Question about Samsung Syncmaster 275T Monitor
I just got a SyncMaster 275T a few days ago & can't seem to get DVI setting working.When I plug in the DVI cable the Monitor shuts down in few seconds so I'm forced to use the 15 pin cable (RGB).I'm using the Cable supplied by Samsung.Using the GeForce GTX 275 video Card.
  • 58 Answers
There may be a switch to select between HD output or DVI. look around front & back.
Otherwise, sounds like it's RMA time for your nice new monitor.
Posted on Sep 04, 2009
Samsung Syncmaster 305t Not displaying full resolution with Dual Link DVI cable.
2560 x 1600 at 60 Hz support . if may v sync 75Hz need to check the adjust.
Nov 05, 2015 | Samsung Computers & Internet
P2770h monitor flickers. progressed into the monitor shutting down after a few minutes. the monitor power on light flashes in a slow dim.
Is this happening while your are playing games or you are doing a specific task? If not try to change your connectivity cable (HDMI or DVI)
Aug 28, 2013 | Samsung P2770H SyncMaster Widescreen LCD...
Samsung syncmaster 275t won't start - what to do?
The Samsung monitor is okay, the problem is a compatability issue between the laptop and monitor. The VGA toDVI is the problem you are converting a analog signal to digital, the signal level degrades when that is attempted. If I understand this the laptop puts out the analog signal "VGA" and the monitor has the DVI input, "digital" The only other suggestion is turn off the laptop screen to see if the monitor will work.
Apr 04, 2012 | Samsung Syncmaster 275T Monitor
Respected sir, I have a samsung B2330 lcd monitor connected to GTX 460 graphic card through a hdmi cable. Since few days, my monitor turns off and on momentarily and randomly and it happens only once in...
Try using a different HDMI cable. If issue persists, try using the DVI port and a DVI cable. If not then try removing your video card and just use the on-board video option of your PC. If issue persists, try a different monitor.
Jan 22, 2018 | Samsung SyncMaster 540N 15" LCD Monitor
When I turn on the computer and the monitor, the monitor does not recognize a signal from the computer. I have tried restarting the monitor and the computer, unplugging all cables including the power...
kkjsr00, You must narrow down the faulty component!!! You must prove what is working and what is not working!! Beg, borrow, steal a "known-good" monitor to prove your pc is operating perfectly and will display the WIN-desktop screen on it. If your pc is A-ok then visit this web blog:
http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ kkjsr00, when strange and weird stuff starts to appear on the screen of "cold-cathode-fluorescent-lamp" back-lit lcd displays the first place I would look at would be the units internal "switch-mode-power-supply/ccfl inverter supply".. No, No, No, unit not going to sleep!!! SMPS/inverter going into SHUTDOWN mode having detected a fault condition with itself or other circuit and is trying to save itself from catastrophic, nonrecoverable failure. e.g. smoke, fire, burn down house, etc. Do some reading in my profile and those of other fixya tech's and you will find more than enough info to help with your problem. Good luck with repair of "flakey" solder joint or bad electrolytic filter capacitor PLAGUE problem. Yes, you sure have a lot of reading to do!! 12fixlouie or old file is louie12fix also try "buddymc" , "budmrtn" profiles for more info.
Apr 26, 2010 | HP w2207 Monitor
Cannot get a picture when using DVI cable on my
Check on the monitor OSD the input settings. I am assuming you're not running both inputs simultaneously some monitors detect that since it is an "either or situation"
in rare circumstances it could be the cable as well. Samsung SyncMaster 226CW Owner Manual
Nov 25, 2017 | Samsung SyncMaster 226CW 22" Monitor
Faulty VGA input
It is uncommon to have a faulty VGA input, although occasionally the pins get bent or broken on the cable. First check the cable.
Have you tried using a different source?
Some graphics cards/computers will only output DVI and VGA separatly and not at the same time. You may have to go into the display settings of your computer and change the output from DVI to VGA.
More details would be great,
Thanks!
Jan 15, 2010 | Samsung SyncMaster 226CW 22" Monitor
Samsung Syncmaster 760V TFT monitor & LED is blinking on and off!
put the monitor upside down till it comes on works for me anyway
Sep 07, 2009 | Samsung SyncMaster 760vTFT Monitor
Samsung Syncmaster 275T Monitor Logo
264 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
