Question about Panasonic CT-20G21 TV
TRYING TO FIND A REPLACEMENT FLYBACK FOR MY PANASONIC CT20G13W TV
  • Panasonic Master
  • 1,210 Answers
Call union electronics at 1 800 648 6657. Have your model # and possibly a chassis # or board #. Are you sure this is the problem? A bad flyback is kind of rare but they do happen. Good Luck!
Posted on Sep 04, 2009
I just want to know, what is the part number of flyback transformer on my teli panasonic TC-20P1.
Part number is required only if you are ordering with the company and here in this case you can specify the model number as the data base is available with them.
Otherwise the flyback/ line output transformer can be removed and taken to any spares shop to be identified for the replacement.
Jun 15, 2011 | Panasonic Televison & Video
My TV has been having a shacky picture when it first turns on for a few minutes, then clears up. the other day after using the TV for most of the day, it shut off unexpectidly, and now it will turn on and...
1. YOUR flyback is going bad 2. Peform a removal and replacement 3. check your error codes first to ensue nothing else exists 4. Proceed to change out the required parts 5. Observe all electrical risks 6. Order replacements from jimmyparts.com 7. Ensure to always remove power 8. Ensure to always use electrostatic wrist strap
Jan 31, 2011 | Panasonic PT-47WX49 47" Rear Projection...
Tv dont come on but have a clicking noise, the led blinks with a click
I have a Samsung 32" that did the same thing a few weeks ago and I am still trying to fix it. The problem is the Main Flyback Transformer is blow with an open circuit in the Primary Winding that means you'll get no Picture. I also found the Power Transistor that feeds this Flyback Transformer was also shorted between terminals Collector Base Emitter(CBE). I bought a replacement Flyback but didn't work so now I need to get the Original part & it's not easy to find. Always use Original Components NOT replacements. Simply put if you're not technical I suggest take the TV to your nearest repair agent but be prepaired to pay for it. Cost of Flyback around US$50 & $10 for Transistor & if you find an honest repairman it should cost around $150 to repair otherwise it's not worth it. Good luck
May 30, 2010 | RCA 32F531T 32" TV
Panasonic TV - no picture, but sound is ok
resolder flyback transformer contacts on the board, if doesn't help, replace flyback and horizontal output transistor
Oct 06, 2009 | Panasonic Televison & Video
Panasonic TV no sound no picture
THE REGULATOR IC STR ??? OR THE HOT TRANSISTOR MAYBE SHORTED
Aug 23, 2009 | Philips 27PT543S 27" TV
High pitch noise from the flyback
You can tell to some extent what it may be by listening carefully and trying to identify the location. If you, remove the back cover of the set; stay away from danger, just listen to where it seems like the sound is coming from. If it is coming from inside the high voltage cage it is the flyback. If coming from around the main power transformer it is one of the power supply parts.
Please Rate This Fixya solution
Jan 23, 2009 | Samsung HL-P6163W 61" TV
Ge d52gw12 rear projection tv
Thats the error code for a bad flyback. Its a very easy an ixspensive repair. You can get a new replacement flyback at the following link for under 50.00 and free tech support so you can install it yourself. here is the link you need flyback 265409 for your model.
http://servicemanuals.vstore.ca/
Jun 28, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Keeps blowing fuse
It has a short circuit somewhere...
Not sure if this is a CRT, LCD or Plasma TV but the two common causes of shorts for CRT's are the Horizontal Output Transistor (HOT) and/or the Flyback Transformer (Could be both). As a general rule if the flyback has visible cracks in the case they should be replaced. It is also a good idea to replace the HOT if you're replacing the flyback as it could be weakened and may not last much longer itself.
Other areas to check for all types would be any Diodes in the Power Supply Circuit. If a diode is open it can cause the fuse to blow. Note that a diode itself will not short, but an open diode can cause a fuse to blow.
Mar 11, 2008 | Panasonic CT-32HL43 32" TV
No power
Check the FBT and the Horizontal Output Transistor also.
Sep 18, 2006 | Panasonic TX-15AT1 15" TV
Televison & Video Logo
53 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
