Question about Xerox Office Equipment & Supplies
I have a problem with my XC1020 copier. When I install a new toner it will make a few copies but then quits. I have tried 3 new toners so it must be something wrong with the copier that keeps knocking the toners out. Am I wrong or what?
    Problem Solver:
  • 15 Answers
Turn machine on hit clear button and hit exsposure button and then clear button and then exsposure button (fast) the display will go blank. type in 24 start 7 start. type in 14 and then start. then type in 16 start. turn machine offf and then on.
Posted on Sep 08, 2009
Canon ir3320i. Just had this machine installed 3 days ago. Had the toner replaced as I was told machine from factory usually have minimum toner in them. Today, after about 80 copies, there's a blank line...
Most new printers come with alignment paper. Were the printer heads aligned after instillation? Aligning the heads will use quite a bit of ink, so have some handy to replace if needed.
Feb 08, 2014 | Office Equipment & Supplies
Its me again,after the user changed a new toner cartridge after few copies there is a dark back ground in copy.before replacing the toner the copy was perfect pls help me in this problem
Hi, After a few copies, the toner supply unit pulls more toner, which results in dark copies. To fix this, you have to reduce the contrast (to minimum). Also, make sure that there is no excess toner within the toner supply unit.
Hope it helps! Good Luck! Thanks for using Fixya! CreativeTECH
Sep 27, 2011 | Panasonic Workio DP-4530 Copier
Where can I find supplies (Drum and Toner) for old Xerox model XC1020
The black toner cartridge is available through Amazon.com http://www.amazon.com/Brand-Genuine-Xerox-Cartridge-Designed/dp/B003KIYZSC . This site has the drum: http://www.tonercartridgedepot.com/xerox-xc1020-3433-d.html .
Some other sites list the supplies but these list them as In Stock today.
I hope this helps.
Jul 08, 2011 | Xerox Office Equipment & Supplies
Streaks on copies on Xerox XC1020 which is 12 years old.
My Brother has been whining about a drum for over a year now, and still printing just fine. As long as it prints good, I say ignore it. If it stops completely, see if you can reset the drum counter to get it going again. These companies just want to get us to toss our machines as soon as possible. Google drum reset for your machine if you have to.
Sep 22, 2009 | Office Equipment & Supplies
Toner cartridge not loading
Cheat the front door interlock and watch the toner bottle to see if it is turning. If not, could be a bad toner drive motor/drive assembly. Otherwise, remove and disassemble the toner hopper and clean it up. Make sure the four clear 'scooper' tabs are attached on the back of the receptacle that fits around the top of the toner bottle. Otherwise, just purchase a new toner hopper, they are cheap.
Sep 15, 2009 | Ricoh Aficio MP 2000 Black and White...
Xerox 3001 Copier. I installed new toner and the
Paper must cover the center to hit the sensor. If paper still goes through without stopping, the paper drive clutch is faulty.
Aug 25, 2009 | Xerox 3001 Copier
Minolta copier 1030, changed toner makes no copies
take the toner bottle out. turn off the machine then turn it on with the bottle out. once the machine, ask for toner install the bottle.
Jun 18, 2009 | Konica Minolta Office Equipment & Supplies
Copier will not load toner
Did you install a new toner bottle? If so did you remove the pull tab or tape that seals the toner from spilling out. If it is a new toner that you know of, do you have another to install. It may be a defective toner. From what you explaining it sounds like there is no toner in the developing unit. Try antother toner first...
Jan 29, 2009 | Gestetner DSm515pfd Digital Copier -...
I have a Xerox xc1020. it will not work. when i turn it on it moans, and than will try and warm up for a long time. can you help me
Wait a minute. I just answered this question to your name for an M20.. On an XC1020, that is different. If that is moaning I strongly suspect the toner cartridge if it just sits there and chugs without faulting out. Could be the drum . If it were the motor on that machien it would fault out. Now it depends on the model.
If it is an XC1020, I very strongly suspect the toner cartridge.
Again, let me know,we will start at the toner and drum on that one.
Jan 22, 2009 | Xerox CopyCentre C20 Black and White...
Xerox XC1020 White Bands running across copied page 4" apart
The metering blades in those cartridges go bad and do not allow the ink to get to the page. Look at the front of the toner cartridge, is should be a solid consistent black all the way across, if its streaky, not consistent all the way across replace the toner.
The other problem could be a dirty laser. If replacing the toner doesnt work let me know, I will tell you how to remove and clean the laser.
Jan 16, 2009 | Xerox CopyCentre C20 Black and White...
46 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
