Question about Refrigerators
Water not filling the icemaker - Refrigerators
  • Dan Webster
    Dan Webster May 11, 2010
    Captain we have a probo. What is it Spock? The lounge is out of ice. Get McCoy on it right away, Dammit Jim I'm a Doctor. Captain the dilithim crystals are melting fast! Shes breaking up. I dunno how much more she can take. O'hura get on the horn to starship command. get em to send us a water valve right away. And tell em to send a water filter. Mr Checkov I need 2 fingers neat, if you pwease and a MANUAL
  • 358 Answers
If the ice maker is working but when stops to call for water doesn't get any , it could be the water supply line is turned off , or the solenoid (electric valve that lets water into the ice maker when it needs) went bad .
Posted on Sep 04, 2009
  • 725 Answers
This sounds like your water valve is bad. Call us with brand and model number and we will send the correct part to you. Hope this solves your problem.
  • Ella Watson
    Ella Watson Sep 04, 2009
  • Ella Watson
Whirlpool side by side with water and icemaker. My water works perfectly fine but my ice maker no longer produces ice. It runs but it's not getting any water to make ice. What can be done to fix this?
There are a couple reasons your icemaker will not fill with water.
First thing you want to check for is a frozen fill tube to the icemaker. The easiest way to check for a frozen line is to remove the icemaker. Once the icemaker is removed look for ice in the fill tube. If there is ice in the tube the (water valve) will need to be replaced. You can melt the ice by forcing hot water up the fill tube.
Another reason could be the icemaker is not sending voltage to the water valve. The fix for this issue is to replace the icemaker. Hope this helps you with your whirlpool fridge!
The reason to change the water valve with a frozen water line is because the solenoid is not closing all the way. This allows water to enter the fill tube of the icemaker and freeze based on the temperature.
May 04, 2017 | Whirlpool Refrigerators
Serial # k15004707 model # mf12665xew3 french doors ice maker in upper left corner. After the ice maker fills with water it drips off the front side.
Refrigerator Leaking From Icemaker
If it's leaking from inside the freezer then it's coming from the icemaker or the drain. Lets start with the icemaker. If it's the icemaker there will likely be an ice hanging from the icemaker or just a big block of ice in the ice bin. In any case, it will be obvious.
There are a few reasons this will happen: one is the icemaker will stop turning when it gets to the fill cycle. This will happen when the gears in the icemaker break. On GE icemakers that were made before the year 2000, you can see the gears by taking off the cover on the front of the icemaker. However, if the small gear is broke you can't buy it as far as I know. I have been taking them off of junk icemakers for years. So this part may be hard to find. But if the big gear is broke replace it. Another reason icemakers leak is the fill tube is stopped up and I already discussed this earlier (replace water valve and clean out tube).
Another reason icemakers leak is that the water comes in too fast so it over fills the first cube mold. When this happens you will get a few drops of water when it fills. To fix this you have to take the icemaker out and remove the piece on the side of the icemaker. I don't know the name of it so for this we'll call it cube separator because that's what it does (most of them just snap off others have a screws). Now take silicone (RTV) and put a small amount around the first cube mold only under the cube separator. Now reinstall the cube separator and wipe off excess silicone and it shouldn't leak anymore.
Another reason that icemakers leak is that the refrigerator water valve sticks after the icemaker goes out of the fill cycle. When this happens the valve stays on and the icemaker keeps on turning, in which case, replace the refrigerator water valve.
May 05, 2015 | Maytag Refrigerators
Frigidaire icemaker still overflowing after replacing inlet valve
Make sure the water is not splashing out the fill tube rather than the icemaker. Sometimes ice forms in this tube and causes the water to shoot over the tube and run down. You could also try turning the water faucet valve down a bit. Your water pressure could be too high and it is filling too fast. Last thing if you have very hard water the cubs could be sticking in the mold tray and not releasing. When the icemaker fills again there is still ice in ther causing the icemaker to overflow.
May 17, 2014 | Refrigerators
My side by side refrigerator is making a buzzing noise from the ice maker area every few minutes
That sound you here is the icemaker calling for water to fill the icemaker but not water into refrig to fill icemaker. If you have no water connected to icemaker,lift up and lock arm into place to turn off icemaker,if you do have water line connected but no ice is being made need to see why water from house plumbing is not coming into the refrig.
Gene
Aug 11, 2011 | Frigidaire Refrigerators
The water fill tube for the icemaker is blocked.
Replace the Dual water control valve found on the back of the refrigerator near the floor with a new one and thaw out the entrance where the water goes into the ice maker. Provide a model number found on the inside of the fresh food compartment wall and I'll try to help you find the correct part number for the water control valve. The water control valve is apparently leaking like a leaky faucet and it's freezing causing the problem
Apr 03, 2017 | Whirlpool Refrigerators
Ice tray dont empty and water keeps running out
Something caught inside the water valve (replace water valve ) such as dirt , sand . Or , the icemaker died in the fill position . Disconnect the icemaker plug inside the freezer , and see if water still runs from the icemaker fill tube . Also make sure the icemaker fill cup on the icemaker , is not clogged with ice .
Sep 07, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice maker stopped working
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig .
Sep 05, 2009 | KitchenAid KSRP25FNSS Side by Side...
Replace selenoid and water is still not going to ice maker
Did you pour about 2/3 cup of water into the icemaker and did it dump ? If you did pour water into the icemaker , and it did not dump the cubes , then the icemaker is bad . If it did dump , so you replaced the water valve , then the fill tube directly at the icemaker is frozen with ice . It will need to be removed ( fill tube at icemaker ) and the ice cleared out by hot water . On some models , behind the refrig , 2 screws hold the fill tube in place . Remove the tube , and clear the ice . When reinstalling , have someone guide it from inside the freezer , to where it mounts on the icemaker fill cup .
Aug 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Sub-Zero 632 Ice Maker Leaking into Ice Bucket
Ice Maker is overflowing and leaking into the ice bucket: There are several things to check for.
Go for the easy stuff first, make sure the icemaker is level, some of the plastic liner fridge's will move and allow the icemaker to tilt over and leak. Other troublemakers..... the fill valve
staying on and over filling the icemaker..... the finish sometimes comes off the icemaker body and all the ice cubes don't come out. This will allow the new water to fill on top of an icemaker
that still has a ice cube or two left inside the body, if you have had trouble with black specs in your ice cubes, this may have been the beginning of your finish problem on the icemaker body.
On the module style ice makers (Whirlpool, Maytag Family, Sub Zero) the printed circuit in the
module head often wears and the contacts become too long and allow the icemaker to over fill = new ice maker or new module head.
Older style icemakers: This gear is bad for breaking and the icemaker quits turning to eject the ice.
You can remove the front cover to see the gear.
This is a common parts breakdown of the older style icemakers
Water fill volume: The water fill adjustment screw will change the fill volumes by changing the fill time.
One half to one full turn usually ( approx ) is equal to 20cc ( 0.68oz ) to 40 cc.
The correct fill is usually 130 to 150 cc ( 4.5 to 5.0 oz ).
When a water valve is replaced the fill volumes must be re-checked!
http://www.SubZeroLosAngeles.com
________________________________________
Sub-Zero Service Experts in LA Metro
Aug 15, 2008 | Sub-Zero 632 / S
Ice maker leaking water
replace the icemaker fill switch in the icemaker its self its a micro switch behind the gold panel on the front of the icemaker
May 03, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Refrigerators Logo
124 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
