Question about Whirlpool GU2400XTP Built-in Dishwasher
GU2500XTPS7 start/cancel button inoperative
I picked-up a used GU2500XTPS7 that had no power to the control panel. I traced the power and it looked like a bad control module. I ordered a new module, and the buttons seemed to work so I though I was home-free. However, while I can select all the wash options the start button will not work. If I hold the delay button I just get two dashes on the screen. If I go through the reset/diagnostic cycle everything seems to function and it goes through the cycles. However, I can't stop it with the cancel button and the screen displays symbols like a J or a small and large vertical line instead of codes. It finishes the diagnostic wash cycles and then goes into standby. I've tried killing the power for extended periods but no such luck.
  • 131 Answers
SOURCE: None of the Wash Cycles are Working
It's probably the touchpad - commonly used buttons quit working after a while. If not, then it's the electronic control board.
Posted on Mar 10, 2008
  • 1073 Answers
SOURCE: problems with Whirlpool dishwasher model GU1500XTKB0
have they checked the thernals on the bottom of the tub
Posted on Apr 12, 2008
leethedeuce
  • 4472 Answers
SOURCE: DU1145XTP
You need to replace the circuit board inside the machine, technically it is possible for you to do it, how long have you had the machine, if it is under warranty you can have it serviced without any cost or less cost to you contact Whirlpool
http://www.whirlpool.com/custserv/index.jsp
You can locate the local authorized whirlpool service center.
If you need any further assistance please let me know.
To continue with my help you must make sure not to reject it and if you find it helpful I would greatly appreciate if you accept and rate accordingly.
Thanks,
Lee
Posted on Jul 28, 2008
SOURCE: Whirlpool Gold model GU1200 will not start wash cycle
FYI, for anyone else with the same symptoms. I took mine apart and found that the seal on the motor shaft failed and over time corroded the motor shaft bearing causing it to failed. I ordered full motor assembly from the parts store.
Posted on Mar 21, 2009
  • 188 Answers
SOURCE: ''Clean'' light is blinking, ''Cancel'' does not reset the cycle.
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on Apr 01, 2009
Reset figidaire dishwasher. Control panel not working.
hi david.
not sure if this link will help you out but have a look.
how to Reset figidaire dishwasher Google Search
Nov 01, 2017 | Dishwashers
Dishwasher starts on its own (no house is not haunted). Start resume button flashes
have a service technician in as it appears to be a problem in the program board
could be moisture across the circuit board
Feb 06, 2016 | Maytag MDB7749AWQ Builtin Dishwasher
Whirlpool Cabrio washing machine button does not work.
Possible that the main controller unit is faulty. You need to confirm the voltage on the controller unit and the connectors to the panel.
If there is no support from the controller then it can be faulty.
This requires testing the board for the processor and the set voltages for the board to function which must be measured..
Jun 05, 2012 | Whirlpool Washing Machines
Lights were flashing on printer and not printing. Couldnt get document cancelled. Replace catridge. Lights stop blinking, previous document cancel but printer still not printing
Check the printer properties in the control panel. Look in the status column. If the status is paused or offline, select resume or online or reset from the Printer menu option. Sometimes you have to turn the printer off and back on for it to start again. If it is an inkjet printer, don't unplug it. Some printers get messed up if they are not powered off using the power button.
Mar 30, 2011 | Office Equipment & Supplies
I need a game manual for shining soul 2. i lost mine and i have forgotten how to use my summons
Shining Soul 2
FIELD CONTROLS
Control Pad Move character
A Button Confirm/Talk/Pick up/Attack. Charge Attack (hold). Shining Force (hold).
B Button Cancel/Use items/Throw (hold)
L Button Display & select ARM equipment
R Button Display & select ITEM equipment
Start/Pause Display Camp Menu. SELECT = Use equipped Soul
CAMP CONTROLS
Control Pad Move cursor
A Button Confirm
B Button Cancel
L Button Select ARM equipment (Item Screen)
R Button Select ITEM equipment (Item Screen)
Start/Pause SELECT = Scroll through item descriptions
Mar 10, 2011 | Video Game Consoles & Games
What does the sign "control lock" mean?
Here is what the manual for your oven says about control lock.
Let me know if you have questions.
Control Lock
The Control Lock shuts down the control panel pads to prevent
unintended use of the oven(s). The Control Lock will remain set
after a power failure, if set before the power failure. The only time
it is not available is during the Sabbath Mode or Self-Clean cycle.
When the control is locked, only the TIMER SET · START, TIMER
CANCEL, OVEN LIGHT and CANCEL OFF, UPPER OVEN
CANCEL / OFF or LOWER OVEN CANCEL / OFF pads will
function. On double oven models, CLOCK SET · START will also
function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Press and hold CONTROL LOCK for
about 3 seconds, until “CONTROL LOCK” and a picture of a lock
appear on the display. Repeat to unlock and remove “CONTROL
LOCK” from the display.
May 13, 2010 | KitchenAid SGL OVEN T/C
Mdb6650aww code flash: Rinse Cycle & Wash Button.unit inoperative
You might try running the diagnostic mode which can be model dependent. To find your particular method to do this .... unscrew and remove the lower kick plate under the door. The service technician paperwork is usually taped to the kick panel or the tub or side wall. Within that paperwork should be the work process to run through the diagnostic mode. The work process is one of pushing various control buttons in a sequence within a quick time frame and repeating 2-3 times.
If that fails ... other potential reasons run the gambit of a bad control panel (or loose wire connection to the panel), bad heating element, etc
Good luck on your troubleshooting!
Jan 20, 2018 | Dishwashers
I need to cancel a print job
depends on you os but go to the control panel and pick printers. When the box comes up double click your printer that you are using, when the next box comes up, pick the job you want to cancel and cancel it. might be able to right click on the job and pick delete.
Oct 23, 2008 | Office Equipment & Supplies
Cancel Job
The only other way you can stop it is to stop the print job from the computer. Press the start button. Press the control panel. Select printers. pick the icon of the printer and double click it. Highlight the print job and press the delete button.
That will canel it.
Aug 25, 2008 | Zebra 105Se Thermal Printer
Whirlpool GU2400XTP Built-in Dishwasher Logo
97 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
