Question about Toshiba Satellite A105 Notebook
Pointer problems i have a toshiba satellite laptop and when I click on an icon on the desktop it highlights all previous icons on the screen. this means that if i double click on say the explorer icons it may also open the previous ten icons as well. do you know of a solution - could it be hotkey problems or corrupt keyboard. The same problem occurs on both the laptop and remote keypad Thanks you
    Sergeant:
    Champion:
  • 317 Answers
Check if your SHIFT key is stuck.
Posted on Dec 07, 2007
  • Baja Data / Jay Arias-Chavez
    Was your problem solved? Do you have more information or questions?
    If not please let us know, please rate the solution.
    Thanks!
I have a Toshiba laptop Satellite lAptopC-55-B5298 8.1
On a Windows 8 machine you have two places to put an icon for a program.
1. The start menu on windows 8 which is the first set of icons you see.
2. The Desktop, which is like the Windows 7 desktop and you put a shortcut here.
This is easy to do as you right click with the mouse and pick "new" then "shortcut".
Then pick browse and pick out the program file you want to run when the icon is pressed.
Then press "OK" and it is stored on the desktop.
On the start menu you have to go to the bottom of the icons to the down arrow.
Press the down arrow and it will take you to the "Apps", which is the list of installed program.
Then scroll sideways to the right until you see the program you want on the screen.
Pick the icon of the program you want on the start menu, with the right hand key of the mouse.
On the menu that pops up, pick "pin to start menu", and its done.
You can re-arrange the icons on the start menu by dragging them around with the mouse.
Mar 22, 2015 | Toshiba Computers & Internet
My monitor is black but i can still see the desktop somewhat. what could be wrong with it?
Your lcd's inverter has gone bad. Google: "Toshiba Satellite A205-S5804 Inverter". They're about 20 bucks. Then to replace Unscrew or pry apart your screen bezel and it will probably be under or above your lcd. Then just unplug and replace.
Oct 24, 2012 | Toshiba Satellite A205-S5804 PC Notebook
My desktop icons are highlighted in colors and wen i put a wallpaper the color comes on top of it how to remove it ?
If you want to hide your icons, right click on your desktop(your screen). A window will appear and put your pointer on view. Another window will open and at the bottom you will see "show desktop icons " with a check mark. Click on this and your icons will be hidden. To get them back do it again.
Mar 27, 2011 | Computers & Internet
Accidentally pressed multiple keys on the keyboard and now everything is bigger than normal. its not zoomed in because the whole desktop still fits on the screen. all of the desktop icons are now bigger....
Right Click the Mouse with your pointer on the screen
Click on Properties
You shall see a display window
Click on Settings
Screen Resolution... Slid to the Less Pixels
Click Apply Button
That should solve your problem
Regards
Salim
Aug 07, 2010 | Toshiba Satellite P25-S5263 Notebook
The tray touch icon has disappeared. |I have toshiba satellite l300. Cant retreated retrieve it even when i go to show/hide control. i have set it to 'show icon' but it does not. and....i want to turn off...
To Disable the Pointer Device, go to, Control Panel, click (Mouse) in the Hardware and Sound category. Go to, Device Settings, in the (Devices) block, click on, and Highlight; the item you want to (disable) this being the Pointer Device. Click the Disable button, just below. Be sure to (Click) on the Apply button, click OK. You may need to Update Drivers. Click on Hardware, click Properties, click, on Driver. If the, Update Driver (block) is not Grayed-out click Update Driver, click (OK), this will ensure that the application take effect. Note: Restarting the computer will configure system changes in the computer applications to prevent errors, and to finalize the (Installing / Uninstalling) of programs, and or (Enabling / Disabling) of Hardware. I hope this Fix it.
Jan 19, 2010 | Toshiba Satellite A135-S4527 Notebook
My Father's Toshiba Satellite Pro A120 laptop is
about the icons moving, it is because of the resolution... when you plug in your laptop to a wide or bigger screen it changes or adjust the resolution so it would fit in the screen...
Nov 22, 2009 | Toshiba Satellite P300-ST3712 Notebook
Desktop icons
Right click on the desktop;
Arrange icons > Auto arrange
untick auto arrange and there you are a clear organised desktop :)
Matt
Jan 22, 2009 | Toshiba Satellite Pro L300 Notebook
USE LAPTOP ON TV & LAPTOP AT THE SAME TIME
dear sir
yes i can help u strongly... first of all u have to turn of laptop then connect yr laptop and tv then turn laptop on now when windows appeair. laptop screen has icon and other has plane wallpaper so now go to display propaties ( click on desktop>go to propaties>setting> now it's show's 2 monitor screen on display screen click in inditeficate... how it's show "Expand display " somthing like that just remove select earrow now click apply... if it's not worked go to advance then go to adaptor setting and find display setting and select "CLONE" it's male both laptop and tv screen as same...it's help u...:)
Thanks
please vote
jo_chinmay
Oct 06, 2008 | Toshiba P000347580 - Satellite 1400&2400...
Thoshiba SATELLITE A200-1Z3 Laptop
It could be that the screen is at the correct resolution, but the icons are just set to display larger (Vista allows this). Right-click on the desktop (NOT over any icons), and select "View". there you can select the size of the desktop icons.
Sep 04, 2008 | Computers & Internet
My icons won't show up
Try right-clicking on the desktop screen > View and make sure that "Show Desktop Icons" is ticked.
Jun 24, 2008 | Toshiba Satellite A105-S361 Notebook
Toshiba Satellite A105 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
