Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
System restarting on startup
My system is restarting frequently on startup
it is running in safe mode
i had disabled the feature of automatically restart
and then a blue screen is appearing and an error is displaying just like
uninstall antivirus and diskfragmentation ,disk utilities and it is asking for chkdisk utilities
what can i do now ?
can anyone fix this problem ?
thanks in advance..............
    President:
  • 392 Answers
Yeah..this is a BSOD problem. This generally occurs due to the recent changes in the Hardware, and SCSI/ ACPI compliant HDD, ... Generally this will be solved automatically after u restart your PC for 10-20 times.Even if it is not solved , then u have to insert Bootable XP CD and while installing the files ..u have to press F6 ,this will take u to install the missing SCSI driver.If u install the SCSI drivers the problem is solved.
Posted on Sep 04, 2009
Error code 0x0000034
Try this
Press f12 then advanced options, then Automatic repair or other options listed below:
From page 115 of your user manual-
Advanced options
Choosing this option presents you with another set of
options:
System Restore
? System Restore allows you to use a Restore point to
return the computer to a state at which it was performing
properly. Restore points are created:
? When new hardware or software is installed
? Manually by the user
System Image Recovery
Windows® will "Recover" the Operating system using a
specific image provided by the user.
116 If Something Goes Wrong
The Windows® operating system is not working
Automatic Repair
This feature automates the repair process. The Operating
System will automatically look for problems and repair them
if possible.
Command Prompt
The command prompt is a very powerful tool for advanced
users.
Startup Settings
In previous Operating Systems the majority of the options
found on this menu were available by pressing the F8 key
during the Windows® boot process:
? Enable low resolution video mode
Restarts Windows® using your current video driver at low
resolution. This allows you to reset your display settings
in the event they have been improperly set.
? Enable debugging mode
Starts Windows® in an advanced troubleshooting mode
? Enable boot logging
Creates a file that lists all the drivers that are installed
during startup
? Enable Safe Mode
Starts Windows® with a minimal set of drivers and
services. If the computer starts and runs in Safe Mode,
you will know the Operating System is most likely
working properly and that you should look to third-party
applications or drivers for the source of your problem.
? Disable driver signature enforcement
Allows drivers containing improper signatures to be
installed
? Disable early-launch anti-malware protection
Allows drivers to initialize without being measured by the
Anti-malware driver
? Disable automatic restart on system failure
Prevents Windows® from automatically restarting if an
error causes it to fail. Choose this option only if
Windows® is stuck in a loop where it fails, attempts to
restart, and fails again repeatedly.
SOLVED Recovery Your new PC needs to be repaired Boot configuration error...
Feb 15, 2015 | Toshiba Satellite C55T-A5123 Celeron N2820...
Dell 5720
download the software diagnostic coming with the computer and pass go www.dell.com give your service tags.
Use the antivirus+antimalware+scandisk
God bless you
Jun 06, 2013 | Computers & Internet
I have a Samsung NP-RF511 S04AU That won't start past the startup screen. I don't want to lose what is on my C drive can someone please help. I am running Window 7
Several things you can try.
Roll back system with System Restore. Under Safe Mode (press F8 during boot and choose Safe Mode). Win 7 - Start > Search type System Restore. Now choose a date prior to problem. You may have to try a few dates. Uninstall last program(s) that was installed, again in safe mode.
In Safe Mode try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Nov 29, 2012 | Computers & Internet
Can't start desktop ho
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Remove all USB attached devices like drives. You may need to roll back system with System Restore. Under Safe Mode (press F8 during boot and choose Safe Mode). Win 7 - Start > Search type System Restore. Now choose a date prior to problem. You may have to try a few dates. Uninstall last program(s) that was installed, again in safe mode.
Nov 23, 2012 | Computers & Internet
Compaq nc6220 freezes during POST
Start in Safe Mode by pressing F8 during boot. Then...
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig > Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running.
This just disables them in startup. Programs will still load, but when you initiate.
Oct 04, 2012 | HP Compaq nc6220 Notebook
System does not restart automatically using restrat fuction. system hangs and has to be manually switch off and again switch on manually
Go to Start> Run > type " msconfig"> "ststem configaration utility" window will apear, select the tab "StartUp"., select "Disable All" and apply and OK. it will ask to restart wait till it restarts. if it is not restarting. do the same thing in "Safe Mode". if you dont know hot to go to safe mode. Just press "F8" key when booting. the menu will apear, select "Safe mode" do above method in safemode and restart. this method will work in most of cases. best of luck.
Jan 28, 2011 | Computers & Internet
Keeps shutting down.
To resolve the issue, Please perform the following steps:
Step 1: BIOS Reset
To reset the BIOS defaults, follow these steps:
1. Restart the computer and press F2 (F10 in some Notebooks) as soon as the HP logo appears.
2. Go to Exit menu and select Load BIOS defaults or press F9.
3. Go to Exit menu and select Save changes and Exit or press F10.
This will reset the BIOS defaults. Now, when the Notebook restarts, press F8 repeatedly until the start up menu appears. Select the Safe Mode and press Enter Key to enter in Safe Mode and then perform the step 2.
Step 2 : Disable the "Automatically Restart" under System Failure:
1. Click Start, right-click the My Computer icon, then Properties.
2. Click the Advanced tab, then Settings in the Startup & Recovery section.
3. Remove the check mark next to Automatically Restart under System Failure.
4. Click OK to close the Startup and Recovery window, then click OK to close the System Properties window.
5. Restart the computer.
Step3: Reinstall Power management
To reinstall Power Management in Windows XP, follow these steps:
1. Click Start, select Control Panel, and then choose Performance and Maintenance.
2. Click the System icon to open the System properties window.
3. Select the Hardware tab and click Device Manager.
4. Click the plus (+) sign next to System Devices.
5. Right-click the ACPI Fixed Features button and select Uninstall.
6. Restart the system.
On restarting the system, Windows will automatically detect and install Power Management on the computer.
May 25, 2010 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Started freezing up frequently. I have to take
Try in the safe mode. If the system freezes up in the safe mode, run a Diags on the hard drive. Most Laptops have inbuilt Diags for the hardware available in the boot options screen. If the Diags pass, do an OS re-installation. You can also try system restore, but the issue can come up again. If you have data, you can try safe mode. If it works, back up your data, and then reinstall the OS.
If the system does not freeze up in the safe mode, go to msconfig, disable all Startup items and non-microsoft services. Startup in the normal mode. Enable the Startup programs one after the other, and you will be able to identify the problem creating application. This can also be a problem of virus infection. So when in the safe mode, after disabling all Startup programs, and un-hiding file extensions and system files, run a virus scan. MalwareBytes is a free and very effective program that can be installed and run in the safe mode.
Jan 15, 2010 | Google Android
My sony vaio vgc-js160j has a blue screen, shutdown and then restarts
When booting press F8,or your button to get to the Screen that has Safe Mode etc on it..then select 'Disable Automatic Restart on System Error'
Maybe it might be a Memory Fault or a Startup Program causing this BsoD.
You might then try to run your PC in Safe mode and look for Programs you installed recently.
Hope this helps
Dec 24, 2009 | Sony VAIO VGC-JS160J/S Notebook
Computer keeps restarting in safe mode, and will recovery, or after recovery screen come-up, start computer in safe mode or start windows normally, when choosing one computer restarts the process over
This might be caused by the adware /spyware or any tro.. virus. pl check the sys32 folder in safe mode. and go to msconfig ->startup tab and disable all and reinstall the sys. sys will be bootedup. if fails then reinstall the OS.
Aug 20, 2008 | Sony Computers & Internet
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
67 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
