Question about Viking DDBB363 Bottom Freezer Refrigerator
Freezer is freezing fine, but refer will no get below 50 deg. F
The refer is only 3 years old, could there be someting blocking the air flow to the refrigerator? How long should it take the refrigerator to get from 70 deg. to 40 deg.?
    Sergeant:
  • 222 Answers
Sounds like a defrost problem, if you have frost on the inside back panel in the freezer then you have a defrost problem bad defrost timer/board or defrost heater or defrost bimetal thermostat. check em all.
Posted on Sep 04, 2009
Testimonial: "I removed the back panel in the freezer and found that the metal defrost thermostat was not connected to the refer line. Thanks!!"
Too cold freezer, too warm refrigerator compartments at "3" (normal) setting
check the air flow from the freezer to the fresh food side. there may be a defrost problem.
Dec 30, 2012 | Refrigerators
We have had sears tech's here 3 seperate ocassions. They replaced a circut board, thermostat, and heater on 3 seperate occasions. Today I noticed the refigerator getting warm, looked and the freezer side...
you have an airflow problem in the freezer. Is something blocking the vent in the freezer compartment? cold air is produced in the freezer section and flows to refrigerated side through air vents. If they are blocked, the air cannot flow from the freezer and it will freeze over. Not a major problem, just move your stuff around.
Nov 24, 2010 | GE GSH25JSTSS Stainless Steel Side by Side...
I have a Frigidaire Model FRS6R5ESBF that is 3 years old but did not get installed until 4 months ago. The freezer appears to be working fine but the refrigerator side is getting warmer by the day. It...
Could be that the freezer is icing up stopping the air flow coming up into your fridge, try switching it off for at least 12 hours with the freezer door open.
Nov 02, 2010 | Frigidaire Refrigerators
ONLY 3 YEARS OLD, SHUTS OFF COMPLETELY AFTER ABOUT 3 MINUTES, THEN DISPLAY COMES BACK ON ASKING TO SET CLOCK
How long does it stay off? 30 to 60 minutes?? Sounds like the cooling fan is not working or air vents on the unit are blocked.... I saw one unit years ago with this complaint that when the customer turned on the MWO, the fan came on and pulled a curtain covering the pantry up to it, blocking the air flow and causing it to overheat and shut off....
Sep 11, 2009 | GE Microwave Ovens
My two year old refrigerator is now at 60F although the freezer is working fine. What could the problem be?
There is a fan the moves air over the coils that remove the heat from the refrigerator. That air has to be distributed between the freezer and the fresh foods section. To accomplish that, a fresh foods temp dial is located inside that section and lets in either more air or less. Make sure that it is set correctly. Make sure nothing blocks the opening that the air is expelled from. That air flow is important to that sections temperature maintenance.
Jul 05, 2009 | Amana ABB1927DE Bottom Freezer...
No air coming from air diffuser assembly in fridge
through other postings on your web site I was able to determine that the return air flow vents for the refrigerator (diffuser air) was blocked due to frost. I defrosted the unit and it is working fine now.
Jan 05, 2009 | Refrigerators
My freezer works fine, however my fridge is not cold. It seems as there is no air flow in the fridge. I have checked behind the crispers to ensure nothing is blocked. I have a Maytag msd2734ge, wide by...
check in the freezer side and look at the back wall and see if there is any build up of frost, your coil may be block, so no air flowing through the coil, your unit may not defrosting, you need to check the defrost heater,the defrost timer or the defrost thermostat one of these part can be defective
Dec 11, 2008 | Maytag MSD2734GE Side by Side Refrigerator
GE Profile refrigerator model PFCS1NJWA is freezing items in back
slow air flow will cause it to freez check air flow from freezer in at the top and back at the bottom
Nov 30, 2008 | Refrigerators
REfridgerator Failure
Refridgerator is 5 years old. Simply went out of cooling and freezing. Still makes operating sounds and lights work but losing our freezer full of food is disturbing on a refer only 5 years old.What could be wrong?
Mar 17, 2008 | Jenn-Air JCD2389G Side by Side...
Fridge problem
I don't know about the hot points for sure, but all the maytags (I used to work for maytag) have a damper valve in the air tunnel that feeds cold air to the refrigerator. If the damper went bad, it would block cold air flow into the refrigerator. (assuming this model has a damper)
Feb 16, 2008 | Hotpoint  21.8 Cu. Ft. Top-Freezer...
Viking DDBB363 Bottom Freezer Refrigerator Logo
267 people viewed this question
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
