Question about HP w19 19" LCD Monitor
Processing auto configuration keeps coming up on my monitor
Monitor gateway
  • 5 more comments
  • ygue50 Dec 24, 2007
    "Processing Auto Configuration" keeps showing up on my screen. I have a Gateway FPD1530 monitor. It is annoying. Can you help me? Please!
  • Anonymous Jul 30, 2008
    since I downloaded and upgraded to IE 7, this problem appeared.
  • daytona344 Sep 02, 2008
    "Processing Auto Configuration" keeps popping up on my screen. I have a Gateway FPD 1700 monitor. This problem has happened before (about 2 years ago) and went away on its own. I took it to my local computer guru who told me I needed a new monitor. When I got home, it wasn't doing it any more, but my LCG said he didn't do anything to fix it. I've tried unplugging everything. I was hoping someone else could help. It's really annoying.
  • Anonymous Dec 12, 2008
    I had the same problem on my PC which suddenly appeared out the blue and thought it was my monitor. However I have just uninstalled the Google taskbar from my Internet Explorer and it has now gone. I cannot believe this is the cure but my monitor does not show auto processing now at start up.
  • Anonymous Jan 28, 2009
    same thing. changed monitor settings to different scan rate, updated all drivers. happens with different machines. not a virus or other malware.
  • no way Jose Mar 05, 2009
    A blue rectangle started popping up on my screen saying "Processing Auto Configuration" It stays on for long periods, but occasionally disappears. It is in the center of the screen! Ugh!
    The rectangle flashes on and off, however, the computer seems to work. What caused this? How can it be eliminated?
  • hh4030 Apr 17, 2009
    Processing Auto Configuartion
Help! I want to get rid of the "Processing Auto Configuration"
Posted on Apr 21, 2009
  • hh4030 Apr 22, 2009
    Whos the sponsor of this "Processing Auto Configuration" nonsense? And how do I get rid of it?
    No one seems to know anything about "Processing Auto Configuration" - what gives?
Why does "processing auto config "keep poping up on my montour?
Posted on Dec 14, 2008
    New Friend:
Check and see if you can tell that the Brightness and Contrast settibgs change (just like a computer always loadibg default setting everytime you boot up as you might know in that case it's the mother board battery that hols the bios settings) so in this situation the monitors battery might be going dead ( I am totally guessing but how else would it keep the brightness etc etc settings.
Posted on Apr 18, 2013
  • inavato
    inavato Apr 18, 2013
What does it mean?
Posted on Sep 05, 2008
You need a new monitor
Posted on Sep 25, 2008
2 Suggested Answers
LadyTech99
  • 141 Answers
SOURCE: processing auto configuration
Check your settings in "Power Options Properties".
Control panel/ power options/ advanced/ under power buttons make sure you have "shut down" when you press the power button on your computer.
I hope I am understanding your problem correctly. If not pls. explain what you mean by and when processing auto config. keeps flashing. Is there a black screen or a windows interface?
Posted on Dec 11, 2008
How do i get auto configuration off my screen
Try uncheck Auto configuration when you right click on desktop and choose screen resolution menu.
Nov 25, 2015 | Gateway FPD1530 15" Flat Panel LCD Monitor
Screen Problems
Why do you keep selecting auto configuration? You have the option of manual configuration, don't you? That is there in case the auto does not provide the results you want. So just set it manually to however bright you want.If it just will not go as bright as you would like, the remaining possibilities are aging backlight, inverter, or powerstrip capacitors which are all within your display.most re[pair shops will not even attempty a reiar of an LCD display, and if it turns out yours is deteriorating, you need to think about a new one. Unfortunately the problem with LCD monitors is that they just don't have anywhere near the life of a CRT.
Jun 18, 2010 | Gateway FPD 1520 15" Flat Panel LCD...
First check to see that all of the cables are connected and fastened in tightly between the monitor and computer using the tiny handscrews on them at the monitor side and on the video card where it connects to your computer.
Also, the resolution detection circuitry in the monitor could be going bad, or you could have a bad video cable connecting it to the computer, or lastly, the video card in your computer could be going bad.
A few separate things you can try:
1. If you have a spare video cable, connect using the spare cable to the monitor and the computer to see if this corrects the issue.
2. If you have another monitor, I would connect it to see if you continue to have video issues.
3. Consider buying a new monitor.
Nov 30, 2017 | Gateway FPD1530 15" TFT LCD Flat Panel...
Message from display FPD 1730 won't go away
press the menu button on screen panel and press exit.
Dec 02, 2009 | Gateway FPD 1730 17" Flat Panel LCD...
FPD1530 15in flat screen Config. issue
The native resolution of the monitor is 1024 x 768, so set your computer resolution to that value. If necessary, restart the computer with the monitor powered on.
Here's a link to the User manual:
Gateway FPD1530 User Manual Fpd 1730 Specifications
Nov 19, 2017 | Gateway FPD1530 15" Flat Panel LCD Monitor
Nov 18, 2008 | Acer AL1711 17" LCD Monitor
Monitor keeps flashing "Auto processing"
Hi
Do a factory or monitor reset from the monitor menu.
Jan 01, 2008 | Gateway FPD1975W 19" LCD Monitor
It solved by fixing 1024X786 pixel solution.if it not possible by fixing it..
Then look over the VGA driver is correctly support or not
if not then you have to update the VGA (Display) by drivers
By
Murugeshkumar.k
Dec 24, 2007 | Gateway FPD1530 15" Flat Panel LCD Monitor
HP w19 19" LCD Monitor Logo
3,321 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
