Question about Dynex 32 in. LCD Flat-Panel HDTV
I am looking for the owners manual for a dynex 32" television. after I complete the channel auto scan, it tells me to "please run auto scan" again.
    President:
  • 2,049 Answers
    President:
  • Dynex Master
  • 1,779 Answers
I believe you can get one through Best Buy. I think that is one of there tv lines they sell.
Posted on Sep 04, 2009
How do I run channel auto scan?
look in the main menu . has to find channels to get a picture
Jan 08, 2016 | Dynex 32 in. LCD Flat-Panel HDTV
Www dynexproducts com
go to MANUALSLIB.COM. ENTER THE UNIT # AND the manual will show up with the table of contents. Look for[ how to install antenna], the correct way is demonstrated with the jpgs. lol.
May 10, 2014 | Dynex Televison & Video
When setting up a new TV, it keeps telling me to "Please run channel auto scan." But it also states that if I sellect Cable/satellite, that the tv does not need to run the auto scan. When you...
you need to select cable from off your remote and run the auto scan.even if it says you does not need to run auto scan still run the auto scan.good luck.
Sep 25, 2011 | Dynex Televison & Video
Finally bought anRCA antenna for my new Dynex TV.Nothing no signal,no way to scan for channels I can see.AGGH.Is it a lemon?
Which Dynex TV do you have? The manuals for most Dynex TVs are available from the product page. Start at http://www.dynexproducts.com/products/televisions.html . If you have an older Dynex that isn't on the main list, check under Discontinued Products. Alternatively search for your model. Then click on the Support tab to find the manual for that model.
For at least one Dynex TV (DX-32L152A11), the procedure to scan for channels is below.
To scan for channels, first make sure that the current input is set to TV. (Press the input button on the TV or the remote). Then press Menu and use the left/right arrows to select TV. Then press Enter or down arrow (the manual says the right arrow). Use the up/down arrows to select the entry to change. First, make sure that the Tuner Mode (first item) is set to Air (use the left/right arrows to change this). Press Menu to go back to the TV menu. Then go down to Channel Scan and press Enter. You may need to confirm the channel scan and press Enter again. Wait for the scan to be completed.
On a discontinued model (DX-32L151A11), the procedure is slightly different. With the input set to TV, press Menu. Select the Channel submenu and press Enter or down arrow. Set the TV mode to Antenna (use the left/right arrows to change the value). Then press the up/down arrows to reach AutoScan. Press Enter. Move cursor to highlight Yes and press Enter again. Wait for the scan to be completed.
I hope this helps.
(There were some Dynex monitors built. They usually do not have a coaxial antenna in port since they didn't have tuners.)
Jul 29, 2011 | Olevia LT32HVE 32 in. LCD Television
I just bought a new dynex 32 inch that did not come with a manual. I attached the cable into the correct area however I am still unable to see my cable channels even when changing the input. What am I...
Check this link to download the user's guide or quick setup guide. Press menu > channel, go down to TV source change it to cable and go down to auto scan and press > to start programing the channels into the LCD memory.
Sep 14, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex 32 Inch Installation Problem
Hi I Just Bought A Dynex 32 Inch HDTV. I Did A Auto Scan And It Didnt Pick Up Any Digital Channels? Am I Suppose To Have An Antenna Or Digital Box? How Do I Get Th Channels To Come In?
Nov 28, 2009 | Televison & Video
Auto Scan doesn't pick up any channels.
In the main settings, there should be an option for AIR or CATV, air is for non-cable and CATV is for cable tv. This has to be on the correct setting before you autoscan
Jun 22, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
How do i run a channel scan? there is nothing in the manual
Found this in the most frequently asked questions at the Dynex customer support website on page 3. the website is:(http://www.dynexproducts.com/pc-680-23-dynex-32-720p-flat-panel-lcd-hdtv-matte-black.aspx) You can also call the customer support telephone number at 1-800-305-2204. between the hours of 7am-12am CST. Give them the model number of you television and tell them you are having problems completing the autoscan of the television. I hope this information helps you with your problem. 1.How do I set up my channels or run an autochannel search? 2.Are you using a cable/satellite box, cable connected directly to the TV, or an antenna? 3.If you are using a cable or satellite box you must use the remote that came with that box to change channels. 4.Make sure you have the correct input selected to view channels via the cable or satellite box. For example, if the cable or satellite box is connected via component cables please press input and select Component 1 or Component 2 to view your channels. If you are using cable connected directly to the TV: 1.Press MENU. The on-screen menu opens. 2.Press < or > to select Channel, then press v to access the Channel menu. 3.Press ^ or v to select Air/Cable, then press < or > to select Cable. 4.Press ^ or v to select Auto Scan. Press > or ENTER. 5.Press ^ or v to select Cable System, then press < or > to select your type of cable or satellite system. You can select STD, IRC, HRC, or AUTO. If you are not sure what type of system you have, select AUTO. 1.Press ^ or v to select Start to Scan, then press > or ENTER to start scanning. Your TV memorizes all cable channels you receive. If you are using an antenna: 1.Press MENU. The on-screen menu opens. 2.Press < or > to select Channel, then press v to access the Channel menu. 3.Press ^ or v to select Air/Cable, then press < or > to select Air. 4.Press ^ or v to select Auto Scan. Press > or ENTER. 5.Press ^ or v to select Start to Scan, then press > or ENTER to start scanning. Your TV memorizes all analog and digital channels you receive.
Mar 16, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex 32 in. LCD Flat-Panel HDTV Logo
1,282 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
