Question about GE 30 in. Profile JP938 Electric Cooktop
Guru, how do you reprogram after you hit canx/clear on the ge cooktop model jp938
  • 3,741 Answers
U.S. toll-free at 800.626.2224 to reprogram the unit you will need to reset the timer click this link directly and get the manual.in it everything is listed clearly with proper procedures.click the pagenumbers to go further. http://www.fixya.com/support/p128338-ge_30_in_profile_jp938_electric_cooktop/manual-12793/page-2
thanks.please do rate the solution.thank you for using fixya.keep updated.
Posted on Sep 04, 2009
1960 ge cooktop element replacement
Your are not quite specific about what kind of a cooktoop ypu want to replace:
DIY How To Replace Gas Cooktop
Whirlpool Cooktop Broken Glass Replacement Model RCC3024
ge electric glass cooktop board glass replacement
Cooktop Main Top Replacement GE Electric Cooktop Repair Part WB62X10047
You can search for more using these terms with COOGLE
Youtube Replace GE cooktop
Sep 24, 2015 | GE Cooktops
When I use the front right burner on high, it keeps clicking on and off. Both the small and large burner does the same thing.
Sorry to read about your problem, I hope this helps you out.
you have a defective sensor control
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
werewr
Dec 23, 2010 | GE 30 in. Profile JP938 Electric Cooktop
What specific type of pots and pans are best to use/ avoid with the profile electric cooktop?
Hello, I hope this helps you out.
any kind of pot is ok
Dec 21, 2010 | GE 30 in. Profile JP938 Electric Cooktop
Can I place a glass kettle("Whistler" brand)
yes you can no problem
Dec 18, 2010 | GE 30 in. Profile JP938 Electric Cooktop
Breaker in panel tripped and won't turn back on
You may have a short circuit to ground fault in the electric cook top. Divide and conquer. Unplug the cook top and try to reset the breaker. If the breaker resets, then you have a problem with the electric cook top. If it doesn’t, then the problem is at the electrical panel side. Either problem will require a qualified technician’s assistance. I hope this helps. Good luck.
Jul 16, 2010 | GE 30 in. Profile JP938 Electric Cooktop
F113
I have the same problem. I had a repair man here and he said the main powder logic board ( WB23T10014) was the problem, it would cost $757 to fix. I ordered the board for $230 and installed it myself but still have the F113 problem.
Jan 21, 2010 | GE 30 in. Profile JP938 Electric Cooktop
GE jp938 just quite. No response to any of the
ck the internal wiring under the top / it may have burned a wire end . make shure you have power on both lines ( 220 v ) m m
Nov 20, 2009 | GE 30 in. Profile JP938 Electric Cooktop
GE gas cooktop
Wow, never heard of that,.... bleeding through glass? I checked the GE service web site and there are no Service Bulletins relating to anything like this. I guess if it were mine and I had that history with it, I'd try the new top, but removing the gasket and first putting a layer of foil duct tape on the underside of the new glass top, then use some new foam gasket material under the cooktop. Good luck. Please don't bother to rate this solution, as anything but a fixya will lower my rating. Thanks.
Nov 08, 2008 | Cooktops
GE Profile Cooktop JGP933
you hit the nail on the head remove the knobs and spray wd40 on each area where the valves been removed make sure no flame is present.
Nov 19, 2007 | GE 36 in. Profile JGP962 Gas Cooktop
One unit show fault code F153
Hi - I've been having the same problem. GE tech service in St. Louis, MO has been a joke. 1st tech call cancelled 30 minutes before appointment. 2nd tech call to diagnose the F153 code I had already provided when I scheduled service on-line cost $74.95 and the tech didn't have the part on his truck. 3rd tech call a new tech shows up, has no knowledge of previous call diagnosis, opens the box sent to my home by GE and announces that the previous guy ordered the wrong part! We're on the 4th call. My cook top right front burner has not worked for a month. I've contacted GE corporate. The part you need (at least I need) for the right front burner which is a large burner is: WB30T10062. If I knew how to, I'd repair this myself. I don't have the extended warranty. The part is covered because my cooktop is only two years old (parts warrantied for five years) but labor is estimated to cost almost $200....plus the $74.95 "diagnostic" visit. A total rip-off. My advice, if you've got this cooktop, it's still under warranty and you aren't using all of the burners on a regular basis: start using them! The tech guy said most people use that front right burner alot and it eventually malfunctions (code F153). His suggestion was to start using the other burners on a regular basis, too, so that when they go out, at least the part will fall under the five-year warranty! When this cook top is done, I'm going to get a gas stove with "old fashioned burners" and it won't be GE!
Sep 24, 2007 | GE 30 in. Profile JP938 Electric Cooktop
GE 30 in. Profile JP938 Electric Cooktop Logo
61 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
