Question about Sony WEGA KD-34XBR970 34" TV
Sony wega wont power on. unplugged and tv fades on audio and video then video goes out audio continues for a few seconds then tv switches off and red stand by light blinks 6 times.
  • 11,896 Answers
It is likely the power supply may have faulty capacitors inside which is quite common.
Posted on Sep 04, 2009
I turn on my KDF-55WF655 Sony TV. The green power light flashes about 10 seconds and then the picture fades in to full intensity for about 305 seconds then goes blank. The green power led flashes about...
If lamp has not been replaced in tv in last 2-3 years, then replace the lamp as symptom shows that lamp has reached to end of its working life span and causing that problem.
Lamp is not dead or broke but weak so you get above said problem in tv.
Thanks.
Oct 05, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Wega KV-XF21M83 21" Color TV red LED flashing two times
mt sony trinitron power light is blinking from green to red twise and then pause for 3 seconds and then blinks again from green to red
Jul 05, 2009 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
Sony 50 Wega LCD flashing red light
Hi
How many times is the red light flashing? The number of times the red led blinks means---
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
  • No blinks(Unit is dead) - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 01, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
When switching the tv on onlypower/standby red light comes on not
How many blinks when its red ?
The blinking is a code from the microprocessor telling why it's not turning on.
Apr 12, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
SONY GRAND WEGA KF-50WE610 can't turn on TV screen.
Ths 5 blinks usually indicate an AKB problem. There is a break in the video path. I'll look up your specific model and post the results here. Please update this if you wish to attempt the repair yourself.
Thanks,
Dan
Mar 19, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony KDF-50WE655 will not power up. Red blight blinks 4 times
4 blinks shows problem either one or all 4 fans are not working AND internal temperature high error.
If you are familiar with TV repair and know basic electronics then unplug TV from AC outlet an take off back cover and check fans are running?
Jan 27, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony wega trinitron won't turn on
  • and some times the eprom ic is fulty ...
  • try to unplug your tv from the main power for 5 hours then press the power button and keep pressing for 7 seconds then release ,if this do not work ,you should take your tv to a qualified person
  • i hope this helps ..
  • Jan 01, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
    Sony Trinitron WEGA 20" Problem
    change the tact switch of tv/video coz its deficteve.
    Sep 30, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
    SONY LCD GOES OFF
    Try turning the tv off, then unplug the tv from the wall for at least 60secs. Plug it back in. Turn it on and see if the blinking has been reset to normal.
    Jun 03, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
    Sony WEGA  KD-34XBR970 34" TV Logo
    107 people viewed this question
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
