Question about GE 30 in. Profile JP938 Electric Cooktop
Won't work, error code f152 keeps popping up.
  • Michael Motley Sep 04, 2009
    Thanks for the advice, you gus are awesome, I will try your advice
  • Michael Motley Sep 18, 2009
    Do you mean the main logic board asm?, or do you mean the display board? plus you have the power board ??? I'm an independent appliance repairer, and I will need to order the right parts and to the customer f152 error,the unit won't reprogram
  • 3,230 Answers
Press Clear/Off and reprogram control, due to shorted key panel membrane switch; Check Electronic Control by opening the control board. If code reappears, replace control.
Post further comments for more information.
Good Luck!!
Thanks
Posted on Sep 04, 2009
  • Mukesh Kumar Sep 18, 2009
    Well i mean the main logic board. you can order that part from the GE dealer or order it from GE site.
    Thanks
E9 code error pops out and flashes.. what does it mean and how to fix this? Since it came on,cooktop not working at all.. Hope to get some help
I had a look and all I found was for a Prestige cooktop?? E9 apparently means a failure of one of the temperature sensors but not sure which one... Sorry.
Jan 05, 2015 | Cooktops
I have a glass cooktop Electrolux which is only 2 years. stopped functioning with a E-11 error code and cannot ulock. what can Ido?
Hello Gloria Padilla, thank you for your post!
I understand that your Electrolux cooktop is displaying an error code "E-11" and will not allow you to operate. The "E-11" error code stands for key sensor in cook place four. This could mean a possible issue with your flex cable, right board, or left board. I see you have completed a reset on your cooktop, at this point I would recommend having a professional technician for a proper diagnosis to be completed. I hope this information is helpful. -Matt
Dec 29, 2014 | Electrolux Cooktops
Frigidaire error code stove f 15
F15 Controller self check failed. Replace the EOC.
Here's the code explanation
Sep 06, 2014 | Frigidaire Gallery 30 Slide-In Electric...
Electric range
Good Morning Kent, thank you for allowing me to assist you!
Typically error code F1 on your Frigidaire appliance indicates that your range has detected an issue with the runaway temperature (overheating). One of the best ways to determine if this is a false error code is to reset the power to your appliance by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, at this moment I would suggest connecting a professional to proceed further. Most likely the EOC (Electronic Oven Control) or RTD Probe (Resistance Temperature Detector) will need replacing. I hope this information helps to some degree.
Feb 05, 2014 | Frigidaire Stove/Oven/Range White Cooktop...
I was boiling water for potatoes on the Electrolux induction cooktop last night. Only using one of the five burners when I heard a "pop" sound and possibly a flash of light. Error code we have is EO
Hi Gail, I am happy to assist you!
It appears the main control has detected a faulty or error condition. "E0" should be followed by two more digits to indicate which error has occurred. Let's try turning electrical power supply off. It is necessary to wait roughly ten minutes to reset cook-top main controls. If resetting the power does not correct the issue or provides a new error code, at this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts.
Dec 20, 2013 | Electrolux 36" Electric Hybrid Induction...
F35 ERROR CODE
had exactly the same thing happen; did you figure it out?
Would like to know if you had a big fee as won't bother if it is expensive to fix! Thanks Emma
Jun 16, 2013 | Miele KM 5753 Stainless Steel Electric...
Cook top flashing code f152
replace the burner RT/FRONT
May 26, 2013 | General Electric Cooktops
GE profile JP939 flashing F152, how do I fix?
F152 means the right front burner has failed, the sensor in it is bad, the burner will need to be replaced. If you go to the following web page, and pick out your exact model number, you will see diagrams and parts lists that will help you get this fixed. You can order the element from that website, if you choose: http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JP969 Good luck, and hope this helps.
Nov 28, 2010 | GE 36 in. Profile JP969 Electric Cooktop
Cooktop keeps blowing fuses. when we hit the
you will have to remove top and find short . it sounds like a burner of melted wiring. .. also ck the swithces for dark connections as the could be the cause. mm
Jun 30, 2010 | Maytag MEC5430 Electric Cooktop
Kenmore Elite Induction Cooktop Error Code 41
I realize this is over a year old. I have the same unit with the same error code. Last night, mine made a popping noise followed by smoke and then displayed the 41 and all E's. I pulled the breaker immediately. I'm sure that at least one controller board is toast.
I called Sears and it is under warranty but for parts only, so I guess I will give them a call and schedule the repairman. This should be fun.
Anyone else experienced this failure??
Feb 01, 2009 | Kenmore 42800 Stainless SteelCooktop
GE 30 in. Profile JP938 Electric Cooktop Logo
310 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
