Sony PlayStation Portable (PSP) Console Logo
Posted on Sep 04, 2009
Will not read the SD card no matter what i do
I put SD card in the orange light just blinks and thats all what can i do to fix it and i tried to gently blow in the slot already
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Sep 06, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
767
Points
Ive had the same problem but i found out that if u push it in hard and quickly then keep it there it will come on, but then u have to keep it puched it for it to work
Anonymous
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Sep 04, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
0
Helped
3263
Points
34
Go to memory settings and see if cards are enabled .
3answers
My hp laserjet 1300 printer shows blinking the orange light instead of the green one and I couldn't find out what is the reason
1. Go light/button blinks twice with solid green and orange lights
2. Green light starts blinking with go light twice and then both go off
3. orange light goes off.
4. green light followed by orange light followed by go light cycle twice and a third time by the green light
5.followed by the orange light continuously blinking.
I have already tried the following trouble-shooting:
1. Put in a new cartridge
2. Made sure there is paper properly seated in the tray
3. Made sure all doors closed (I even took off left side to verify no memory cards
4. Verified all doors closed
5. Done a cold reboot by holding the Go button while turning the unit on.
6. Repeated steps 1-5 multiple times.Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For HP Support
Camera says new sd card is full
put it in a computer and see what it reads,it might need formatting .
1helpful
Flashcard not loading
It may be likely that the TF (SD) card is not being read properly or has been damaged/corrupted.
Try to read that SD card on your computer (i.e. not using the GPS) ... and see if it works. And/or use the Properties - Tool - Check Disks tool to "recover/fix" the SD card (on your PC).
4helpful
3answers
Netgear wndr3300 blinking orange light
It depends. Have you checked the Netgear support site for FAQ and the manual. In some routers, orange lights indicate wired 100Mbps connections while green indicates 1000Mbps. In other cases, blinking lights indicated that the router is 'bricked'.
2answers
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Every time I put my camera's SD card into my HP Printer C3150, a red exclamation mark light blinks on and off, and the SD card does not appear on "My Computer," so I can't access my pictures....
I am not an expert on such matters. It is possible the printer won't read the SD card because it wasn't formatted before use or was formatted by a computer using 64 bit software instead of 32 bit.
You could try using a card reader and downloading the images to your computer and printing from there.
1helpful
Memory card error for 4GB SDHC card on HP Photosmart printer 2710
Well SD max is 2gb, so you can get 2gb if you want.
SDHC max is 32gb. If you are not on a budget, try upgrading your printer to a newer model.
SDHC is coming out with even newer models, now with a class 10 (10mb read/write speed - but very costly).
However, if it doesn't matter to you, might as well just stick with the same printer, since SD cards are coming down in price. Just make sure you get 2gb cards with a good class speed.
Joystick blinks orange light
It sounds like it could be a couple of different things but it will be hard to tell without having the camera right in my hands. First you might want to check to see if you have a SD card in the cmaera. The internal memory may be full of your images and there is no room for anymore. If you have a sd card already in the camera then make sure it is not over 2gb. That model will only accomodate a 2gb card and nothing more.
Hope this helps
1helpful
I load regions to sd card and meridium platium does not recognize
You do not need to screw with an SD card, they are formated to take whatever data you send to them, but in your case check by reading the card to see what is on it BEFORE you put it in the GPS. It may have junk files on it, thus there is no room, unless of course you try to load to much data, THERE IS A LIMIT, suggest you read the GPS manual, and see what the limit of the size of the card is for that GPS, yes there is a limit!
1helpful
Tom Tom XL
The One XL can only read from internal OR sd card...
So, if you want the device to boot from the sd card, it need system files installed on the sd card...
So, try this:
- BACKUP !!
- Copy ALL content from internal memory to sd card.
- Insert sd card, and boot the device.
It should know boot from sd card, not internal memory...
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
