Question about Lexmark X1240 All-In-One InkJet Printer
Just purchased a Lexmark 1200 series printer and it's software was successfully installed and my computer is recognizing that something is plugged into its usb port. Yet when I try to print documents an error message comes up and says, "Problem communicating with the printer." So I followed every single troubleshooting recommendation: checking the firewall, disconnecting and reconnecting bot the usb cable and power, checking that the printer is in fact on, and restarting my computer. None of these work. Would it more likely be a faulty usb cable or do I need to return the printer? HELP!
  • 1 more comment
  • serenascalf Jan 30, 2010
    TAKE THIS OFF OF GOOGLE NOW!
Have Lexmark 1200 series want to install on Windows 7 should I download drivers first amd then try and install software or the other way around?
Please follow the steps below on how to properly install your Lexmark 1200 Series printer on your Windows 7:
1. Check the version of your operating system. Go to Start menu > right-click on Computer and choose Properties to see if you have a 64-bit or 32-bit OS.
2. Visit the Lexmark website to download and install the printer driver on your computer. Use the links below: - Lexmark X1200 Series Driver for Microsoft Windows 7 32-bit - Lexmark X1200 Series Driver for Microsoft Windows 7 64-bit
3. Follow the instructions on your computer screen. The software will show you a step-by-step instructions on how to setup the printer as well.
Oct 09, 2011 | Lexmark X1270 All-In-One InkJet Printer
I've lost my cd to install the printer, is there a way i could do it online?
Yes you can download the software from the manufacturers website. Go to http://www.lexmark.com and look for downloads. Then enter your printer make and model to find your software. Download the software by following the instructions and install it on your computer before connecting your printer.
Nov 08, 2010 | Lexmark International Lexmark 1200 Series
Lexmark X8350 "communication not available"
I fixed this by completely uninstalling the Lexmark software, then unplugging the USB and restarting. I then installed the new Lexmark software that I downloaded from their site, make sure not to plug the USB back in until it told me to. It then detected the printer properly and started working.
Jun 02, 2009 | Lexmark X8350 All-In-One InkJet Printer
Lexmark printer 1200 series all-in-one setup
Hey,
The lexmark drivers and software required for installing the printer is available at www.lexmark.com
Select Drivers & downloads then driver finder.
Type in your model x2350 for example
Select your windows version
Download the setup program.
1.Download software
2.Run the downloaded setup
3.Plugin the printer when asked
4.Done
Thanks,
Ekse
May 05, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
I have tried to install lexmark 1200 series all in one printer.computer says i havent got a valid port to install
Did you install the right driver for your system,xp/vista.
When you run the software disk and install it at some point it will ask you to turn on the printer and plug it in, this should not be done until the software ask's.
Apr 09, 2009 | Lexmark X1270 All-In-One InkJet Printer
Can't seem to install the lexmark 1200 series all in one cd
uninstall the old driver you installed
unplug printer connection to PC (USB Cable)
restart PC
Install the software using the new CD
Follow the instructionon CD.
before end of installation it will ask you to connect the printer
here is the user manual: copy and paste the link to your web browser
http://www.lexmark.com/publications/pdfs/1200/eng/ug.pdf
Mar 20, 2009 | Lexmark X1270 All-In-One InkJet Printer
No connection with lexmark 1200 series (X1270 printer)
make sure your firewall software is configured correctly - nortons and mcafee especially can interfere with printers - try turning it off and seeing if you can connect then
Nov 20, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark 1200 series
Does it power on? How is it connected to your computer? Did you install the drivers for it?
Sep 07, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark 1200 series all in one
I purchased a lexmark 1200 series all in one printer and cannot locate the cd that came with it. Is there a way to install it without the cd? I tried but it says can't find hardware.
Sep 03, 2007 | Computers & Internet
Lexmark X1240 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
