Question about Toshiba Satellite A215-S7422 Notebook
No screen picture showing. will show with extende monitor
Find solition for monitor no screen display
    Problem Solver:
  • 15 Answers
Do yuo have an External Monitor to plug in and test ?
Posted on Sep 04, 2009
Can I use the AMD Radeon HD 7540D Integrated Graphics with 1 HDMI and 1 VGA to use dual monitors?
Hi Veronica,
Absolutely you can.
After you get the monitors hooked up and powered on, RIGHT click on the desktop...anywhere. Select "Screen Resolution" Once the display settings pop up, select "Detect". After you select that, you should have 2 monitors show up..one should say 1 and other should say 2. To Identify which one is which, click the "Identify" button and you should see a #1 and 2 on your monitor screens.
If you go down to where it says "Multiple Displays", that is where you can set them up to be extended, or duplicated.....Extended just means that one of the displays is going to be primary and the other display is going to be an extension of that. Duplicate is just that...both screens show the same thing.
Hope this helps:)
Thanks
Gary
Oct 28, 2013 | Computers & Internet
I have an Acer laptop approx. 2 years old. I am trying to show a folder from My Pictures on a InFocus in 20 series. Projector is up and on computer source. When I start up the computer, the projector...
You need to enable the 2nd video output in the video card settings!
right click on desktop select properties and select the settings tab
Select the monitor 2, click on extend my desktop to this monitor.
Then you can drag windows either out from your main monitor, to up, down, or the sides debends on where you set the 2nd display, you can also change the position of the 2nd screen by draging it around in the middle.
Aug 11, 2008 | InFocus Computers & Internet
Asus tf101 only half screen showing
you will need to connect to another monitor or your television to your computer with the vga lead monitor connection
click start control panel display change display settings adjust resolution this may vary depending on your operating system you should a no 1 and a no 2 with detect and identify keep an eye on
the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes
you should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system
or click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes
if you can get an extended desktop your monitor is faulty
if you cant get an exended desktop
hope it helps
Jun 22, 2012 | ASUS Eee Pad TF101B1 Tablet
A few months ago my screen started distorting the picture now and then, and then would revert back to being fine. Now it stays mostly like that. I have it set up as an extended display from my laptop. I...
The resolution for the extended display could be wrong or on a setting the monitor cannot display. When you tell the computer to extend the display their should be a resolution drop down. Change it for the extended display monitor ( Click Advanced Display Settings or you may have to click the second monitor to see the resolution for it)
Jun 01, 2017 | Acer AL1912 19" LCD Monitor
Second display shows only blue blank screen but I can see the pointer
This is an extended display. You can move open windows, icons, or folders over to the second screen. This is called a dual-monitor setup. You can also set the second monitor to duplicate what your primary monitor is showing.
Feb 27, 2011 | Tritton Technology TRI-UV150 Video Card
I just got the Gigaware 2 port usb powered vga splitter and I have ywo monitors connected. Both monitors show the same thing but I want to extend the desktop across both screens, however Windows XP does...
A display splitter will only mirror the screens, you cannot extend the desktop via a splitter.
Most portables cannot support dual monitors without a docking station.
Jan 07, 2010 | Computers & Internet
I'm trying to hook up my pc to my tv ( it's hooked up right, & my screen saver picture is on the tv screen, but not the desktop icons, & I can't get anything else on, I pressed tne Fn & F5 key...
If you see something coming from your PC on your TV, you're almost there!
When you hook up a monitor to your laptop, there's two ways it can work. It can show the same image on both displays, or can "Extend" the desktop on to both screens. In the extend mode, you can have different things on each screen.
Here's what you do to see which mode its in:
- On an empty spot on the desktop, right-click.
- In the menu that comes up, choose Display Properties, or Screen resolution.
- This will bring up the Display properties.
Here's where you need to look to get it configured properly.
You most likely will see two boxes in one area. One will have a number one, the other a number two. If number two is one the right of number one, this means that your display is being extended to the right of the number one monitor. You can verify this by moving your mouse PAST the right edge of the screen. When it goes past, it should show up on the other screen.
Nov 10, 2009 | Toshiba Satellite A100-S8111TD Notebook
Does the LB 23" monitor not have the capability to allow me to view one file on the LB monitor and another file on my notebook monitor?
It is not a question of monitor capabilities, it's down to what the video driver on your laptop is capable of. First try to make it show video on both monitors - usually it's Fn + function key that has "crt/lcd" on it or an icon of a display hotkey pressed once for laptop only, again for both, and again for external only) and then play with the desktop settings to have the desktop extend to your external monitor, instead of showing the same picture on both. Then you can move an application window out of your notebook screen to your external monitor.
Oct 24, 2009 | LG Flatron L2320A 23" LCD Monitor
We have the monitor hooked to a docking station for a laptop. I can not view the screen on the Viewsonic, but does display on laptop. I have been able to do an extende monitor view, but not the main view....
when you connect external monitor to a laptop u get two options in the monitor section of graphic properties tab
1.) extended
2.) clone
it is clear from ur post that u are using extended view
try using clone mode then both laptop screen and external monitor will show the main screen
other method is to disable the laptop screen and just allow external monitor to work, in this case laptop screen shows nothing but external monitor shows main screen
Sep 29, 2009 | ViewSonic VG700b 17" LCD Monitor
Monitor
I was trying to change the resolution on my monitor and accidently hit a button saying 'Extend screen.
Dec 14, 2006 | Philips 105S51 15" CRT Monitor
Toshiba Satellite A215-S7422 Notebook Logo
42 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
