Question about Canon i850 InkJet Photo Printer
Red streak poor color
Red streak threw the bottom of picture color blown out and blurry?? need help fast
If streaking is occurring only at the bottom of the page (i.e. the last area to print as the paper is fed beneath the print head), the problem may be due to improper curl of the paper. Many inkjet printers (Canon especially), rely on a slight curl of the paper so that it is "bowed" when it travels beneath the print head.
To see if this is the problem, gently roll a sheet of paper so that the print side is on the outside of the roll. When you place the paper in the feed area, it should have a very slight bow so that the center of the print side is slightly raised off the surface, while the edges are on the surface.
Also, make sure you use only OEM (Canon) cartridges. There is not a single "compatible" cartridge in the world that won't screw up your Canon print head. Take my word for it (and I DON'T work for Canon), you must use only Canon cartridges.
Posted on Jan 21, 2008
Television is a Tosiba DLP 72HM195
your tv needs a y-load board its like a grafix card as computers have due to overheating the board components are affected this is a manufacturing fault it tends to happen with samsung aswell
Feb 22, 2012 | Toshiba 72HM195 72" HDTV
I hve a nikon coolpix 10 MP but the image quality is poor....i have tried resetting all the camera settings to default and dont know what else to do....also, it keeps showing a red colored icon (it...
The red clock indicates that the date and time need to be set.
As for the "poor" quality, there are many possibilities. If the colors are wrong, the most likely culprit is an improper white balance setting. If the pictures are blurry, that could be caused by subject motion, camera motion, improper focus, or a combination of the three. If pictures taken with the flash are too light or too dark, that could be because the subject is outside of the flash's range. Without knowing what you mean by "poor" I can't give you anything more than some ideas.
Dec 27, 2011 | Nikon COOLPIX S220 Digital Camera
LEFT SIDE OF PICTURE IS BLURRY AND COLORS DISTORTED
Does that set have whats called a color wheel, if so that maybe you problem, and replacement is how you fix it.
Apr 30, 2010 | Toshiba TP43H95 43" Rear Projection...
Blurry and colors are seperated red green white
if you are viewing from a projection tv, chances are you have to go thru the menu of the tv to 'picture tuning'. here it gives you different things that could be fixed. one to look for is 'lamp alignment'. It should show all the colors and lines with directions to bring them into focus. This should fix the blurriness and 3-d red/green/white separations. hope this helps you!
Aug 16, 2009 | Philips Magnavox 51MP392H Rear Projection...
Problem with pictures
if the picture is getting distorted red pink or green in color then it is 100% CCD fault and the detail is also blurry then arrange for ccd change or buy a new one i suggest
Jan 29, 2009 | Sony Cyber-shot DSC-S650 Digital Camera
Red noise or flicker on bottom half a plasma screen
Hi!
as i see your picture maybe that is lack of vertical sync or vertical ramp... can you send me the service manual then i diagnose this problem. send me at gmf_likha@yahoo.com
Nov 08, 2007 | Televison & Video
Rca d61w20 dominate red & blue screen also very blurry picture
Red and blue present, but no green = bad green CRT is
best guess.Remove lower front panel = adjust screen and focus
controls for best pix..................T.
Oct 30, 2007 | RCA P52926 52" Rear Projection Television
Blurry Images
Hello paulaspec,
You have a problem with the three factors, and they are screen voltage, focus voltage, and control (focus 2) voltage. Basically these voltages have to be adjusted since the components in this section have aged some. These controls are usually located in the television on the IHVT (Integrated High Voltage Transformer) or as it is also called the flyback transformer. these controls must be adjusted together, along with the color controls. Here is how the adjustment is done (You will need a schematic diagram, a DC volt meter, and a color bar generator to do these measurments):
1) turn color and tint fully counter clockwise until you have a black and white picture.
2) connect the color bar generator to the TV (ch 3) and turn it on, you should see bars in various shades of gray
3) adjust as best as possible the color and tint controls to obtain the color bars on the screen Red Green Blue.
4) measure the voltages on the focus, screen and control grids of the CRT and match them to the schematic digram measurements.
5) adjust the focus screen and control grids to match the ones on the schematic diagram
6) once this is done then you adjust the color controls once again to obtain the red green and blue bars on the TV screen.
This should help if the CRT (picture tube) electron guns are still good and if the flyback transformer voltage supply is working.
However if you do not have a background in electronics please take the TV to a shop for repairs.
I hope this helps,
Thank you,
Shuttle83
Oct 16, 2007 | Sony KV-20M20 20" TV
Canon i850 InkJet Photo Printer Logo
103 people viewed this question
old marine
old marine
