this case, we got an OL reading because the light switch is in the "OFF" position.
Read more: How to Use an Ohmmeter ' eHow.com http://www.ehow.com/how_2282412_use-ohmmeter.html#ixzz0zwX1LcJD
Consider that a low reading, anywhere from 0 to .5, indicates very little to no resistance. This means there's a continuity of current in the circuit. This is the reading you should get
Read more: How to Use an Ohmmeter ' eHow.com http://www.ehow.com/how_2282412_use-ohmmeter.html#ixzz0zwXjz6C0
Jul 19, 2010 | DeLonghi BCO264B Espresso Machine Coffee...
The clock works but nothing else, could it be programed and I need to reset? how do I reset? I am talking about a cuisanart grind and brew.
there are thermal protection switches under the warming plate there is usually 2 of them if one blows it will stop all function but usually not clock. youcan fix them yourself youfirst need to remove bottom to get under warming plate and there will be two little bullet shapped fuses made from copper youcan use a test meter to see if there is current passing through them both fuses must pass current through to work if one is bad and other is good it will not work . you can aquire the fuses on the web just do a google search for inline thermal protection switch and type name of pot or maker you have to get right ones .. but let me warn yout these are in place for a reason they usually only blow when there is a problem usually overheating problem . so it may be a wise choice to just replace product.just incase
Mar 17, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
Failed heat function
no its a thermal fuse you can by pass it for testing but run long witout it and may get fire other disc is thermal limiter which if it fails then thermal fuse blows i reccomend replacing both as thermal disc may be stuck in closed position
Mar 31, 2008 | Fedders Y Chassis AEY12F7E Air Conditioner
Dryers Logo
80 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
