Question about Sony Playstation 3 (PS3) Console
PS3 My PS3 is usually on a HD tv and works fine, although when I hook it up to a non-HD tv 480i it will not display anything. Is there a switch or something?
  • Anonymous Jan 22, 2008
    i Have to same problem. It won't display anything on a non hd tv after being connected to a hd tv where it works perfectly.
  • 23 Answers
You need to reset your video settings when you move to a regular TV. Just hold down the power button, it will beep twice and go back to stand by mode. They boot up again and your video setting should be back to normal ( for standard TV).
Posted on Jan 22, 2008
I have the same problem although reset doesnt work contacted playstation and they were useless told me to keep tryin , ha as if i wa gona stop tryin
Posted on Feb 03, 2008
  • 181 Answers
How are you hooking it up to the other TV? Are you using an HDMI cable?
Posted on Dec 07, 2007
Doesn't recognize non HD TV
hook your PS3 to the tv with the regular cord, put the tv on the channel you want. with the PS3 off but switch in on press and hold the power button until it beeps twice then release. you can also do this the other way round (SD to HD).
Mar 18, 2010 | Sony Playstation 3 (PS3) Console
JVC XV-SA602 player - I just get red and blue wavy lines on my TV, but can get audio. I've checked my component video connections and they seem fine, but cannot get video or even the menu to come up on TV....
I found the problem, or at least the solution. I set the switch on the back of the DVD to "remote" and reset the TV settings on the remote (although they had not changed and were still OK). With the TV/Video switch set to "colorstream", I finally got the video from the DVD. This was odd, because my TV says it does not accept progressive scan and my settings have always been with the switch on 480i on the DVD. The only change has been a added cable TV DVR box capable of HD (although TV is not HD). Does not seem like that should affect things since the cable box just outputs to the TV. But, at any rate, this regained our picture.
Nov 23, 2009 | JVC XV-SA602SL DVD Player
I am trying to hook the Philips 30pf9946 up to an HD Tivo
I am wondering what you are making the connection with, If you are using s-video or composite from your tivo to your hd tv it will only produce 480i. in order to get 480p and above you will need a component video cables or better(hdmi) in order to produce the signal. You may have already known this, but I couldnt tell be the information provided. Hope this helps.
Jun 20, 2009 | Philips 30PF9946 30 in. HD-Ready Plasma...
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
Adjust the system's video output settings. Select the best output settings for the TV in use.
1. Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1
HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p
Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i
Composite / S Video *3 480i 576i
AV MULTI / SCART *4 480p / 480i 576p / 576i
*1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5. Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
6. Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
7. Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
Cant get hdmi for ps3 to work on my jvc hd 52g887
Had same problem with Panasonic PT60LC14 tv when connecting by HDMI cord to my PS3 and a blue ray disc was playing. First, read your tv manual to see what video inputs it supports . Then read the PS3 online manual (section on "video output settings").
For me I found out that my tv only supported 1080i (along with 480i/p, 780p) and the ps3 manual says blue ray outputs 1080p, so my blue ray discs will not play on my tv according to the PS3 manual. PS3 manual says to restart the ps3 (power off, then power on and HOLD for 5 seconds) - then the standard video output settings should be reset. Hopefully the ps3 menu will pop up at least. I haven't tried this yet but if it doesn't work, i'll may try to reset PS3 video out settings manually first using another tv that works with it ..
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
Picture flashing
If it is an older "hd" tv it is probably 'hd ready.' Check for adjustments on your source. The tv will most likely only display the highest resolution it is given.
Dec 28, 2007 | Zenith C27V36 27" TV
PS3 Hi Def to normal tv
press front power switch to turn it on and hold for a few seconds, it will beep a few times and turn off automatically. now everything you setup for hd tv will be defaulted to normal.
Dec 12, 2007 | Sony PlayStation® 3 (60 GB) Console
Unhooked ps3 from an hd tv and plugged it into an sd tv and it shows no picture.
when in standby mode(redlight) push and hold the power power button until you hear the second beep. This should reset your PS3 to it's standard 480i resolution.
Sep 21, 2007 | Sony Playstation 3 (PS3) Console
Issue with 480i display
Possible decoder problem in the respective IC...accordianman
Sep 15, 2007 | Samsung DLP HL-P5663W 56" TV
Sony Playstation 3 (PS3) Console Logo
111 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
