Question about Refrigerators
What is the difference in temperature controllers between a fridge & a freezer? Can they be interchanged?
  • Mainetech May 11, 2010
    It really depends on the brand, model, style, etc of your unit. most units with conventional knob controls only measure the temperature in one compartment and control the other with airflow. If you have computer control, then we start talking about thermistors and you cant tell by looking at them if they have the same specs. If you can give some more info on what you are trying to do, maybe I can point you in the right direction
    Novelist:
  • 101 Answers
Refrigerator and freezer temperature controller can-not be interchanged (normally). They have a designed range of operation. Such as...say the refrigerator thermostat has a range of 45 degress at the warm setting and 33 degress set at maximum cold. This would never work for the freezer. Some electronic devices have ways to change their setting range but that is specific for each control.
Posted on Sep 12, 2009
My double door galaxy (5 year old or so) seems to be at the right temperatures but the control reads 56 degrees for the freezer and fridge
Get a thermometer for both fridge and freezer to ensure temps are correct. Freezer should be around 0F and fridge around 37-38. If temps are correct but display is reading that much differently, control is most likely bad.
Sep 08, 2017 | Galaxy Refrigerators
What is the ideal setting for fridge on Bosch KGN34VW20G
Hello John;
My name is Peter. I am a retired Sears service technician. The freezer temperature should be between -2 & + 2 degrees F. The fresh food section should be between 35-40 degree F.
Pick up a inexpensive temperature gauge with a steel shank. Place the temperature gauge in the freezer center. Do not make contact with any food product. Allow 20 minutes and read the gauge. Be quick the temperature on the gauge will drop quickly when you remove. Adjust the temperature control knob according until you reach the desired setting. Repeat this process as necessary. Do the same for the fresh food section.
You only have one source of cooling; the evaporator coil and fan in the freezer. The freezer will meet it's temperature setting first before it opens the fresh food section damper.
A balanced system will save on your electrical bills. The compressor will kick in only when demand is met. Your compressor should not be running continuously.
Oct 23, 2014 | Bosch KGN34VW20G White 280 l Fridge...
Re: Lights and fan problems for Sub Zero 532 Side by side refrigerator.
First of all if you're condensor motor is controlled by electronic control board varyable speed type you might want to think about looking at replacing the control board. But first I would take a voltmeter test to see if the fan motor is getting enough voltage. If the voltage varies with the temperature inside the box then you have a controller. If the voltage remaind constant (120) and the motor still slows down yoy have a bad fan motor. As far as you're like the problem goes the only thing I can think of besides loose wires or bad switch.would be if it operated off the same control board.
Dec 10, 2012 | Refrigerators
Fridge section not cooling enough but freezer OK
Is the fan blowing in the freezer section? Also, check to see if you have airflow thru the damper (vent) in the frig section.
Mar 31, 2012 | GE GSL25JFPBS Side by Side Refrigerator
The fridge & freezer has started to get warm it was 8deg above the recomended temperature & then the light starts to flash,we have cleaned all around it,taken food away from the outlets in the...
it can be a defective thermistor,a defective cold control or compressors short cycling(not running long enough) or the evaporatorin the freezer is frozen up and cant keep temps constant
Aug 03, 2011 | Refrigerators
My F&P fridge (F/E372BRT) recently gave out a loud alarm recently, which i stopped by pressing one of the temperature control buttons inside the fridge. However the green lights now flash inside the...
It is best to consult your users manual first as controls are like humans nowadays. They are all different in programming features.
You may have set it for an illogical temperature or a component malfunction may have occurred and the alarms alerted you to that with an error code display. No error code =no malfunction and more than likely means a human error was made.
Oct 15, 2017 | Fisher and Paykel Refrigerators
F & P E4028
A bad thermostat. Your cooling is out of control it is the thermostat that controls the frig. The thermostat is behind the knob that lets you turn up or down the temp. Most of the time two screws to take loose behind the knob. It should just pull off.
Dec 15, 2009 | Fisher and Paykel E522BRXFD Stainless...
Refrigerator temperature running too high
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 03, 2009 | Whirlpool ED2FHEXN Side by Side...
Faulty Freezer & Fridge
You have a defrost or temperature control issue or both. I will be back soon with photos and solutions. Thanks, Sea Breeze
Jul 13, 2009 | LG LRTBC1825T Top Freezer Refrigerator
Fridge compartment is not cooling down to set temperature
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Jul 08, 2009 | Refrigerators
Refrigerators Logo
62 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
