Question about PNY Verto GeForce FX 5200 (128 MB) AGP Graphic Card
Hi All I have same problem with my PC. I reinstalling XP setup & I got the problem of Windows XP setup inspecting Hardware Configuration & then blank screen displayed. Thereafter my machine hanged. So, Please give me solution as soon as earliest .
    President:
  • 1,187 Answers
In the BIOS, disable everything you don't need or have on the computer:
Floppy controller - don't need.
Parallel printer ports? disable for now.
Serial ports? disable for now
You may also want to remove all but one stick of RAM.
If it still fails, change to another stick of RAM.
It will work.
Posted on Sep 04, 2009
Doesn't enable virtualization
To determine whether your PC supports hardware virtualization:
Step 1. Does my PC have a CPU with support for hardware virtualization?
Download and run the Hardware-Assisted Virtualization Detection Tool
If you receive the message This computer does not have hardware-assisted virtualization, your computer does not meet the hardware requirement for Windows Virtual PC, but you can still use Windows 7 XP Mode by running this hotfix. Be aware that XP Mode will run much better if hardware-assisted virtualization can be enabled.
If you receive the message Hardware-assisted virtualization is not enabled on this computer, go on to Step 2 below.
If you receive the message This computer is configured with hardware-assisted virtualization, download and install Windows Virtual PC and Windows XP Mode.
Step 2. Does my PC BIOS support hardware virtualization, and is it turned on?
Instructions to turn on hardware virtualization in your PC BIOS are specific to OEM models. It is important that after changing your BIOS settings the PC is completely shut down at the power switch before restarting so that the new BIOS settings can take place.
Examples for some models of some computer manufacturer's BIOS settings are below:
Sample instructions for your PC
Expand all
Dell systems
Depress the F12 key when boot menu text appears at startup
Select BIOS setup and depress the Enter key
Using the mouse, expand the Virtualization Support menu item by clicking on the plus to the left of Virtualization Support and select Virtualization
Check the Enable Intel Virtualization Technology checkbox
Click Apply
Click Exit
Fully shut down (power off), wait a few seconds, and restart your computer
HP systems
Depress Esc key when prompted at startup
Depress the F10 key to Configure BIOS
Scroll to System Configuration using the arrow keys
Select Virtualization Technology and depress the Enter key
Select Enabled and depress the Enter key
Depress the F10 key to save and exit
Select Yes and depress the Enter key
Lenovo ThinkPad systems
Depress the blue ThinkVantage key when prompted at startup
Depress the F1 key to enter the BIOS setup utility
Using the arrow keys, scroll to Config and depress the Enter key
Scroll to CPU and depress the Enter key
Scroll to Intel Virtualization Technology and depress the Enter key
Depress Enter key to continue
Depress F10 key to save and exit
Acer
PCs capable of supporting Windows XP Mode have already been enabled and do not require additional configuration.
Asus
Samsung
Panasonic
Depress the F2 key when boot menu text appears at startup
Select Advanced menu in Setup Utility
Change "Intel Virtualization Technology" setting from Disable to Enable
Depress F10 to exit Setup Utility
Select Yes in confirmation menu
Depress Enter to exit confirmation menu.
Please note the instructions above may not work in all cases and consulting with your computer manufacturer may be necessary. Additionally, we expect hardware virtualization to become more available when Windows 7 is shipped, particularly in business-class PCs. For those PCs that come pre-installed with Windows XP Mode we recommend the computer manufacturer turn on hardware virtualization before shipping the PC.
Once you have confirmed your PC supports hardware virtualization
Download and install Windows Virtual PC and Windows XP Mode
hope this helps
Aug 08, 2012 | Computers & Internet
Nvalid configuration information - please run SETUP program, The system configuration information does not match the hardware configuration. ...and it will stay there.
Hi oyemsdetosin,
I see that you are encountering an issue with you machine.
try to boot into safemode, once in safe mode unstall what ever program was install recent on the machine and mahy need reinstallation, also check if your drivers are all ok possible windows update may have changed some of your system drivers.
If you cant boot into safe mode try running a system restore using your window disc by running a recovery. If still that does not work I believe you will need to reinstall windows.
I hope this will be helpful.
Have a nice day,
mvincentc
May 16, 2011 | Dell Latitude D600 Notebook
Computer wont bootup windows xp error loading operating system drive 1 not found please help me
1.Restart your computer. Immediately after the screen goes blank for the first time, press the F8 key repeatedly. The Windows Advanced Options menu appears. If the menu does not appear, restart your computer and try again. Use the cursor keys on your keyboard (your mouse will not work) to select Last Known Good Configuration, and then press ENTER. Windows XP attempts to start.
If you recently installed new hardware, shut down your computer and disconnect the hardware. Then, restart Windows XP and troubleshoot your hardware to get it working properly.
3.
Restart your computer and press F8 again. This time, choose Safe Mode and press ENTER. Windows XP attempts to start in Safe Mode, which does not automatically start programs and hardware, and displays very primitive graphics. If Windows XP starts successfully in Safe Mode, you can remove any programs or updates you have recently installed. Then, restart your computer normally.
Performing a repair installation of Windows XP can fix many serious startup problems. While you should not lose any of your important documents, you might lose settings, and you will need to reinstall many updates.
Before performing a repair installation of Windows XP, you should have both your Windows XP CD and your product key available.
To perform a repair installation of Windows XP
1.
Insert your Windows XP CD into your computer.
2.
Restart your computer. If prompted, press a key to start from the CD-ROM.
When the Welcome to Setup page appears, press ENTER on your keyboard.
On the Windows XP Licensing Agreement page, read the licensing agreement. Press the PAGE DOWN key to scroll to the bottom of the agreement. Then, press F8.
When prompted, press R to have Windows XP attempt to repair Windows by reinstalling important Windows components.
The repair and reinstallation process might take more than an hour. Eventually, Setup prompts you to answer questions just as if you were installing Windows XP for the first time. For detailed instructions, read Install Windows XP.
Oct 26, 2010 | Computers & Internet
MESSAGE: SETUP IS INSPECTING YOUR COMPUTERS HARDWARE CONFIGURATION
Check to make sure that you have not left the windows installation disk in your CD/DVD drive. The system boots directly to the disks and begins the installation routine.
If not, you will have to reinstall windows, you had an inturupted or damaged install.
Good luck,
James.
PLEASE VOTE 4 THUMBS UP FOR ME!!!!!!
Apr 27, 2010 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Umm... can't boot to windows at all so the program that was provided wont work, can't reinstall windows automatic disk eject on startup!
And Thanks.
Mar 19, 2010 | Microsoft Windows XP Professional With...
Eee PC 1800HA can't go through windows xp installation
You have a "Driver Issue", generally a "Display Driver" but not always, what you need to do is start PC in "Safe Mode" Press F8 at turn-on, and then remove the display adapter from device manager and reboot, windows will then install a"Generic" driver and ya should be able to get to desktop to get the correct driver, and install. Sometimes it is faulty components too. But it seems ya may be past this point seeing as ya tried to re-install XP on it again... not the best way to handle it, but of course ya didn't know that.
However since ya have tried a setup ya may be in a bit of trouble. I think maybe ya only option is to Format the drive... and totally reinstall Windows XP. (Or ya just gonna have endless trouble). Use the DVD that came with ya PC and reinstall it.
Jan 24, 2010 | ASUS Eee PC 1000HE Netbook
HOW TO ENTER CMOS SETUP OR BIOS SETUP OF SONY VGN-FW290E OR HOW TO INSTALL WIN XP IN THIS NOTEBOOK
To enter the CMOS setup BIOS you hit f2 during the power on. After you enter the bios to the boot up screen and select first boot up = CD ROM. Save the configuration and reboot. Now pop in your windows XP cd into the CDROM, your computer will bootup from the CDROM. You can now reinstall windows.
Dec 11, 2009 | Sony VAIO VGN-FW290JTB Notebook PC
Trying to reinstall windows xp and not letting me
do you have a XP installation disc? do you have a valid product number? (sometimes the product number is located on a sticker, depends if you brought the PC ready made)
Lastly how many times have you reinstalled the OS? if you have a OEM product code I think the limit of reinstalling the OS is 5 times, after then you have to speak to MS. although you have to have to reach the activate windows screen before this becomes an issue.
Nov 14, 2008 | Microsoft Windows XP Home Edition
Acer travelmate 2420
Hello! :)
The first thing I would have you do is to shutdown the computer (Hold the power button until the system turns off) and retry the format. Are you using a Microsoft XP disc or a recovery disc? If your not sure just post with all of the text that appears on the CD.
Sep 11, 2008 | Acer TravelMate 2300 Notebook
Start up problems
Looks like you need to reinstall windows. get a windos setup disk and reinstall it. If it does not install cause windows setup cannot detect your c drive, then you may need to change the hd as well
first try reinstalling windows
Feb 17, 2008 | Dell Latitude D600 Notebook
PNY Verto GeForce FX 5200 (128 MB) AGP Graphic Card Logo
56 people viewed this question
Top PNY Computers & Internet Experts
David
David
marley mcelhinney
Jim Thurston
Are you a PNY Computer and Internet Expert? Answer questions, earn points and help others
