Question about Yamaha DSP-A3090 7-Channel Amplifier
3090 input selector cuts in and out
Hey All,
I think we should start a club – if so I would join as I have a similar problem. My input selector cuts in and out (especially when I first turn the unit on) I think it needs to heat up in order for it to work. The selector switch also can dim and/or go crazy (auto switching itself over and over).
Not sure what to do. I live in NYC and there is a repair facility 1 mile from my place but they want $75 just to look at it (not including anything else). What it really comes down to for me is; has this piece of equipment meet its usable life and should now be replaced? All the new models have many more features and types of technology that wasn’t even available back in 1998. however, I would be willing to keep this unit and repair it if the quality is superior to today’s models.
Does anyone have any thoughts, suggestions, comments, etc.?
Thanks –
Jay
My A3090 was purchased in 1996 and began to having problems with the input selector around 2006. The first symptom was difficulty finding the proper position for a input selected via the remote and bouncing back and forth many times before stopping-- sometimes in the correct position, other times not. Sometimes the selector would stop in between inputs and that would result in intermittent loss of sound, picture, flickering, etc. Once incorrectly positioned between inputs, even manually turning the knob will not fix the problem-- you must use the remote and select an input at one extreme or the other to reset the indexing.
Recently the problem worsened such that I was motivated to remove the cover and have a look. The selector and motor are soldered components on a small circuit board that appears to be dedicated to just that function. No rotary contacts are visible and the mechanical portion does not look like it can be disassembled without first removing it from the circuit board. The assembly is connected via a wire bundle and ribbon cable to two other circuit boards. I suspect the actual signal switching isn't even done inside the selector component-- it just reports the selector position via the ribbon cable to the main processing board. And it wouldn't surprise me if there aren't any contacts inside the selector that can be cleaned.
Seeing the ribbon cables immediately raised a warning flag because decades ago I saw similar cable connections cause many problems in personal computers. Back then they were very prone to corrosion and connection issues at each end. So I removed and reinserted the ribbon cable on both ends in hopes of improving the connections and that seems to have fixed the problems I was seeing. (Please note: This was done with the receiver power cord unplugged and *very* careful avoidance of any other components inside the receiver-- like the bank of capacitors adjacent to the input selector. I'm not a technician and don't know if any of them still held a charge. This is just an account of what I did and the results I saw, it's not a recommendation.)
Posted on Jul 12, 2010
  • 4,234 Answers
This type of problem is not unusual for older electronics. The constant heat and cold cycles make some of the solder connections fail over time. This could be as simple as a few poor solder connections that appear to 'repair" themselves once the unit heats up. This should be a labor only repair. Since I highly doubt you can replace the unit for anything close to the repair cost, it probably is worth the repair.
Dan
Posted on Sep 05, 2009
I do have the same amp with the same problem,the problem appears to be the selector its self as is very common to this type of mechanical selectors that the contacts are getting over the time a kind of corrosion,so you need to clean it very good with a contact spray or even better to dissasembly the selector and clean the contacts by hand.
Posted on Feb 09, 2010
Number JC9043011 did my spin id number win?
Wheel of Fortune ' Wheel Watchers Club ' What is SPIN ID?
www.wheeloffortune.com/spinid/
  1. Cached
  2. Similar
Watching Wheel at home is more rewarding than ever with the Wheel Watchers Club! Watch Wheel for a chance to win with your Wheel Watchers Club SPIN ID number starting January 16th! Short for "Special Prize Identification Number," your personal SPIN ID number can give you the chance to win $5,000 each weeknight. 2.
Wheel of Fortune ' $5K Every Day Sweepstakes
https://www.wheeloffortune.com/fivek-every-day/
  1. Cached
Fri.) to see if your SPIN ID is announced during the $5K Every Day reveal. ... If your SPIN ID is verified as the winning number, we'll call you to confirm you as the ...
Wheel of Fortune ' America's Game® ' Wheel Watchers Club
  1. Cached
  2. Similar
Find Your Station. FPO. Wheel Watchers Club. Login OR Join. FPO. Did My. SPIN ID Win? Let's See. Filter Content as: All Photos Video Text. #WheelOfFortune ...
Wheel of Fortune Solutions - Winning Spin ID
www.wheeloffortunesolutions.com/spinid.html
  1. Cached
  2. Similar
Daily Wheel of Fortune winning Spin I.D. numbers, prizes and names of winners.
My Spin ID number came up last night -... - Patricia A McLeod ' Facebook
https://www.facebook.com/wheeloffortune/posts/499915046718810
  1. Cached
  2. Similar
My Spin ID number came up last night - and guess what - I did not win. I found out that you have to login into your Spin ID account every 6 months so its...
Member TIP: To keep your SPIN ID and... - Wheel of Fortune ' Facebook
https://www.facebook.com/wheeloffortune/posts/131867833547568
  1. Cached
  2. Similar
The Wheel Watchers Club is the only way to win big, just like the contestants on Wheel of Fortune. Join today to receive your SPIN ID number. Short for "Special ...
Jan 25, 2017 | Computers & Internet
Hi! An elderly friend in Tadworth,Surrey lives alone & really needs to socialise as she's suffering from loneliness. Any help available? Thanks
She could join a local bowls club
She could go do a local bingo game.
She could contact local council and see if there are any day club activities run for the elderly .
She could contact a local RSL and see if they run any day club type activities.
Senior Citizen type places ?
Probus club is another
Lions Club is another
look at clubs she could join in her area .
Dec 08, 2016 | Video Game Consoles & Games
Is there a fiat club that one can join in cape town area
There is only one person who owns Fiat; in this area, and it is You. The what is about a club?
Apr 27, 2016 | Fiat Cars & Trucks
HOW do i join POGO?
If you're interested in Club Pogo or want to join, go to Club Pogo page. From this page you can view a video with a VIP Tour of Club Pogo, and even compare memberships!
Aug 12, 2015 | Miscellaneous
Need to replace gear selector on golf automatic as it wont start cut out on me so was in gear have had it checked and it is the gear selector how do i fix it myself
Hi Gary, I may be wrong but I think the gear selector mechanism would not cause the vehicle to cut out? If a diagnostic scan has reported a fault with the selector mechanism it will be with alignment of the switching mechanism which allows start up only in park or neutral. If the starter turns the engine with the selector in either of those two positions (P or N) the problem is with the engine not the shifter. If the engine does not turn you may have two or more problems. Give more details and describe the events leading to the problem more clearly. Regards John
Mar 24, 2013 | Cars & Trucks
What is the connector pin-out match to wires on Denso 234-3090 and 234-4700 oxygen sensors in 2000 Nissan Maxima?
The 234-3090 is the wrong sensor
The 234-4700 is the wrong sensor
& for california emissions
Get the correct sensors with the connector
on them (OEM Type) you have many to choose
from, even at auto zone
You got universal cut & splice,that is silly
Jul 31, 2011 | 2000 Nissan Maxima
How to join club nintendo
Go to club.nintendo.com and click the Join Club Nintendo now button. After that just follow the steps.
Apr 24, 2011 | Nintendo DSi Matte Blue Console
I think i have a short or loose connection. sometimes i turn the switch on and it lights up and fires right up. then sometimes it dont. sometimes the lights come on and when i hit the start button it makes...
I think you are correct. I think id be looking at the connection the back of the ignition switch for starters ... but dont neglect any connection. Make sure battery connection is secure (though it probably is as you say you get a click when you press the starter.) I would normally expect the battery side of the start solenoid to be the place where your fuse panel gets its power ... look around and check all connections.
You may be interested in joining th Honda Riders Club (google it to find it) If you join, you get access to your service manual
I hope this works for you
a
Oct 15, 2009 | 2003 Honda VT 600 C Shadow
Pinkig under load ?
hey sav,
Are you a member of the MTOC?
join up and you'll get advice on this matter I think you mite need it looked at again and check your oil in the correct way as it maybe low!!! see you in the forum.
Feb 16, 2009 | 2006 Yamaha MT-03
BUSH PRO300/AR
hi.
the inputs are not for a tv.
they are for a 5.1 dvd player or similar device, the dvd player will have the same corresponding outputs, join them up and hey presto, sound.
hope this helps
Sep 17, 2007 | Audio Players & Recorders
Yamaha DSP-A3090 7-Channel Amplifier Logo
736 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
