Question about Philips 42PF7320A 42 in. Plasma HDTV
42FD8854/17S A friend of mine gave me this tv, if you turn it off from the remote and leave it next time you come back the light will blink, if you turn it of from the side without shutting it off first, when you come back to turn it on from the side as soon as it heats up the green light comes on and starts flashing an at the same time you hear a clicking sound. I took the back off to see where the ound was coming from and I found that one of the relay is clicking, what can I do to solve this problem. Is either buy a refurb board for 200.00 or go to the repair center and it will be 125.00 just to take it so they can tell me is the board and charge an arm and a leg for the board plus labor. where is a good place to find this power boards???? Thanks. Armando
  • 92 Answers
Charles Hyde sell them.
www.chsinteractive.co.uk
Posted on Sep 05, 2009
I dont have a remote for my tv and it wont turn on manually the led light blinks 9 times and stops and starts again what should i do?
The blinking lights are a service code. You should first try to unplug your TV and leave it unplugged for at least 4 hours... then plug it back in again.
If the blinking light is still there and no picture, time to have the TV serviced. Good luck!
Oct 10, 2010 | Panasonic CT-34WX54 34" TV
Need codes for rcr 460 remote
1. Manually turn on the component
you want the remote to control
(TV, VCR, DVD, satellite receiver
or cable box).
Note: If you press an invalid key
during the Manual Code Search,
the remote does not respond and
the LED indicator light does not
blink. If you do not press a valid
Manual Code Search key (TV,
VCR, DVD, SAT·CBL, ON·OFF,
GO BACK), the search times out
after two minutes. When the
search times out, the LED
indicator light blinks four times
and turns off. The last
programmed code under that
component key is retained.
2. Press and hold the component key
(TV, VCR, DVD, SAT·CBL) you
wish to program. The LED indicator
light turns on and remains on.
3. While holding the component
key down, press and hold the
ON·OFF key. The LED indicator
light turns off.
4. After holding down both keys
for three seconds, the LED
indicator light turns back on.
5. Release both keys. The LED
indicator light remains on.
Throughout the
programming of each key, be sure
to keep the remote pointed at the
IR sensor of the component you
are currently programming the
remote to control.
6. Press and release the ON·OFF key
repeatedly until your component
turns off. Each time you press the
ON·OFF key, the LED indicator
light blinks, and the next code in
the list is sent. This process
continues until all of the codes in
the Code Lists have been searched.
If your component turns off, you
have found the correct code. (If it
cycles through and the LED
and turns off, all codes have been
searched. The Manual Code Search
method is exited.)
Press Stop when TV turns off.
Mar 06, 2010 | RCA Universal Remote Control
How do you tune Sky+ remote into Sony KDL46W5710 Television
The Sky+ remote should automatically default to Sony TV's. Leave the batteries out for a few minutes and try again. The Code for Sony is 0000.
Or try this :-
With TV and sky box on.
Press the 'TV' button on the remote.
Hold down the 'select' and the 'red' button (of the four coloured buttons) together, until the red light on the remote blinks twice. (takes 2 seconds)
Press the 'TV' button again.
Now enter four zeros, the red light on the remote should blink twice.
Press the 'standby' button (top right).
If the TV turns off, then press 'select' and the light should blink twice again, job done.
If the TV does not turn off then press 'TV' followed by 'standby' again.
Alternate pressing 'TV' 'Standby' until the TV turns off.
When it does, finish by pressing 'Select.
Check the red light on the remote, if it blinks 3 times, then it has run out of options for 0000.
Dec 19, 2009 | Televison & Video
I have the radion shack hdtv remote. Cat no
Download the manual and codes from here
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/radio_shack/15135-manual.zip&area=other
Here is how to set the code...
1. Turn TV on
2. Press TV button on remote
3. Hold P button on remote until LED blinks twice
4. Enter the first 5 digit code for Magnavox TV's
5. Press Power button - TV should turn off. If TV doesn't turn off repeat steps 2-5 with the next 5 digit code, until either TV goes off or run out of codes.
6. If out of codes use searching for code method below...
TV codes for Magnavox
10047, 11454, 10054, 10154, 10000, 10250, 10051, 10180, 10060, 10030, 10171, 10092, 10706, 11913, 11904, 11755, 10019, 11365, 11254, 10802, 10386, 10282, 10020, 10187, 10186, 10024, 10179, 10096
Searching for code
1. Turn on TV.
3. Press and hold P button until LED blinks twice
4. Enter code 991 on remote - LED blinks twice
5. Press 1 - Device key blinks twice
6. Press Power button once
7. Press and release CH+ key until TV turns off.
At this point in the manual, the manual is only correct depending on what type of TV you have.
In the manual if you press the Power on button the TV should turn itself back on, the fail to state that not all TV's turn on by the power button, the majority now are triggered to turn on, on channel change, however you can't use channel change here to check it as you'll go to the next code... here is my solution...
8. Turn TV back on either using original TV remote, or buttons on front (most TV's if you change channels they come back out of standby mode, very few now turn on by pressing the power button).
9. Press Power button on remote - TV should turn itself off again.
10. Press P button on remote to lock in that code.
If the device does not turn off press CH- to go back through the codes, press and release P button when TV turns off.
Finding code
If you used the search function you might want to know what code it's using. To do this follow these instructions...
1. Press TV button
2. Press and hold P until LED blinks twice
3. Enter 990 and LED blinks twice
4. Press 1 and count number of times LED blinks this is the first digit of your code (e.g. 1 blink = 1, 2 blinks = 2, etc).
5. Repeat step 4 pressing buttons 2 - 5 for the other digits (e.g. for the second digit press 2 count number of blinks.. etc)
At this point the manual doesn't tell you how to get out of this mode, I presume pressing any other button on the remote other than 1-5 will take you out of this mode, either that or leaving the remote alone for 5 minutes.
Nov 08, 2009 | Radio Shack (15-2147) Remote Control
My television blinks yellow light
i have same tv lct2715 my customer gave to me.
open back cover you will see many many bulging capacitors that is 1000uF and 470uF at powersupply and mainboard . replace all!
mine works great!
Aug 11, 2009 | Akai LCT2715 27 in. LCD Television
Lost blue; otherwise normal; blinks 5x
If the TV standby light is blinking for five times then you may perform the steps given below:
(i) Turn off the TV then disconnect all the cables from the TV.
(ii) Next, reconnect all the cables after two minutes.
(iii) Please make sure that the power cable from the TV is directly connected to a functional wall outlet.
(iv) Next, you may try resetting the TV to the original factory settings.
Please follow the steps that are mentioned below to reset the TV to the original factory settings:
(a) Turn ON the TV.
(b) Press and hold the Power button on the Remote Control supplied with the TV, then press the Power button on the TV front panel.
(c) Release the Power button. The TV will turn itself off, then back ON again.
(d) Next, release the Reset button on the Remote control.
If the standby light still blinks then the issue may be with the projection lamp in the TV and requires replacement.
Jul 12, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Viewsonic model vs10846-1m aka N4060W won't turn on.
I found if you hold the power button down on the remote or the tv , hold it down for anywhere from 2-5 minutes the green light will blink and blink and blink, all of the sudden it will stay on. then shut off, but if you turn it back on on the light will again stay on , do this 3-4 times and then the tv will turn on. Once you turn it off for over 10 minutes you will have to go through the whole rigamaroo again. This will only work for a while, mine has quit completely now. The Veiwsonic guy gave me a part number for a power board he said was most liley the issue. It ran about $71. I've got a repairman coming tomorrow to see what the dealio is. I'll let you know what he tells me, good luck!
Jan 28, 2009 | Televison & Video
On timer light blinks on/off tv does not turn on jvc av-32d502
Well, it sounds like the TV is in timer standby mode and thus preventing the TV to turn on or off.
  • Very simple thing you can try to reset the TV is to unplug it from the wall and leave it unplugged for about 5 minutes or so.
  • Next, replug in the power for the TV and see if the timer mode has been cancelled out.
Regards,
Feb 16, 2008 | Televison & Video
Remote JER622
There is a way to program the remote without codes...
make sure the tv (or whatever you are programming for) is turned on
press and hold the button for that function (sat, vcr, dvd, tv, etc), the on/off button will light up
continue holding that button down while you press and hold the on/off button. When the light turns off, release both buttons. The light will now stay on.
Press the play button - it will then cycle through 10? codes I think, while the on/off button blinks. When the button stops blinking, if your tv (or whatever) has not turned off, press the play button again to send the next set of codes. When it turns off, press the reverse button (slowly - to find the correct code) until it turns back on, then press the stop button to save the code. If the remote has cycled through all the codes for that kind of device, the next time you press the play button, the on/off button will blink 5 times and the light will go off.
Hope that made a bit of sense...
Feb 10, 2008 | Jensen 143307 Remote Control
42" Plasma TV Problem
same frustrating symptoms on brand new 42inch here! tv just turns itself off sometimes without warning or if changing to certain channels. leaves red light flashing for a while then red light goes away. any attempts with remote gives flashing green liht on tv. manual power off and on restarts tv but auto off again. found while manual power on keep changing channel on remote till stable picture appears. then use remote to shut down tv - solid red light indicates standby mode. then use remote to turn on again... till next time it happens. but what is technical fault??
Aug 18, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Philips 42PF7320A 42 in. Plasma HDTV Logo
53 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
