Question about Logitech QuickCam Communicate STX Personal Web Camera
Echo and sound delay on webcam
I have PC Vista. Logitech 2MP QuickCam Pro 9000 webcam. Using Sony Vegas Video 8.0 and external mic (web cam mic muted).
I am trying to record live sound and vision (singing). When sony vegas opens up the capture window before I even start recording there is an electronic sound like a stone dropping down a mine shaft and hitting the sides every 3 or 4 seconds! When I record through the webcam I can hear myself 1 second behind what I have sung, this is fine when singing one note however I am singing a multi note phrase so it's almost impossible to ignore. I then record a harmony in a different clip (against the original clip playing through vegas) then I put all the harmony clips together in vegas and make each clip small so it can be seen on the one screen (makes it look like split screen). Before I edit the individual clips the sound and vision are out of sync, so I then have to spearate the sound and vision in Sony Vegas and line up the sound and vision. I cannot edit the sound any further (add echo or reduce hiss) as these effects make the clip shorter or longer and then I have to line it up again in vegas. My speakers are off as is the logitech mic (muted) and I am just using headphones. So I have no idea where the echo (feedback) is coming from. Q1. How do I stop this weird echo/sound delay, both prior to recording (in pause mode) and during the recording. Q2. How do I get the sound and vision to be the same and not have to manually realign. Many thanks.
  • Weldon Dube'
    Weldon Dube' May 11, 2010
    Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone or Headset. Click OK and it should work. Then to use it on the Web, do this. Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype. Each program has Options that have to be setup in order for the Audio and Video to function properly. A. Skype Setup: After downloading and installing Skype http://www.skype.com/intl/en-gb/download... ) set it up as follows: Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card. Then click on the Video Settings. The camera, if Installed Properly, it will come up and show a video picture. Then, on the bottom of the page click save. The camera and audio should function properly. Your friends and Family will now be able to see and hear you. B. Yahoo Setup: After downloading and installing Yahoo Messenger http://www.soft32.com/download_30.HTML ) set it up as follows: Go to Messenger at the top left and click on it. Next go down to Preferences and click on it. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card. Next go to the Test Audio section and (in blue writing) click on "Open the call setup assistant" and follow the instructions on the left window. C. Windows Live Messenger:http://www.microsoft.com/downloads/detai... After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X. Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar". Next go to the Menu Bar on right side, click on " "Action." Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions. NOTE: Your audio and video should work. Enjoy. When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to. D. AIM (AOL) Messenger:http://dashboard.aim.com/aim On the VIM sign-in window, click on Edit. Then click on Settings Enhanced IM. Next click on Enhanced IM. Then click on Audio Video. The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer. The Audi Video drop downs are Microphone Speaker Camera The audio and camera should function now. Additional information to use with VIM settings. Adjust Your Audio and Video Settings: In order to adjust your audio and video settings, please follow the steps given below: 1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM conversation before running setup. Would you like to disconnect now? Click the Yes button. 2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working Properly. Follow the on-screen prompts. Notes: The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly. Follow the on-screen prompts. images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the Picture-in-picture (PIP) display. After making the settings your ready for a chat and video talk with your Family and Friends. Hope this helps. Bud
  • Logitech Master
  • 2,130 Answers
1st You download Webcam Driver.
webcam driver
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Posted on Sep 20, 2013
    President:
  • 8,637 Answers
A. Skype Setup:
http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/
B. Yahoo Setup:
http://download.live.com/Messenger
On the VIM sign-in window click on Edit.
Microphone
Speaker
Camera
Conversation before running setup. Would you like to disconnect now? Click the Yes button.
Notes:
Posted on May 23, 2010
I have a logitech Pro 9000. It works completely fine with GChat, but not for Skype. Skype complains " bad internet connection" and the video I transmit is mostly frozen. On the other hand the...
hi freeman319
you might want to try and uninstall the quickcam application. as i've researched skype is having problems with certain cams compatibility. just try and uninstall the quickcam application but not the drivers. with this you may still be able to use the quickcam with other applications.
you can uninstall it through the control panel>add remove programs
also if you are using a headset or separate mic and headset with the video call you would want to disable the mic on the quickcam
go into Device Manager and disable the microphone in the Pro 9000
ofcourse this is just some things you can try but is not guaranteed to solve your issue. please let me know if this works. thanks.
hope this helps
janc30
Feb 11, 2011 | Logitech QuickCam Pro 9000 Web Cam
How can i download software for logitech web camera pro 9000
The link below will take you to Logitech's support page for that specific model of web cam. You will need to select the operating system you are running but will be able to download the latest software and driver for the device.
http://www.logitech.com/en-us/435/6333?section=downloads&WT.ac=sc|downloads||dd
Robert from Blitware
Jun 07, 2010 | Logitech QuickCam Pro 9000 Web Cam
Very choppy video on HP DV7T Vista 64 bit
If you are happy with it running on a different OS try running it in Compatibility Mode
Right click on the desktop camera icon
Select 'Properties'
Select 'Compatibility' tab
Check the CM mode box and select the OS from the dropdown box
Click 'Apply' & 'OK'
May 23, 2010 | Logitech QuickCam Pro 9000 Web Cam
QuickCam Pro 9000 Web Cam: I plug in my Logitech Quickcam Pro 9000 and it wil...
It is possible your webcam is either disabled or the driver is corrupted. Try reloading the webcam software driver, reboot, and then try the free webcam test tool to check if it is working properly.
May 06, 2010 | Logitech QuickCam Pro 9000 Web Cam
MY WEBCAM AND MIC NOT WORKING,I HAVE WINDOWS VISTA ULTIMATE ON A ASUS 6000 ENTERTAINMENT SERIES
Change default microphone from your camera property. That is it should not be the computers default microphone of sound card , it should be the camera’s mic.
Oct 19, 2009 | Logitech QuickCam Pro 9000 Web Cam
Logictech quickcam Pro 9000 not working
Hello nreesorjohns , this is the link for Full Driver enjoy :) ftp://clubicvisiteur5638:1244762357@ftpclubic7.clubic.com/temp-clubic-rx326/drivers/logitech_logitech_quickcam_11.8.0.1065_4219.exe
Jun 11, 2009 | Logitech QuickCam Pro 9000 Web Cam
When I try to start my logitech webcam 9000 Pro , my pc always restarts.
What pc is it? Laptop /desktop, mac/pc,os is windows or mac? vista, xp, etc?
probably a driver problem, but would be helpful to know the pc environment.
May 25, 2009 | Logitech QuickCam Pro 9000 Web Cam
Camera works but microphone doesn't My wife has a QuickCam Pro 9000 Web Cam - Camera works - The speakers are in the screan and are realtek the computer seems also to be looking for realtek microphone and...
That KachiWachi guy is a **** indeed...
My fix for Vista 64 bit, yellow exclamation mark at Logitech Mic (Pro 9000) in Device Manager:
Right click Logitech Mic (Pro 9000), properties, driver, update driver
Browse my computer for driver software, location should be C:\Windows\System32\drivers, also make sure the Include subfolders box is checked
Click on Let me pick from a list of device drivers on my computer
Make sure there is a checkmark at Show compatible hardware
Select the USB Audio Device instead of the Logitech Mic (Pro 9000) and click next
Now your microphone works by using the generic Windows driver instead of the Logitech ****!
Sep 18, 2008 | Logitech QuickCam Pro 9000 Web Cam
Logitech QuickCam Communicate STX Personal Web Camera Logo
1,352 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
