Question about Konica Minolta Office Equipment & Supplies
New Konica bizhub C351 copier with only 58 copies. It will make copies but it has a 6 1/8" x 8 5/8" BLACK area in the center of the 8 1/2" x 11" copy if you make a copy from the platen glass. It does not do it if you print from the printer function. It does the same on both color and black and white on reduction or enlargement.We have changed the PWB-A "CCD" board, PCB-C board, ribbon cable that connects the two and the large cable that connects PCB-C down to the machine and still the same problem. If someone could call me @ 828.896.8888 we would be glad to compensate them for their services to help resolve this.
  • Konica Minolta Master
  • 6,696 Answers
Gray box after installation.
Solution
CAUSE: Installation procedures were not completed properly.
SOLUTION: Complete the installation procedures thoroughly:
1. Adjusting Touch Panel - Press the Accessibility key, Touch Panel Adj.
2. Setting Gradation Adjustment - Go into Service Mode, Image Processing Adjustment, Gradation Adjustment. Service mode- ulilty/counter, check details , then(Stop00 stop01)
3. Touch High Compression Mode and press Start [perform 3 times].
4. Touch Gradation Mode and press Start [perform 3 times].
5. Touch Resolution Mode and press Start [perform 3 times].
6. Date/Time Setting - go into Service Mode, Press Stop, 1, 1, 4, 4, Clear.
7. Go into Utility/Counter, Administrator Setting, System Setting, Date/ Time Setting.
8. Install Date - go into Service Mode, System 1, Install Date.
9. Serial Number Input - go into Service Mode, System 1, Serial Number [If Serial Number is already there, Clear and re-enter it].
10. Unit Change - go into Service Mode, System 2, Unit Change.
11. List Output - Please Load 8.5x11 Landscape paper on Tray 1, go into Service Mode, List Output, and Touch Machine Management List and press Start.
12. Press Adjustments List and press Start.
13. Press Service Parameter List and press Start.
14. Press Fax Setting List and press Start.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Sep 07, 2009
Code c202 bz c451
This sounds like you have a piece of paper behind tray one.
1. Turn the machine off
2. Take out tray 1
3. Remove paper
4. Insert tray
5. Turn back on
If that doesn't help, you have and issue with the paper pick up motor. This is 99% of the time not the issue. The paper behind the tray is most likely your problem.
Oct 08, 2014 | Konica Minolta 4053-401 Black Laser Toner...
ERROR CODE CALIBRATING
Might require having the firmware up graded get a konicaminolta tech out to up grade the firm ware from a secure konicaminolta web site.
Jun 06, 2014 | Konica Minolta bizhub C351 All-In-One...
C351 konica does not print
does it copy??? try different file different program pdf, web page does it print the demo page does it print the counter page????
Apr 29, 2014 | Konica Minolta bizhub C351 All-In-One...
Dots in print c351
what color and copy to or both print and copy
Feb 02, 2014 | Konica Minolta bizhub C351 All-In-One...
Yellow background after the first print or copy bizhub c351, how can I run image Quality adjusment
The copier automatically adjust the color calibration every ON/OFF.Clean the LED line located under everyimaging unit(black,yellow,cyan,magenta).
Feb 01, 2013 | Konica Minolta bizhub C351 All-In-One...
What does center erase mean on Konica Minolta Bizhb C351 mean?
Hi Meggleton313,
If you needed to photocopy a couple of pages (side by side) from say a magazine or book. You would lay the magazine on the glass, opened on the 2 pages you want. You could use center erase to remove the area where the spine of the magazine would be. Thus avoiding the dark and blurred image traditionally associated with copying this kind of media.
Kind regards
m-press.biz
Mar 01, 2012 | Konica Minolta bizhub C351 All-In-One...
I am trying to set the copier to black and white as default. I do not find in the manual where to change the settings.
1. Select black on the main copy screen. 2. Select the Utilities/counter button. 3. Select [DETAILS]. 4. Select [2. USER SETTING]. 5. Select [3 Initial settings]. 6. Select [Current Settings]. 7. Return to the main screen.
ftp://207.18.56.26/software/BPG/UserbizhubC351CopyOperFW_G4.pdf
page 12-21
Feb 21, 2011 | Konica Minolta bizhub C351 All-In-One...
Konica bizhub C351 copier with BLACK area in center of the copy
u have to run the setup for machine if u like i can send u the step guide how to setup the machine
Aug 05, 2009 | Konica Minolta bizhub C351 All-In-One...
Konica bizhub C351 copier with a C9401 error code
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON again while pressing the Utility/Counter key more than
10 seconds after.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. Turn off the Main Power Switch and turn it on again more than 10 seconds after, and
make sure that the machine properly starts.
Aug 02, 2009 | Konica Minolta bizhub C351 All-In-One...
Dead touch screen
did you try to turn the brightness button.
Mar 31, 2008 | Konica Minolta bizhub C351 All-In-One...
325 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
