Washer will not drain with clothers in it but will when empty
My washer washes spins but will not drain fully, if I take the clothes out it will drain completely...please help
  • Anonymous Mar 16, 2014
    washer works fine without clothes, but will not drain with clothers
    President:
  • 1,776 Answers
Check the drain line for kinks or obstructions. Check the pump. Remove the hoses from the pump and use a flashlight to look into the suction port. Look for anything clogging the pump (like the occasional stray sock) and check the pump impeller. Make sure there are no broken or missing blades and that the impeller spins freely. If there are any broken/missing blades or if you cannot get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged drain line or pump. Sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 04, 2009
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Frigidaire washer combo dryer.......flsg60rgs0 will spin on last cycle but clothes are still soggy what is the problem.......belt is not broken
I appreciate your post, Sandra Brown!
Based off the information you have provided your Frigidaire washer is not spinning fully to drain the clothes. It sounds like a possible issue with the wash motor of sensor. I would suggest consulting with a professional technician for a proper diagnosis and repair to be completed. This will help to avoid any unnecessary part purchases. Hope this helps. -OOS
Dec 11, 2014 | Frigidaire Washing Machines
Maytag Neptune washer machine won't spin or fully drain
    • 1 Open your home's breaker box and flip the circuit breaker switch to "On." If it is already set to "On," flip it to "Off" and then back to "On" to reset it. A power surge may have interrupted your wash cycle so the drain/spin cycle never actually started.
    • 2 Move the washer away from the wall and straighten the drain hose if it is twisted or turned in a way that makes it difficult for water to flow through it. Replace a kinked hose with a new hose.
    • Sponsored Links
    • 3 Push on the washer door to make sure it is fully closed. The washer will not drain or spin unless the door is closed tight. Press the "Start/Pause" button after you close the door.
    • 4 Wait for about 30 seconds after you press "Start/Pause." The washer will not operate until it has been able to fully lock the door and restart the drain process.
    • 5 Run the clothes through a complete cycle again, making sure you use cold water if there are a lot of suds in the washer. Too much soap in the washer can make it hard to drain. Use high-efficiency or low-sudsing detergents on subsequent uses.
Feb 15, 2013 | Washing Machines
Washer fails to remove water from clothes after rinse and spin cycles are completed. M/N 110.26732500
'f its a top load put something down in lid switch hole.....Start wash cycle let unit go through cycle by itself Don;t touch timer unit should fill then adjatate then drain then you will here a clunk and unit will spin thats the wash////then unit will fill then adjatate then unit will drain(this is the inportant part ) unit should drain completely before it spins if it is spinning with the water in it your gearcase is getting bad//This condition also put stress on the clutch//if unit is not draining and spinning at the same time but just spinning slowly then you will need a clutch.....Hope this helps if i did help you please vote need more help please ask..........
Feb 03, 2011 | Kenmore Washing Machines
How can I get my washing machine to spin and empty with bad timer
Emptying the tub is easy, just lower the drain hose into a bucket on the floor, or into a floor drain. If the timer can be operated manually, turn it to spin, then drain after spinning a while. If this is an electronic timer, you will need to remove the clothes and take to a laundromat or a friend's house to spin the water out.
Dec 03, 2009 | Washing Machines
Washing Machines Logo
114 people viewed this question
Top Washing Machines Experts
