Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Lawnmower will not engage blades
I have a Great Dane ZTR lawnmower. Ocassionally, after I have been mowing for a period of time and then cut the blades off, they won't engage until the mower has sufficient time to cool down. The blades are activated by an electric clutch. The dealership where I bought the mower is flooded with idiots that can't figure out what the problem is. Mowing is a considerable part of my income and this little problem is beginning to drive me crazy. If anyone can help I would be very appreciative.
  • mark groves
    mark groves May 11, 2010
    Hi Have they adjusted the electric clutch at all, If not heres how to adjust it, First of all you will need a 10 thou feeler gauge now on the side of the clutch you will find 3 holes put the feeler gauge in and check the clearence if it is too wide you can adjust by tightening the three nuts on the outer edge but you have to adjust and check all 3 sides. If this does not work then i would be looking at the amperage/volts system on the engine it may not be producing enough when hot.
wadembly
  • 448 Answers
SOURCE: Sears lawn tractor. While mowing, ran over a
the branch probably got cought in the belt that runs the rearend it may have caused it to come off check the drive belt
Posted on Jun 06, 2009
wadembly
  • 448 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
SOURCE: LTX1000 42" 18HP Kohler - Blowing fuse after 2-4 min mowing.
i hav a 18hp ohv eng. back fires and gas is coming out of muffler.
Posted on Jul 18, 2009
  • 32 Answers
SOURCE: How do I get my mower deck set properly? Any tricks?
check your front tire air pressures
Posted on Jul 26, 2009
cjrepairs
  • 60 Answers
SOURCE: My lawnmower quit mowing.
It depends on whether its a lever or pushbutton engage model? it may be a broken belt or a simple wire connection come loose. If you want to stay friends tell them mowers are repairable/replaceable but friends arent!
Posted on Aug 16, 2009
My blade will not stay engaged to mow. how do I fix the problem?
When you say will not stay engaged you are saying that it comes on then cuts off ? If you turn on the PTO and it engages and the mower is not moving does the PTO stay engaged and for how long (if OK then need to check connections for PTO ) . If it is not engaging at all then we have to look at interlocks / safety switches . Give me some Details
Apr 18, 2016 | Husqvarna Rz4623 46" Ztr Lawn Mower Zero...
My riding lawnmower blades will not disengage or engage Now my lawn mower will not start
just replaced some pulleys on my craftsman 42 inch cut and now the blades are ingages all the time, but it will start
Jul 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My craftsman lawnmower dies when i let out on the clutch
make sure your not in reverse with the blades on. if so turn the key left to mow in reverse mode. else check pullies.
Jul 06, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
To mulch my grass clippings, do I have to use the side discharge or can I simply remove the bag and insert the rear plug?
Insert the rear plug if mulching is desired. The key to mulching is to mow the lawn frequently.You want to keep the mower deck height high enough to cut the grass and allow the mulching blades to work, but just low enough to actually cut the grass in a smooth uniform height. To low of a cut setting will clog the mower and create a mess. 2 times a week is a good frequency to start with.
Jun 10, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
Blades slow down when cutting deck is lowered.
the lowerer the deck the more your working the mower. either mow more often or reduce speed
Oct 22, 2009 | Garden
Aug 16, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have a husqvarna 172 ride-on lawnmower. Running
This unit probably has a safety switch built into it and it could be below the gas tank. If this switch isn't adjusted properly then it's designed to cut off the motor. I think you should concentrate on that before attempting anything else.
Aug 02, 2009 | Garden
Swisher lawnmower wont mow
Yes It would. The belt doesn't just wear it slackens also. It will probably turn the blades when not under load but as soon at it attempts to cut grass there is not enough grip.
Replace the belts first and it should be fine.
Regards
Marc
Apr 17, 2009 | Swisher 60" 13 Hp Trailmower #T1360h
JCB LS45 lawnmower - 2 stroke or unleaded petrol??
JCB LS45 specs Manufacturer: JCB
Blade Length in cm: 42 cm
Blade Width in cm: 40 - 44 cm
Cutting Width in cm: 42 cm
Electric Start: with Electric Start
Grass Collection Bin: Back
Horse Power: 3.5 hp
Mowing System: Rotary
Power Supply: Petrol 2 Stroke
Type: Walk behind mower
Apr 04, 2009 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
188 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
