Question about Garden
Has spark gas ,air 10 10 vintage wont start .has new plug started once when i got itn died wont start. arms sore.
    President:
  • 2,220 Answers
Remove and inspect the plug. If it's wet you have flooded the saw.
Posted on Sep 04, 2009
My pgo t rex 125cc wont start, has gas, clean air filter,new s/plug,new battery,dont get spark when i remove plug wire +hold near earth, help pleae
motors need three things to run. Fuel, Oxygen, and Ignition (spark).
If you leave motorcycles set for a long time, the gas in the carburetor will turn to lacquer. If that is the case no fuel will get to the spark plug. Spraying starting fluid in the air cleaner or carb can prove this, and it will start and run for a couple seconds then die.
If you can smell gas, you have either no spark or it may be flooded. If you don't have spark, find out if there is a blown fuse, or a shorted wire.
Feb 28, 2015 | PGO Motorcycles
98 harley fatboy turns over but wont start
some after market ignitions don't spark on the first couple of turns but first take off your air cleaner twist the throttle and look to see if gas is spraying in the carb if not give it a little starting fluid if it fires but then dies then its carb issue. now other thing to check is if you have three posts on your coil then its single fire and your plug wires might be going to the wrong spot switch um around.
May 09, 2014 | Harley Davidson FLSTF Fat boy Motorcycles
Need help starting a gx340 honda with new ring kit ,honed cylander,lapped valves,adjusted valves with new ex valve seal.started warmed up and changed throttle level from low for 10 min to med for 10 min...
If there is air in the tanks, it will be harder to crank, drain air out before starting, Also check spark plug. Sometimes i put gas where the plug goes, just a little pinch of gas though. put spark plug back and give it a few cranks.
Oct 02, 2013 | Honda Jenny GT8HGB-30P 8hp 30 Gallon GX...
My murray push lawn mower won't start
did it die right after a refueling? You might have water in your fuel can.
Which now is probably in your mower.
Drain out all the fuel *(remove the carb bowl too) Get some fresh gas *(dump your can of fuel out into a secondary container so you can look for water in it. If it has water on the bottom...you should dispose of it wherever you dispose of your mowers waste oil.
You should be sure you have spark. Which means you need to remove the spark plug from the head and with the boot still attached dangle it on the metal head and give it a pull and look for sparks. If you have no spark you might need a new plug or coil. Thats really all you can do for weak or no spark. Be sure the plug is clean and free of oil/gas contamination as that may have fouled the plug.
Good luck and be careful!
Jul 13, 2010 | Yard Machines 11A54MC006 21Inch 139cc MTD...
I have a poulan micro deluxe and it wont start
Given the age of the saw and the fact ethanol was not an additive at the time of its creation I suspect you have cracks or holes in fuel lines. It is a good idea to replace the plug and the fuel filter. For the record the most common hard starting problem on a 2-cycle engine regardless of vintage is a flooded engine. We will go in a logical progression to isolate your problem. You need spark, air fuel mixed in correct proportion, and compression for the saw to run. We will test spark first like this:
Ignition Coil Test by SmallEng.com (Inspect the plug once removed if wet the saw is flooded. Post back with that too.)
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You do not have to bend up the electrode.
If no spark post back (below and I will help find parts). I am going to continue as the saw has spark.
Remove the air cleaner (clean it), open the choke, put a teaspoon of fuel/oil mix in carburetor throat. reinstall air cleaner, and try to start it. If it sputters and dies there is a fuel delivery problem (fuel lines or dirty carburetor). This is may be helpful:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
If still no start reply below and we will continue.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 05, 2010 | Poulan Garden
Want start
Read the warm start procedure from the operators manual.
1. Pull choke (sets fast idle)
2. Push in choke (fast idle retained)
3. Make sure ignition is on, pull (usually once on my saw)
4. Advance throttle slightly to release fast idle.
I made the mistake ONCE of not setting the fast idle. My shoulder gets sore thinking about it. HTH
Lou
Sep 21, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
3000gt sohc wants to start but wont?
With all the new parts check the tps sensor on the throttle body may be unhooked.
Sep 08, 2009 | 1997 Mitsubishi 3000GT
Craftsman 25cc edger has trouble starting. once started it will run for 5 - 10 minutes and then shut shut off. Will not start again until it cools down. Changed the spark plug , but it has the same pr
Dump the fuel in the tank, get new gas and new oil and start over. Get a carbeurator cleaner additive for the gas as your carb. is dirty resulting in the sporatic operation.
A spray carb. cleaner that you squirt into the air intake by removing the air filter will also work for you. In fact, when you are getting the carb. cleaner get a new air cleaner and a new spark plug. get back and let me know how u make out.
May 20, 2009 | Garden
2004 chevy aveo.. HELP!
try compression test and get back to me
Dec 26, 2008 | 2004 Chevrolet Aveo
Garden Logo
98 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
