Question about Vector Welding Tools
I have to need different type's of solder vector files or eps file
Dear sir
i am a logodesigner and i have to need group solder vector file or eps file . because of i have to make a logo . if possible please send me eps file in the mail.
Thanks
bhakta thapa
Posted on Sep 04, 2009
I cannot open a downloaded EPS image file in Lenovo photos. Lenovo photos does not even recognize that image exists in the folder that it is in. How do I view this file?
Michelle,
Lenovo photos may not recognize the .EPS file extension. You can download this viewer from CNET and save the file to a different format if you would like.
http://download.cnet.com/EPS-viewer/3000-2193_4-75211879.html
Hope this helps,
Scott
Oct 01, 2013 | Lenovo Computers & Internet
What web site can i go on to find a world blank map ?
just put blank world map in google and you will find many blank world maps
I’m happy to help further over the phone at https://www.6ya.com/expert/bob_62dfa2f81bb55288
Oct 03, 2009 | Computers & Internet
Missing WMF Graphic filter
I had the exact same problem and couldnt figure out what was going on...but I had a freak fix. I don't know how, but when I installed disc 4 (Picture It! 2000 Setup and Picture Disc) and disc 5 (Additional Art), I was able to access the program again. Hope this helps!
Apr 13, 2009 | Computers & Internet
Changing resolution in eps options of Adobe Illustrator C3 (mac)
Unfortunately I do not have the answer, but I do have a recommendation for what I did. I exported the file as a jpeg. This allows you to change the resolution there. Hope this helps.
Mar 23, 2009 | Apple Computers & Internet
My project name is digital image processing.so want basics to do this project.
Start of by looking at the different types of image file formats as the inputs, for example JPEG, GIF, BMP, TIFF, PNG etc. There are loads of them with different pro's and con's for each.
Also take a look at the vector based file formats, and how vector images are scaleable upwards to any size, without loss in resolution.
I'm not sure about the details of your project, but it falls into the 3 main topics of :-
  1. Inputs to the system
  2. How it is processed
  3. What the final output is
Dec 10, 2008 | Computers & Internet
Illustrator to photoshop
Here is everything you will need. I hope you will find this worthy of a FixYa rating.
Import Illustrator CS2-CS3 artwork into Photoshop CS2-CS3
What's covered In Adobe Photoshop, you can import Adobe Illustrator artwork in several different ways, each of which offers a different level of control. When you open or place AI, EPS, or PDF files created by Illustrator, Photoshop rasterizes vector artwork and removes the ability to edit transparency, fonts, layers, and paths. To retain more control over imported Illustrator artwork, Adobe recommends that you drag or paste it into a Photoshop image or export it in Photoshop format.
Drag Illustrator artwork into Photoshop Dragging Illustrator artwork is the quickest way to import it into Photoshop. By default, Photoshop creates a new layer for the dragged artwork and imports the artwork as a Vector Smart Object. (For more information, see "Smart Objects" in the Photoshop Help.) You can import dragged vector artwork as a work path, however, by holding down Control (Windows) or Command (Mac OS) while dragging. To center imported artwork in the Photoshop image, hold down Shift while dragging.
Note: To import dragged type as a work path, you must first convert it to outlines in Illustrator. For more information, see "Modifying letterforms as graphic objects" in Illustrator Help.
Paste Illustrator artwork into Photoshop When you copy Illustrator artwork, you can paste it into Photoshop and retain many Illustrator features. To do so, however, you must properly configure Clipboard preferences in Illustrator.
The Illustrator Clipboard supports a variety of formats including: PICT, PDF, and AICB. Though Illustrator always copies PICT data to the clipboard, you can configure Illustrator so that it also copies PDF or AICB format. These two formats allow you to retain Illustrator features in artwork pasted in Photoshop. PDF retains Illustrator transparency, while AICB format retains Illustrator paths.
You should only select the AICB format by itself if you are going to be pasting paths in to Photoshop. In all other cases, select the PDF format or the PDF format in conjunction with AICB. The PDF format retains transparency and other features in Illustrator such as extended support for spot colors.
To configure Clipboard preferences in Illustrator:
  1. Choose Edit > Preferences > Files & Clipboard (Windows) or Illustrator > Preferences > Files & Clipboard (Mac OS X).
  2. In the Clipboard section, select the desired format.
  3. If you selected AICB, select either Preserve Paths or Preserve Appearance.
  4. Click OK.
Paste options in Photoshop
When you use the Paste command to import copied Illustrator artwork, Photoshop provides the following options in the Paste dialog box:
  • Paste as Smart Object: Pastes the art as a Vector Smart Object that can be scaled, transformed, or moved without degrading the image before it's placed into the Photoshop document. As the art is placed, its file data is embedded in the Photoshop document and the art is rasterized on a separate layer.
  • Paste as Pixels: Pastes the copied artwork in a new layer and rasterizes it at the resolution of the Photoshop image. Use this option when pasting raster objects.
    Note: When you use this option, clipping masks for raster images are not retained as paths. These masks still clip images, however.
  • Paste as Path: Pastes the copied artwork as a work path.
  • Paste as Shape Layer: Pastes the copied artwork in a new vector shape layer. Compound Illustrator shapes retain their attributes and remain editable. Multiple copied paths and clipping masks are pasted as multiple paths that use the unite attribute .
    Note: When you use this option, pasted objects use the foreground color in Photoshop, not the fill color they use in Illustrator. Likewise, transparent objects become opaque.
Export Illustrator files in Photoshop format Exporting Illustrator documents files in Photoshop format gives you the most control over Illustrator artwork in Photoshop. With this method, you can specify resolution and enable anti-aliasing for rasterized artwork. You can also retain the following Illustrator features:
  • Editable text
  • ICC profiles
  • Layers, including nested and hidden layers
  • Masks
  • Transparency
  • Compound shapes
  • Slices and image maps
Note: A compound shape must have either no stroke or a stroke with a round join that uses whole integers for the stroke weight. However, the compound shape can reside on a layer with other objects. In that situation, Photoshop places the other objects on a separate layer in the same layer set.
For more information about exporting Illustrator files in Photoshop format, see "Photoshop export options" in Illustrator Help.
Open Illustrator (AI) files in Photoshop You can open AI files in Photoshop if you save them using the Create PDF Compatible File option.
To save an AI file using the Create PDF Compatible File option:
  1. Choose File > Save As.
  2. Choose Illustrator (*.AI) as the file format, and click Save.
  3. Click Create PDF Compatible File in the Illustrator Options dialog box, and click OK.
Thanks,
Lee
Jun 18, 2008 | Adobe Photoshop 7.0 for PC
User's manual for epox mother board ep-8k9a7i
Download from this link for EPoX EP-8K9A7I.
Fill in (File type & Model).
http://www.epox.com/usA/downloads.asp
Enjoy!
Mike
May 02, 2008 | EPoX EP-8K9AI Motherboard
Convert CAD (DWG) to Visio Drawings
You can import graphics files of different formats to start a new Visio drawing by using the Open command on the File menu.
The following graphics file formats are supported:
  • AutoCAD Drawing File Format (.dwg, .dxf)
  • Compressed Enhanced Metafile (.emz)
  • Enhanced Metafile (.emf)
  • Graphics Interchange Format (.gif)
  • JPEG File Interchange Format (.jpg)
  • Portable Network Graphics (.png)
  • Scalable Vector Graphics Drawing (.svg, .svgz)
  • Tag Image File Format (.tif, .tiff)
  • Windows Bitmap (.bmp, .dib)
  • Windows Metafile (.wmf)
Note File formats may vary slightly between language versions. You may not get exactly the same results if you import files created in different language versions.
  1. On the File menu, click Open.
  2. In the Files of type box, click the file format of the file you want to import.
If you don't see the file format listed, Visio doesn't have a file filter for that format. Try saving the document in a format Visio can open.
Dec 28, 2007 | Computers & Internet
Welding Tools Logo
80 people viewed this question
Top Vector Welding Tools Experts
Bill Boyd
Are you a Vector Welding Tool Expert? Answer questions, earn points and help others
