Question about Maytag Freezers
I have an Maytag upright freezer.Does it self defrost?if so how does it self defrost?Do you have to leave the plug and hose out all the time? model # is rfu1500aaw
  • Maytag Master
  • 1,606 Answers
This is not a self defrosting freezer . Remove the plug and hose ONLY when you unplug to defrost . You should defrost when the coils get about 1/4 " of frost (ice) on them . Otherwise , the frost will act like the plastic insulation on electrical wire , not letting the coldness freeze the food solidly .
Posted on Sep 04, 2009
Testimonial: "Thinks,that help alot.I didnt know for sure. thank you :-)"
How do you defrost upright freezer model no.fum 12smhrwh
un plug leave door open be ready for water coming from drain add longer hose to drain to reach out doors or in container shallow pan under it be ready to empty can take up to 24 hours depending how frosted up it is
Feb 13, 2017 | Freezers
Ice forms at the bottom very solidly Model: Maytag MQU1656BEW 15.7 cu. ft. Upright Freezer with auto defrust
check for a bad/ loose/dirty gasket on the bottom side ofn the door. check your drainage line for clogging on the defrost system for back up
Jul 20, 2011 | Maytag 20 cu. ft. Upright Freezer MQU2056B
I lost my owners manual. How do I defrost my upright freezer
they can be defrosted by using a blow dryer on the evaporator coil.or most common way is to remove all the product in the freezer and turn the unit off and leave the door open. most units have a defrost heater and they self defrost but if you are building up frost then you may need to check the continuity on the heating element and replace if need to. or check and make sure the defrost timer is working properly
Oct 09, 2010 | Frigidaire 11.6 cu. ft. / 328 liter...
Maytag upright freezer with self defrost. The water line freezes.
This sounds like your defrost heating coil has gon bad. Not much you can do but replace it. Please leave a good thumbs up for me for the effort. Pretty sure I'm correct on this one. The Raz Shack
Mar 11, 2010 | Maytag 20 cu. ft. Upright Freezer MQU2056B
I have a maytag upright freezer. It is on the coldest setting. A bowl of water on the bottom shelf freezes overnight. The middle one is freezing, but not entirely. The top one is still water, but cold....
check to make sure door seals are touching the frame all round, could be an air leak,also make sure there is no ice build up around the inside casing. if so fully defrost unit,clean all vents/drain pipe, then turn back on and leave it for 24hrs (freezers work beast when full).....and door shut..how many times have you closed door after them????
Mar 01, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
How can you tell by looking if a freezer is a manual defrost or self-defrosting type? Thanks
If you have freon lines running through your shelving, this is a manual defrost. If you have an evaporator fan motor blowing air in your freezer compartment this is a self defrosting model. Good Luck, Appliance Specialists
Jan 13, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
I have a maytag freezer does it self defrost?
If it has a fan in it, it's self defrosting. The moving air burns away the frost and 8 out of every 24 hours, the defrost timer will turn a heating element in the cooling coils, to melt away any ice buildup.
If it isn't a self defrost model, you can safely defrost it woth a pan of hot water. I also use a spray bottle woth hot water to help the process. DON'T use anything electrical to make the heat. Water can drip into or onto it and you could get electrocuted.
Sep 03, 2009 | Maytag Freezers
Frigidaire MOdel LFFU1765DW9 This is a commercial self defrosting model freezer, upright, and water leaks out of the bottom right side every so often. Why and what should I look for to fix it.
I have a frifigidaire freezer LFFU1765DW9 . it is not cold at all the light in side is on the power is on but the fan no run and the compressor is not run.
Help please
Jun 21, 2009 | Frigidaire Freezer Refrigeration White...
Freezer defrosted and the motor won't start back up.
From what I can gather, you have a self defrosting freezer and the "motor" you speak of is the fan inside the freezer. If this is correct, do this:
Unplug freezer. Unload all food into coolers or other freezer space. Leave freezer door open for a day to allow it to manually defrost. Plug freezer back in after minimum 24 hours and confirm fan running and cooling before loading back up with food.
Mar 28, 2009 | GE 16.7 cu. ft. Upright Freezer FUF17DTR
Upright freezer
no light in unit??? check the bulb, reason i say that is you should aa least have lights on, check the recepticle its pulgged into
Apr 06, 2008 | Maytag 20 cu. ft. Upright Freezer MQU2056B
Open Questions:
Freezers Logo
256 people viewed this question
Top Maytag Freezers Experts
John Tripp
John Tripp
christian nielsen
Ismael Rodriguez...
Are you a Maytag Freezer Expert? Answer questions, earn points and help others
