Question about Kitchen Ranges
Trying to change out door hinges on Maytag CRG9700BAL gas range and can't get the cooktop up to gain access to side panel screws in order to gain access to the hinges.
Does the cooktop flip up like it does on electric ranges?
Posted on Sep 05, 2009
    Sergeant:
    Champion:
  • 205 Answers
Hello sir/mam
the cooktop will be having push locks so that it will be locked as we press it so to remove this using a screwdriver give a light pressuer to the bottom of the top.
Posted on Sep 04, 2009
I am trying to remove the door panel to clean it a maytag gas range model mgr7662ws
tip out till it wll hold itself open then lift door off remove the screws around the outer edge and separate carefully the floor works best .clean and dry very well as any moisture in there might make it explode when heated . reassemble and put back on hinges carefully . LUCK be with you and don't forget to vote
Apr 30, 2016 | Maytag Kitchen Ranges
Oven door dirty between glasses
Usually there is a spot right before close that the door wool slip off the hinge. On some models you use a nail to hold it on place some have a special hinge. After that the door comes off and a few access gives you access to the inside panel
Sep 13, 2014 | Maytag MES5752BAW Slide In Electric Range
Broken door hinge on Stoves 900dfa oven
STOVES 900DFa - how can I download the USER MANUAL and the TROUBLESHOOTING and MAINTENANCE MANUALS
Dec 30, 2012 | Stoves 900DFa Dual Fuel (Electric and Gas)...
How do i take replace to outer glass panel on a maytag gas range
Here is a step by step on door glass repair:
1) open the oven door and look at the hinge on each side, there should be a moveable part sort of near the middle of the exposed part of the hinge. This is the hinge lock, or stop, whichever you prefer.
2) flip the hinge locks in place.
3) with the locks on place, try to close the door slowly. you'll notice that the door will push upward.
4) when it does this, you can now lift the door and remove it from the rest of the machine
5) To access the glass you going to have to take all the screws pretty much, making sure you remember where and how each one goes
6) now the door should come apart and you have access to the glass
****Note that there are a great number of makes, models, etc. This is a general instruction, and some extra steps may be needed ****
May 11, 2012 | Maytag Kitchen Ranges
Hook up oven door on maytag gas range
You likely need to lock the hinge in open position to do it. Either there is a small lever on the hinge itself you need to flip when the hinge is in the open position or there is a hole in the hinge, where you need to insert a steel pin (you can use screws, but they bend somewhat ;)) to hold the hinge open
Mar 04, 2010 | Maytag MGR5875QDS Stainless Steel Dual...
Ordered a replacement handle for oven door, trying to figure out
Open to the first hold area, where you set the door to broil. Lift off the hinge bars.
Jan 21, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
DRYER FIN IN DRUM IS COMING LOOSE
Unplug the dryer, remove the door hinge screws that go into the cabinet and the two screws on the opposite side of the door opening, then the front panel can be removedby starting at the top. Once the front is off, there are two screws, one to each side that hold the top on, remove these and raise the top. You can rotate the drum by hand and the baffles are held on by the screws on the outside of the drum. Reassemble in reverse order.
Jan 06, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
We are trying to find out how to remove our oven hinges to replace them.
not easy dte door lifts off srtaight up, the side panels must come off then you can remove hinges
Dec 24, 2008 | Maytag MGR4452BDW / MGR4452BDQ /...
Cleaning ge profile convection microwave
HI HERE THE STEPS TO DISASSEMBLEA gas range cabinet comes apart very easily. Here's how:
Step 1: Take out the screws that hold the panels, and pull off the control knobs. On the control panel the knobs are friction-fit; pull them straight off. Some knobs may have setscrews in the base of the knobs; back out these screws using a screwdriver or Allen wrench and pull off the knobs.
Step 2: Remove the back service panel on the control panel by backing out a series of screws around the edge of the panel. To remove the front panel, take off the control knobs and remove a series of mounting screws that hold the decorative panel to the frame. These screws may be hidden by molding or trim; pry off the molding or trim with a screwdriver, or take out several screws.
Step 3: To gain access to the burner assemblies, remove the burner grates and then the top of the range. The entire range top should either lift up and off the range or open up and back on hinges. The oven door can usually be removed by pulling it straight up off the hinges on both sides of the door. Some hinges have a latch that must be unlocked before the door can be removed.
Step 4: If the surface light of the range burns out, remove retaining screws and panels as necessary to gain access to the bulb. Replace the burned-out bulb with a new one of the same type and wattage; check the ends of the old bulb for this information. Then replace any retaining panels.
Step 5: If the oven light burns out, unscrew it and remove it from the oven. Replace the burned-out bulb with a new one of the same wattage, made for oven use.
PLEASE RATE IT.........................
Nov 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Cant get oven to work
hi Step 1: Take out the screws that hold the panels, and pull off the control knobs. On the control panel the knobs are friction-fit; pull them straight off. Some knobs may have setscrews in the base of the knobs; back out these screws using a screwdriver or Allen wrench and pull off the knobs.
Nov 06, 2008 | Maytag MGR4452BDW / MGR4452BDQ /...
Kitchen Ranges Logo
80 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
