Question about Whirlpool RBS275PD Electric Single Oven
Broil turns ON when pressing BAKE button on RBS275PD Whirlppol oven
The bake button on the panel turns on the broil instead of bake. The broil button works fine.
Has anyone seen this problem and know the fix.
Thanks
  • 1 more comment
  • Blessed_Mom Feb 14, 2008
    Pressing the "Bake" button and the broil feature comes on. Press "Broil" button and the broil comes on. I can press "Delay Start Time" and "Start" and the bake comes on, for now...but I'd like my "Bake" button to work properly again.
    Does anyone know the fix?
    Thanks!
  • Anonymous Mar 17, 2014
    My knob broke on the bake and broil i don't know if my food is on bake or broil
  • Anonymous Mar 26, 2014
    oven made a loud popping sound and then turned off. bake, broil and clean buttons light up and an 88
Our Whirlpool oven just started doing the same thing!!!! The Delay Start Time (setting it for one minute ahead) and then Start works just fine.  But we fried the tops of three loaves of homemade bread!!!!
Is Whirlpool just a bad brand for ovens?
Posted on Feb 17, 2008
Accubake oven broil on while bake is on
did u by any change do any work inside that may have reversed the wiring? other wise check the oven relay board and the wiring behind the bake broil switch
Jul 06, 2014 | Whirlpool RBS275PD Electric Single Oven
Oven won't heat past 290 after that we get an error message
Your oven is in celcius mode to change press bake and broil at the same time SF will appear then press broil and cooking time at the same time a C will appear press again to toggle to farenheight then press start to lock it in that mode. Some models when you press the bake and broil the sf will appear if it does press the press the broil button to toggle between C & F then press start.
www.appliancehelponline.com
May 21, 2010 | GE Profile JTP18 Electric Single Oven
Why won't my oven go on bake
you have a bad clock board a stuck relay on the board.
get a new clock board.
Sep 03, 2009 | Whirlpool RBS275PD Electric Single Oven
Broiler element comes on when "bake" is pressed
does the bake element come on at all?
if so, try the oven out. do a bake @ 350 allow it to pre-heat, and see if once the pre-heat is comlete, id the broil shuts off.
on many ovens at the beginning of the cycle during pre-heat both bake and broil elements are powered.
other than that it may be a control board, or a burnt and crossed wire in the harness.
May 28, 2009 | GE JTP15 Electric Single Oven
Digital oven will not turn on, I press bake/broil it reads ''Loc''
Look on the control panel for an icon that looks like a padlock near one of the buttons. Hold that button down until it beeps and that should unlock the panel.
Mar 20, 2009 | Ovens
I ran the self-clean mode this morning. After it finished this process, I preheated the oven to do some baking, and now the oven won't heat at all.
I am going to assume that you selected bake as you normally would and there are no faults (error code) reported. - this would mean there would not be a problem with the controller or the temperature sensor. The problem may be with only the bake circuit - so try the broil function - If the broil works then you may have a problem with the bake element or the connections to it or the relay on the controller - check the connections first then the element - If the broil does not work also then you may have a problem with the relay on the controller or the connection of the other leg of the 220v supply.
Make a check or have someone check it and wrte me back a post here
Regards
Oct 04, 2008 | Whirlpool RBS275PD Electric Single Oven
Thermador double oven / Bake wont work /FC code flashed once
I found I have this exact problem. Same bake preheat issue: I can bake if I set broil first. However, the oven doesn't work if I press bake first. The control board has already been replaced a couple times over the years. Is this another replacement??
Aug 30, 2008 | Thermador SC272T Electric Double Oven
Electric Oven Won't Heat
Rob, sounds like it was just installed. You need 240V on this unit. On the terminal block in back where the power hooks up, it should read 240V across the two outer terminals and 120V from each end to center terminal. Im ruling out the thermal cut out because you never used it. I would start with the power source first. The display sounds like it's getting the 120V it needs to funtion, but I don't think your making the loop for the 240V needed for the bake and broil. Catriver.
Jul 12, 2007 | Whirlpool RBS275PD Electric Single Oven
Whirlpool RBS275PD Electric Single Oven Logo
468 people viewed this question
Top Whirlpool Ovens Experts
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
