_NEC CD -RW NR-9100A DRIVES
I HAVE A BIG MATER IN FOUND THIS DRIVES _NEC CD -RW NR-9100A
  • Anonymous Jan 20, 2009
    mirza
  • 138 Answers
Hey plz be clear about your question and details so we can assist you!
Posted on Dec 08, 2007
Formating a cdrom
MAY BE NERO SOFTWARE CAN HELP U TO DO U R STUFF MAN..
best regards & best of luck..
Oct 12, 2007 | NEC MultiSpin NR-9100 (NR-9100A) CD-RW...
Can I burn DVD ?
No. If you have a CD-writer, you cannot burn onto a DVD-disk.
Jul 31, 2010 | NEC MultiSpin NR-9100 (NR-9100A) CD-RW...
How to set NEC NR 7800A as the master
the First thing you need to do is make sure the jumpers on the back of the drives are set ,one to slave and one to master. there will be a mark either on the case by the jumpers or on a label on the drive. On systems I build
I set the top one to master and bottom one to slave. It makes it easier to hook up the cable to them. The end of the cable goes to the top one and
the other one to the slave.
May 15, 2010 | NEC NR 7800A CD-RW Burner
Pc freezes when I click open on my nec nr 7900a cd-rw. dell pc, software windown xp,
this is most likely an interface issue either on the motherboard or drive....could be software but dvd drives don't last forever. when booting press delete and let it go into bios setup. You don't need to change anything in bios, just try opening the drive. If it opens without delay remove any disc. Reboot PC and see if the drive behaves, If it's still being awkward, with the PC unplugged open up the PC and remove the drives data cable. Start PC, close down PC. Reconnect drive (use a different IDE /SATA connection if possible) Try DVD drive again. If the fault still persists, It's most likely the drive. Get a new one they are really cheap.
Aug 02, 2009 | NEC NR 7900A (NR7900) CD-RW Burner
Driver for NEC CD-RW NR 9100A
I cannot watch DVDs with my nr-9100a cd rw and dvd rom drive.
Nov 29, 2008 | NEC MultiSpin NR-9100 (NR-9100A) CD-RW...
How can i fix
you need to check the Master slave settings of this device, you can only have 1x master & 1x slave on an IDE channel, if you set to the wrong one then the devices will conflict, if you are replacing a drive check what setting it had and replicate the same setting on the replacement CD drive. the master slave setting pins are usually next to the 40pin IDE connector on the back of the drive. hope this helps :D
Oct 01, 2007 | NEC MultiSpin NR-9100 (NR-9100A) CD-RW...
CD Burner
This will be a burner problem as in the laser is no longer able to read a disc and tell if it's full, empty or formated. I doubt it's a software problem, but you may have a faulty cdr disc so check a few or a different make as not all are compatable with all burner makes.
Apr 20, 2007 | NEC MultiSpin NR-9100 (NR-9100A) CD-RW...
55 people viewed this question
 Grubhead
Grubhead
