Question about Philips HDD082 MP3 Player
Nothing happens when I plug it in.
Won't turn on. Can't open it to change the battery. Wont charge when I plug it into the USB or the Wall outlet. Anyone got an idea? Plz help.
  • JanieP1106 Dec 19, 2007
    The screws are so tiny on my son's MP3 player, I can't unscrew them to take battery out. Player is frozen. Any suggestions?
  • nick000 Jan 08, 2008
    I have a HDD082 and it too will NOT power up or take a charge from the USB or charger... any help will be greatly appreciated.
This solution does not work. my device will NOT turn on, hence the Device Manager does not recognize the device, hence you can not do a device repair.
Posted on Feb 11, 2008
Mine is less then 3 mo old and it has stopped working, I have used the death out of it and now I cannot even turn it on to get all my songs off of it....will a regular charger charge it aside the one for the computer?
Posted on Apr 15, 2008
  • 8,596 Answers
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
My iphone won't charge up at all i put it on
hi there.
Follow these steps:
  1. Remove any debris from the charging port on the bottom of your device.
  2. Restart your iOS device.
  3. Try a different USB cable or charger.
  4. Make sure that you have the latest version of iOS.
  5. Contact Apple Support to set up service.
If your iPhone, iPad, or iPod touch won't charge - Apple Support
Why my iPhone is not charging?
2: Change the Wall Outlet or USB Port Plugged Into. The next most common reason aniPhone won't charge is because of where it's actually plugged into. Sometimes the wall outlet itself isn't working or the light switch is turned off, so if you're using a wall charger then change the outlet.20 Feb 2016
iPhone Won't Charge? Here's Why iPhone Isn't Charging & How to Fix It
How do you clean the charging port on iPhone?
To be safe, back up your iPhone or iPad to your computer or the cloud. Power it off, and with a normal toothpick, gently remove the lint. You will be amazed how much can get stuck in the port. Connect the charger and see if it works.16 Dec 2014
Use a toothpick to clean out your iPhone - CNET
https://www.cnet.com/how-to/use-a-toothpick-to-clean-out-your-iphone/
How do I charge my phone if my charger port is broken?All you need to do is shut down your device, remove the battery if possible and use something small, such as a toothpick, to 'lever up' the little tab inside the USB port on your smartphone or tablet. Do so very carefully and gently, then reinsert your battery and plug it in again.16 Jul 2016How to fix a phone that won't charge properly - AndroidPIThttps://www.androidpit.com/how-to-fix-a-phone-that-won-t-chargeSearch for: How do I charge my phone if my charger port is broken?
or try this link.
iphone won charge up Google Search
Nov 19, 2017 | Cell Phones
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
120gb Zune won't turn on or charge
No probley not it needs a new battery more than likely they can be bought for around $25.00 or so no fun to put in very delicate.
Sep 29, 2017 | Microsoft 120gb zune digital player /...
Nokia coolpix p100 wont charge
In General. Nikon Coolpix cameras TURN ON when you change them. This means when you plug in USB with a computer the camera turns on and the computer sees it.
If you turn the camera ON. And the Battery indicator shows "FULL CHARGE" you may NOT be able to charge it.
To eliminate variables. Do not charge with the computer until you charge with the adapter (wall charger). When the wall charger works then try the computer.
Look at page 145 in your manual for Computer charging.
Make sure your date and time are set in the camera.
Make sure it NEEDS a charge.
Aug 13, 2017 | Nikon COOLPIX P100 Digital Camera
My phone turned off randomly and now it won't turn back on,thinking it was dead I plugged it in using the USB charger because I lost the other one...but after plugging it in it still wouldn't turn...
First of all change your battery and try again if nothing happens don't do anything just go to service centre with a photocopy of purchasing bill.
Aug 04, 2011 | HTC Cell Phones
My sky caddie sg5 wont charge
If you follow these instructions which I think you know how to, it will recharge. If not the rechargeable battery needs to be replaced
To charge the battery, simply follow the steps below:
  1. Gently pull back the rubber cover to gain access to the mini-USB port located at the bottom of the SkyCaddie. Insert the mini-USB connector of the supplied wall charger into the mini-USB slot.
  2. Plug the wall charger into the AC wall outlet. While charging, the charging indicator in the upper left-hand side of the SkyCaddie will show red. The charging indicator will switch to green when fully charged. You may also notice the unit's screen turn on and off periodically.
The battery will charge, even with the SkyCaddie turned off. A full battery charge may take 4 hours. Once fully charged, expect 36 holes of continuous play.
Warning!Always connect the cable to the SkyCaddie first before connecting to AC power or PC USB.
Jul 16, 2011 | GPS
My Mambo- Mano MP4-MP3 does no charge
it does not seems to charge / or turn ON either from the computer or when plugged to an electrical outlet to the wall. Red light is still ON after the whole night . What's wrong ?? Can you please HELP - CODY STELLER MINE IS A 4 GIGA BITE MP4 PLEASE HELP ONLY
Sep 01, 2008 | Kaser Corporation Mambo Mano Digital Media...
Gigabeat Will Not Turn On - Battery Flashes Then Goes Dead
I called and they told me,i have the same problem, to just turn the battery switch ( bottom thing) off and charge it over night via wall outlet. hope it helps im trying it as i type so i wouldn't know...
Jul 29, 2007 | Toshiba gigabeat S MP3 Player
Wont stay on
I suggest removing the battery when plugging it to the wall outlet or are you trying to charge it? I think the one that is spinning is the hard drive reseat it then lets see what happens try to purchase a new hard drive if problem persists. please indicate also the status of the lights on your laptop ill reply with more steps when you've indicated everything
Mar 22, 2007 | Dell Inspiron 1100 Notebook
Philips HDD082 MP3 Player Logo
69 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
