Question about HP PSC 2210 All-In-One InkJet Printer
How do you unlock a password from an ipod houch
I need help unlocking my rca tablet
For unlocking you need unlock code from imei number. there are many apps and software which generate unlock code for free. here is how to unlock iphone ipad which is locked disabled due to wrong passcode entered.
Below is procedure for unlocking iphone ipad.
First try to recover your password for that connect your ipod to computer via usb cable.
Now ipod is recognize by computer and find the folder named ipod. Now browse ipod folder and open ipod_control folder , inside that folder there is ipod _unlock file. Try to edit that file with some software to recover your password inside that file otherwise. Delete or rename that file and power of your ipod and restart it. There is other way to recover password but when I put such answer my answer marked as spam and deleted and some senior member using that answer method for their answer and get reputation.
Ipod got disabled when you have entered wrong passcode many times. And to unlock this passcode either recover your passcode from ipod or restore your ipod via ituens.
For that connect ipod to computer and if ipod is recognized by computer then open itunes click on device tab then summary tab on right side pane you will find restore ipod.Click on Restore iphone and ipod will be restored but this will erase all data on ipod.
If you don't want to delete data then there is option to restore ipod from backup. So restore ipod from recent backup. For that open itunes - click on devices and right click on ipod there you will find option restore from backup.
If none of above method can solve your problem then enter into dfu or recovery mode. For that connect your ipod via usb cable to computer and thenPower off your ipod, now press and hold power button and home button for 15 seconds, now release power buttonbut keep holding home button now itunes will detect ipod in recovery mode now restore your ipod.
http://ipodtips-tricks.blogspot.com/2015/12/reset-forgotten-password-unlock-ipod.html
Oct 15, 2017 | Tablets & eReaders
Tip
Resetting an iPod if you forget your password
<p>The iPod is a security measure to prevent unauthorized access to your personal media player. Apple included an option to set a password to be used to unlock the device at startup. If you draw a blank password, you can still have the ability to unlock the device, but the process depends on the model of the iPod. IPod Touch owners to restore the device to a password reset code. Other iPod owners need only plug it into iTunes to lock the screen around. <br /> <p><br /> <p>Lock the iPod <br /> <p>1. Connect your iPod to your computer you normally sync your device. <br /> <p>2. ITunes load. <br /> <p><br /> <p>3. Click the "Eject" on the right to offer your iPod under "Devices" in the left column of iTunes. The iPod will be unlocked. <br /> <p><br /> <p>4. Select the "Extras" on the iPod. <br /> <p><br /> <p>5. Select "Lock screen". <br /> <p><br /> <p>6. Select 'Turn Off Screen Lock. " <br /> <p><br /> <p>Unlock iPod Touch <br /> <p>1. Connect your iPod Touch to your computer. <br /> <p><br /> <p>2. Open iTunes. <br /> <p><br /> <p>3. Click on the iPod Touch icon on the left "Devices" section column. <br /> <p><br /> <p>4. Select the "Summary" tab. <br /> <p><br /> <p>5. Click "Restore" and confirm the prompt action in the resulting pop-up. Follow the wizard prompts for the restore process to complete. <br />
on Jul 21, 2011 | Computers & Internet
Remove password ipod
Depending on the model of your ipod it will differ
iPod Classic password
This works on an iPod 5 th gen
Click start control panel scroll to folder options tick in the box to show hidden files and holders
connect your Ipod to your computer
Click start click click on you Ipod to open
then go Ipod controls device there should be a folder saying locked
Right click select rename to open or delete the folder your Ipod should now be open
ipod touch password
Launch the iTunes program on your computer and click "Help" on the main menu.
Scroll down and click "Check for updates."
Close iTunes.
Connect your iPod to the computer using the supplied USB cable.
Launch iTunes, which will display your iPod on the left panel.
Right-click your iPod in the iTunes program and click "Eject."
Close iTunes and detach your player from the computer to unlock it.
http://www.youtube.com/watch?v=5uT8Utk5Tqg
ipod iphone ipad password reset
Unlock an iPod Model A1199
Although the second generation iPod Nano (also known as 2G) uses a four-digit pass code that prevents unauthorized access to your iPod by locking the screen, you can also unlock the device by plugging it into your computer's USB 2.0 port.
When the 2G iPod Nano is connected to the computer it is synchronized, and automatically unlocks the screen according to the official Apple site.
In order to successfully unlock the Nano it must be plugged into the primary computer used for synchronizing content.
Click "Start," "All Programs" and "iTunes" on your PC's desktop, or click "iTunes" on the Macintosh's desktop dock.
Plug the iPod Nano's cable into the docking port on the iPod Nano.
Plug the other end into the USB port on the computer to open iTunes.
Click "Controls" at the top of the iTunes' menu, and select "Eject iPod."
The iPod Nano's screen will be unlocked once it is ejected from your computer.
Jul 25, 2013 | Apple iPod Audio Players & Recorders
Forgot ipod password give me a code to unlock it
The only solution is to restore and update your ipod in iTunes.
It will erase all your files on the ipod but at leas you can use it now.
Jun 22, 2010 | Apple iPod nano
Ipod touch is locked forgot password cant unlock
plug it into your computer and through itunes on your original computer you will be able to reset it. If it is not the original computer that you are using you will be able to reset it but will probably lose the information on it.
May 05, 2010 | Apple iPod touch
How can i unlock my ipod nano if i forgot my screen password \
there is no way you can unlock your ipod nano without the screen password. i would request you to contact the authorized service center. they will be in a position to help you out.
Oct 31, 2009 | Apple iPod nano
Ipod nano volume locked forgot password
Basically you cant unlock the voulume if you dont know the password. You would probably have to reset your iPod in order to adjust your volume and when you put a new password in be sure to remember it.
Feb 25, 2009 | Apple iPod nano 3rd Generation
Ipod seems to be blocked password not working i type the numbers in but numbers not showing .when i type in the white blocks where u type the passwords numbers dont work just makes a tick noise when i type...
hi ipod locking is diffrent from mobile locking. you can unlock ipod vary easily here is steps for how to unlock ipod. I am sure u can unlock your ipod by this method still if u find any problem then comment here.
below is also some way you can reset your ipod password this can also unlock your ipod.
  1. Plug in your iPod
  2. Wait for it to load; when it loads, open my computer(or computer if on vista)
  3. Make sure you can view hidden files
  4. If not, go to tools, folder options, and select view hidden folders
  5. Go to iPod_control
  6. Got to a folder in the folder named device
  7. if your ipod is locked there will be a file _locked . just rename the file to _unlocked and safely remove your ipod and it will be unlocked
Dec 02, 2008 | Apple iPod touch
Cant unlock ipod
if you give the correct password it must unlock.
else do a reset so that the password gets resets
Oct 21, 2008 | Apple iPod nano
How to unlock it with no password
i have locked my i pod but i cannot unlock it i forgot the password pls help me wht to do
Nov 15, 2007 | Apple iPod MA446LL/A MP3 Player
HP PSC 2210 All-In-One InkJet Printer Logo
15 people viewed this question
Seeker5211
Seeker5211
